Hidden files and drawers not visible in file-requesters;
for example in Meld or Firefox - when I try to open
there are only non-hidden files visible - Example .mozilla is invisible.
When I try to save files 8downloaded) in Firefox - the same.
Hidden files are not visible, although Nautilus shows them…
Thank you, that helps.
Exists a permanent solution (dconf)?
I try this:
!WORKS! - another possible solution…
