Hey,
I know that similar topics already exist but since I did not have this problem the first two years with Manjaro and without Hardware or majoar software changes it now just constantly keeps coming up I thought I’d ask here.
So what happens is, that I get an unusually high cpu usage from (udev-worker), when I enter
udevadm monitor
I get that it is constantly recognizing a device change:
KERNEL[760.644667] change /devices/pci0000:00/0000:00:17.0/ata1/host0/target0:0:0/0:0:0:0/block/sda/sda1 (block)
UDEV [760.664992] change /devices/pci0000:00/0000:00:17.0/ata1/host0/target0:0:0/0:0:0:0/block/sda (block)
KERNEL[760.665964] change /devices/pci0000:00/0000:00:17.0/ata1/host0/target0:0:0/0:0:0:0/block/sda (block)
KERNEL[760.667413] change /devices/pci0000:00/0000:00:17.0/ata1/host0/target0:0:0/0:0:0:0/block/sda/sda1 (block)
UDEV [760.668116] change /devices/pci0000:00/0000:00:17.0/ata1/host0/target0:0:0/0:0:0:0/block/sda/sda1 (block)
UDEV [760.683925] change /devices/pci0000:00/0000:00:17.0/ata1/host0/target0:0:0/0:0:0:0/block/sda (block)
UDEV [760.690878] change /devices/pci0000:00/0000:00:17.0/ata1/host0/target0:0:0/0:0:0:0/block/sda/sda1 (block)
KERNEL[760.697150] change /devices/pci0000:00/0000:00:17.0/ata1/host0/target0:0:0/0:0:0:0/block/sda (block)
KERNEL[760.698944] change /devices/pci0000:00/0000:00:17.0/ata1/host0/target0:0:0/0:0:0:0/block/sda/sda1 (block)
Running
sudo systemctl stop systemd-udevd systemd-udevd-kernel.socket systemd-udevd-control.socket
sudo systemctl start systemd-udevd systemd-udevd-kernel.socket systemd-udevd-control.socket
temporarily fixes the issue until the next boot.
Here is my output from inxi --full --admin --filter --width
Kernel: 6.5.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=f54f97ce-0481-4e33-991c-8c70989bbb74 rw quiet splash apparmor=1
Desktop: GNOME v: 44.5 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Laptop System: ASUSTeK product: UX410UAK v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: UX410UAK v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: UX410UAK.308 date: 11/08/2017
ID-1: BAT0 charge: 13.1 Wh (40.4%) condition: 32.4/48.3 Wh (67.0%)
power: 15.2 W volts: 11.4 min: 11.4 model: ASUSTeK ASUS Battery type: Li-ion
serial: N/A status: charging cycles: 1075
Info: model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017 process: Intel 14nm
family: 6 model-id: 0x8E (142) stepping: 9 microcode: 0xF4
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 3100 min/max: 400/3100 scaling: driver: intel_pstate
governor: powersave cores: 1: 3100 2: 3100 3: 3100 4: 3100 bogomips: 21607
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5916
class-ID: 0300
Device-2: Chicony USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2 chip-ID: 04f2:b57a
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.1
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x14d2 built: 2016 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 620 (KBL GT2)
device-ID: 8086:5916 memory: 7.47 GiB unified: yes display-ID: :0.0
API: Vulkan v: 1.3.264 layers: 4 device: 0 type: integrated-gpu name: Intel
HD Graphics 620 (KBL GT2) driver: mesa intel v: 23.1.9-manjaro1.1
device-ID: 8086:5916 surfaces: xcb,xlib,wayland
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
API: ALSA v: k6.5.5-1-MANJARO status: kernel-api with: aoss
Server-2: JACK v: 1.9.22 status: off
tools: cadence,jack_control,jack_mixer,qjackctl
Server-3: PipeWire v: 0.3.80 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-4: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
Device-1: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24f3 class-ID: 0280
IF-ID-1: br-1ac68488355f state: down mac: <filter>
IF-ID-2: br-676d578d147a state: down mac: <filter>
IF-ID-3: br-8e3a90325e51 state: down mac: <filter>
IF-ID-4: br-aec406e2658f state: down mac: <filter>
IF-ID-5: br-d095adcc41e0 state: down mac: <filter>
IF-ID-6: br-f46e94679df1 state: down mac: <filter>
IF-ID-7: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-8: veth8a87b91 state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:3 chip-ID: 8087:0a2b
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.2
lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 2.73 TiB used: 1.6 TiB (58.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M81000G
lanes: 4 tech: SSD serial: <filter> fw-rev: S5Z42105 temp: 34.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH3 2T00
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 20RL
ID-1: / raw-size: 784.92 GiB size: 771.52 GiB (98.29%)
used: 626.48 GiB (81.2%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
used: 29.6 MiB (30.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: file size: 9.77 GiB used: 983.8 MiB (9.8%) priority: -2
file: /swapfile
System Temperatures: cpu: 77.0 C pch: 58.5 C mobo: N/A
Fan Speeds (rpm): cpu: 3900
Processes: 290 Uptime: 9m wakeups: 1 Memory: total: 8 GiB available: 7.65 GiB
used: 6.01 GiB (78.6%) Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 2808
pm: nix-default pkgs: 0 pm: nix-sys pkgs: 0 pm: nix-usr pkgs: 0 pm: pacman
pkgs: 2775 libs: 573 tools: gnome-software,pamac,yay pm: flatpak pkgs: 12
pm: snap pkgs: 21 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.30
What I tried:
- Switching kernel versions
- Updating whole system
- Removing / Adding USB accessories
All help is greatly appreciated!
