Good Day,
I am using terminal to change kernels.
There were a series of error and at least one relates to updating packages FIRST. Way back in the day I had that covered with sudo apt-get update etc. That was a long time ago. FOr all intents and purposes I am a brand new user. My understanding from the literature is that PAMAC updates everything. Not too sure that’s working out though. So here’s the error message I got during the kernal switcharoo:
[obit@Neptune ~]$ sudo mhwd-kernel -i linux515
[sudo] password for obit:
core 169.2 KiB 2.83 KiB/s 01:00 [######################] 100%
extra.db failed to download
error: failed retrieving file 'core.db' from manjaro.moson.eu : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
error: failed retrieving file 'core.db' from quantum-mirror.hu : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
error: failed retrieving file 'extra.db' from manjaro.moson.eu : OpenSSL SSL_read: Connection reset by peer, errno 104
error: failed retrieving file 'extra.db' from quantum-mirror.hu : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
error: failed retrieving file 'extra.db' from fastmirror.pp.ua : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
error: failed retrieving file 'extra.db' from mirror.cyberhost.uk : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
error: failed retrieving file 'extra.db' from repo.ialab.dsu.edu : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
error: failed retrieving file 'extra.db' from mirror.alpix.eu : SSL connection timeout
error: failed retrieving file 'extra.db' from manjaro.kyberorg.fi : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
error: failed to synchronize all databases (download library error)
The following packages are out of date, please update your system first: audit bash bashrc-manjaro btrfs-progs ca-certificates-mozilla cryptsetup device-mapper gnupg icu krb5 libcap libelf libldap libnftnl lvm2 manjaro-release mkinitcpio mkinitcpio-busybox nfs-utils nfsidmap nss pacman-mirrors python rpcbind sqlite sudo systemd systemd-libs systemd-sysvcompat xfsprogs
Do you want to continue anyway? [y/N]
Yes in fact today my network is horrible, and I was expecting more mirrors based on my readings. thanks for confirming this for me. So I will update mirrors again later too.
Good morning, I am assuming you mean sudo pacman-mirrors…? My terminal threw up a Must have Root Privileges ERROR. Silly question, but you put sudo in after the &&. Is this format correct? Do you ever use sudo twice in the same line such as if I were to add it to the beginning of the first command do I leave the existing sudo after the &&?
Thanks
