i have some problems with the usage of virtualbox on manjaro host
i noticed the high cpu when i running vms ( windows and linux like debian os )
i saw more of 100% of cpu usage when i’m running the vms
the version of vbox that i’m using is the 6.1 , it has the guest additions installed by AUR packages
`inxi -FN
System: Host: hikari-hp Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 Console: tty 1 Distro: Manjaro Linux Machine: Type: Laptop System: HP product: HP Pavilion Notebook v: N/A serial: 5CD8475263 Mobo: HP model: 84F8 v: 08.10 serial: PHNEF018JBK089 UEFI: AMI v: F.18 date: 06/20/2018 Battery: ID-1: BAT0 charge: 39.0 Wh condition: 52.7/52.7 Wh (100%) CPU: Info: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP L2 cache: 8192 KiB Speed: 900 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900 8: 900 Graphics: Device-1: Intel UHD Graphics 630 driver: i915 v: kernel Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] driver: nvidia v: 455.45.01 Device-3: Chicony HP Wide Vision HD type: USB driver: uvcvideo Display: server: X.Org 1.20.9 driver: modesetting,nvidia resolution: 1920x1080~60Hz OpenGL: renderer: GeForce GTX 1050/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01 Audio: Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel Sound Server: ALSA v: k5.9.11-3-MANJARO Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 IF: eno1 state: down Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter driver: rtw_8822be IF: wlo1 state: up Drives: Local Storage: total: 1.03 TiB used: 239.97 GiB (22.8%) ID-1: /dev/sda vendor: SanDisk model: SD9SN8W-128G-1006 size: 119.24 GiB ID-2: /dev/sdb vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci Partition: ID-1: / size: 83.17 GiB used: 24.34 GiB (29.3%) fs: ext4 dev: /dev/sda2 ID-2: /home size: 904.76 GiB used: 215.63 GiB (23.8%) fs: ext4 dev: /dev/sdb1 Swap: ID-1: swap-1 type: partition size: 4.00 GiB used: 0 KiB (0.0%) dev: /dev/sda1 Sensors: System Temperatures: cpu: 38.0 C mobo: N/A gpu: nvidia temp: 37 C Fan Speeds (RPM): N/A Info: Processes: 250 Uptime: 38m Memory: 7.63 GiB used: 1.22 GiB (16.0%) Shell: Bash inxi: 3.1.08 `
what can i do ?
thanks
