Zuiron
November 12, 2021, 4:37pm
#1
so yeah like title. um and also KDE also is super laggy. im using video-nvidia. is this like a nvidia issue? if it is. i do have a rx580 which i could switch to i know amd is better but for one more week im kinda stuck with this gtx 970 card.
which is even worse like when i try play Anno 1800 thats even worse. FPS from dxvk says 40+ but it feels like 3 or maybe max 5 FPS xD horrible.
Zuiron
November 21, 2021, 6:08pm
#2
ok so now everything is smooth it seems after ive switched to my rx580 card. have not tested games YET.
but for some reason the display configuration setting window wont open .
Can you post inxi -Fza
on console ?
Zuiron
November 21, 2021, 6:40pm
#4
System: Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=c42e44df-19da-4f3f-b047-f9ce7b48f8c2 rw quiet
cryptdevice=UUID=b8f088a5-eb34-4324-8285-ba65a64ce5eb:luks-b8f088a5-eb34-4324-8285-ba65a64ce5eb
root=/dev/mapper/luks-b8f088a5-eb34-4324-8285-ba65a64ce5eb apparmor=1 security=apparmor
resume=/dev/mapper/luks-12d24fe2-8692-4f03-acca-053726bed626 udev.log_priority=3
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Desktop Mobo: ASUSTeK model: Z170-P v: Rev X.0x serial: <filter> UEFI: American Megatrends v: 0705
date: 02/23/2016
CPU: Info: Quad Core model: Intel Core i5-6600K bits: 64 type: MCP arch: Skylake-S family: 6 model-id: 5E (94)
stepping: 3 microcode: EA cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 28009
Speed: 800 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] vendor: Tul
driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0") s-diag: 777mm (30.6")
Monitor-1: HDMI-A-0 res: 2560x1440 hz: 60 dpi: 123 size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
OpenGL: renderer: AMD Radeon RX 580 Series (POLARIS10 DRM 3.41.0 5.13.19-2-MANJARO LLVM 13.0.0) v: 4.6 Mesa 21.2.5
direct render: Yes
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: Tul driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK PRIME B450M-A driver: r8169
v: kernel port: d000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: down mac: <filter>
Device-2: ASUSTek AC51 802.11a/b/g/n/ac Wireless Adapter [Mediatek MT7610U] type: USB driver: mt76x0u
bus-ID: 1-11:7 chip-ID: 0b05:17d1 class-ID: 0000 serial: <filter>
IF: wlp0s20f0u11 state: down mac: <filter>
IF-ID-1: enp0s20f0u8 state: unknown speed: -1 duplex: half mac: <filter>
Bluetooth: Device-1: Huawei CLT-L29 type: USB driver: rndis_host v: kernel bus-ID: 1-8:3 chip-ID: 12d1:108a class-ID: 0a00
serial: <filter>
Drives: Local Storage: total: 1.58 TiB used: 384.63 GiB (23.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 39.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SHSS37A240G size: 223.57 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00.r scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 2B6Q scheme: GPT
Partition: ID-1: / raw-size: 896.8 GiB size: 881.65 GiB (98.31%) used: 384.63 GiB (43.6%) fs: ext4 dev: /dev/dm-0
maj-min: 254:0 mapped: luks-b8f088a5-eb34-4324-8285-ba65a64ce5eb
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 440 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
Swap: Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 34.41 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-12d24fe2-8692-4f03-acca-053726bed626
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: amdgpu temp: 41.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1027
Info: Processes: 271 Uptime: 43m wakeups: 0 Memory: 31.29 GiB used: 4.6 GiB (14.7%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1429 pacman: 1423 lib: 413 flatpak: 6 Shell: Zsh v: 5.8
default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.08
What says ```mhwd-kernel -li`` on console ?
Zuiron
November 21, 2021, 6:45pm
#6
Currently running: 5.13.19-2-MANJARO (linux513)
Can you install kernel 5.14 and kernel 5.10 and test again?
Because kernel 5.13 is EOL.
mhwd-kernel -i linux514
and mhwd-kernel -i linux510
Zuiron
November 21, 2021, 6:50pm
#8
ok ill try 5.14 first. its gonna take awhile. my current internet connection is capped @ 300kbits xD
Zuiron
November 21, 2021, 7:36pm
#9
just updated and switched to kernel 5.14 now it works. marking this as resolved. thanks @Keruskerfuerst
system
Closed
November 24, 2021, 9:37am
#10
