Hibernation leads to freeze
I am running Manjaro on a new laptop (Asus Zenbook UX3405M) and hibernation is not working. The laptop has 16GB of RAM and swap is the same size and on.
This is the log from journalctl when going into hibernation:
Okt 13 12:06:05 seblap systemd-logind[805]: The system will hibernate now!
Okt 13 12:06:05 seblap ModemManager[864]: <msg> [sleep-monitor-systemd] system is about to suspend
Okt 13 12:06:05 seblap NetworkManager[799]: <info>  [1760349965.3412] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Okt 13 12:06:05 seblap ModemManager[864]: <msg> [sleep-monitor-systemd] ready to sleep; dropping inhibitor
Okt 13 12:06:05 seblap NetworkManager[799]: <info>  [1760349965.3417] device (wlo1): state change: unavailable -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
Okt 13 12:06:05 seblap NetworkManager[799]: <info>  [1760349965.3438] device (wlo1): set-hw-addr: reset MAC address to 6C:2F:80:F3:A8:68 (unmanage)
Okt 13 12:06:05 seblap NetworkManager[799]: <info>  [1760349965.3444] device (p2p-dev-wlo1): state change: unavailable -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
Okt 13 12:06:05 seblap NetworkManager[799]: <info>  [1760349965.3445] manager: NetworkManager state is now ASLEEP
Okt 13 12:06:05 seblap NetworkManager[799]: <info>  [1760349965.3447] device (enp0s13f0u1u2c2): state change: activated -> deactivating (reason 'sleeping', managed-type: 'full')
Okt 13 12:06:05 seblap systemd[1]: Starting Network Manager Script Dispatcher Service...
Okt 13 12:06:05 seblap systemd[1]: Started Network Manager Script Dispatcher Service.
Okt 13 12:06:05 seblap NetworkManager[799]: <info>  [1760349965.4028] device (enp0s13f0u1u2c2): state change: deactivating -> disconnected (reason 'sleeping', managed-type: 'full')
Okt 13 12:06:05 seblap NetworkManager[799]: <info>  [1760349965.4032] dhcp4 (enp0s13f0u1u2c2): canceled DHCP transaction
Okt 13 12:06:05 seblap NetworkManager[799]: <info>  [1760349965.4032] dhcp4 (enp0s13f0u1u2c2): activation: beginning transaction (timeout in 45 seconds)
Okt 13 12:06:05 seblap acvpnagent[835]: The network interface address for the VPN connection has gone down.
Okt 13 12:06:05 seblap NetworkManager[799]: <info>  [1760349965.4032] dhcp4 (enp0s13f0u1u2c2): state changed no lease
Okt 13 12:06:05 seblap acvpnagent[835]: IP addresses from active interfaces: enp0s13f0u1u2c2: 192.168.211.54
Okt 13 12:06:05 seblap NetworkManager[799]: <info>  [1760349965.4033] dhcp6 (enp0s13f0u1u2c2): canceled DHCP transaction
Okt 13 12:06:05 seblap NetworkManager[799]: <info>  [1760349965.4033] dhcp6 (enp0s13f0u1u2c2): activation: beginning transaction (timeout in 45 seconds)
Okt 13 12:06:05 seblap NetworkManager[799]: <info>  [1760349965.4033] dhcp6 (enp0s13f0u1u2c2): state changed no lease
Okt 13 12:06:05 seblap acvpnagent[835]: A network interface has gone down.
Okt 13 12:06:05 seblap acvpnagent[835]: Function: applyHostConfigForNoVpn File: ../../vpn/Agent/MainThread.cpp Line: 13070 No network interface is available, cannot determine potential public addresses.
Okt 13 12:06:05 seblap acvpnagent[835]: Current network state: No network interface
Okt 13 12:06:05 seblap NetworkManager[799]: <info>  [1760349965.5860] device (enp0s13f0u1u2c2): state change: disconnected -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
Okt 13 12:06:05 seblap systemd[1]: Reached target Sleep.
Okt 13 12:06:05 seblap systemd[1]: Starting System Hibernate...
Okt 13 12:06:05 seblap systemd[1]: session-1.scope: Unit now frozen-by-parent.
Okt 13 12:06:05 seblap systemd[1]: user.slice: Unit now frozen.
Okt 13 12:06:05 seblap systemd[1]: user-1000.slice: Unit now frozen-by-parent.
Okt 13 12:06:05 seblap systemd[1]: user@1000.service: Unit now frozen-by-parent.
Okt 13 12:06:05 seblap systemd-sleep[26250]: Successfully froze unit 'user.slice'.
Okt 13 12:06:05 seblap systemd-sleep[26250]: Performing sleep operation 'hibernate'...
Okt 13 12:06:05 seblap kernel: PM: Image not found (code -16)
Okt 13 12:06:05 seblap kernel: PM: hibernation: hibernation entry
-- Boot 2c7d7f83175b4170bcf8a96f7a03a54b --
I am using KDE Plasma with Wayland. What happens is that the display freezes with the mouse pointer still visible but it doesn’t shut off. I have to perform a hard shutdown.
The second to last entry in the logs “kernel: PM: Image not found (code -16)” seems to be a pointer that I cannot make sense of. I’ve added the “resume” tag to the kernel command line with the swap UUID and updated grub.
Which other logs could be helpful?
inxi -zv8
would be nice - to see the configuration of the kernel command line, among other things
/etc/mkinitcpio.conf must contain the “resume” HOOK
and
the kernel command line must contain the "resume=UUID=your_swap_device_UUID" parameter
Power management/Suspend and hibernate - ArchWiki
Perhaps your machine model has been mentioned here in the forum already with regards to hibernation?
Thank you. Here is the output of inxi:
  Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=fdc01839-1b01-459f-96a4-dbdaa3edd4c2 rw rootflags=subvol=@
    resume=/dev/disk/by-uuid/e01157a8-4b44-493c-afce-1eced696794c
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
  Type: Laptop System: ASUSTeK product: ASUS Zenbook 14 UX3405MA_UX3405MA
    v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: UX3405MA v: 1.0 serial: <filter>
    uuid: 81c8f7c1-2d23-c045-be0a-09e99e77f849 UEFI: American Megatrends LLC.
    v: UX3405MA.311 date: 06/06/2025
  ID-1: BAT0 charge: 69.6 Wh (100%) condition: 69.6/75.1 Wh (92.7%)
    power: 0.1 W volts: 8.69 min: 7.97 model: ASUSTeK ASUS Battery type: Li-ion
    serial: N/A charging: status: full control: start: N/A end: 100%
    cycles: 32
  System RAM: total: 16 GiB available: 14.99 GiB used: 5.25 GiB (35.0%)
  Array-1: capacity: 16 GiB slots: 8 modules: 8 EC: None
    max-module-size: 2 GiB note: est.
  Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous
    size: 2 GiB speed: 7467 MT/s volts: curr: 0.5 min: 0.5 max: 0.5
    width (bits): data: 16 total: 16 manufacturer: Micron Technology
    part-no: MT62F1G32D2DS-026 serial: N/A
  Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous
  Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous
  Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous
  Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous
  Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous
  Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous
  Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous
  Slot: 12 type: PCIe gen: 5 status: available length: other volts: 3.3
    bus-ID: 00:01.0
  Slot: 1 type: PCIe gen: 4 status: available length: other volts: 3.3
    bus-ID: 00:1c.0
  Info: model: Intel Core Ultra 7 155H socket: U3E1 bits: 64 type: MST AMCP
    arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
    family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x25
  Topology: cpus: 1x dies: 1 clusters: 9 cores: 16 threads: 22 mt: 6 tpc: 2
    st: 10 smt: enabled cache: L1: 1.4 MiB desc: d-8x32 KiB, 6x48 KiB; i-14x64
    KiB L2: 18 MiB desc: 9x2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 400 min/max: 400/4500:4800:3800:2500
    base/boost: 3861/4800 scaling: driver: intel_pstate governor: powersave
    volts: 0.9 V ext-clock: 100 MHz cores: 1: 400 2: 400 3: 400 4: 400 5: 400
    6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
    15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 21: 400 22: 400
    bogomips: 131824
    bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
    f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
    ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
    movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
    rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
    split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
    user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
    conditional; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
  Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: ASUSTeK
    driver: i915 v: kernel alternate: xe arch: Xe-LPG process: Intel 4 (7nm+)
    built: 2023+ ports: active: HDMI-A-1,eDP-1 off: DP-1 empty: DP-2
    bus-ID: 0000:00:02.0 chip-ID: 8086:7d55 class-ID: 0300
  Device-2: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.4:7
    chip-ID: 046d:08e5 class-ID: 0102 serial: <filter>
  Device-3: Shinetech USB2.0 FHD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-9:3 chip-ID: 3277:0055
  Display: unspecified server: X.Org v: 24.1.8 with: Xwayland v: 24.1.8
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :1 screens: 1
  Screen-1: 0 s-res: 8000x2134 s-dpi: 96 s-size: 2117x565mm (83.35x22.24")
    s-diag: 2191mm (86.26")
  Monitor-1: HDMI-A-1 pos: top-right res: mode: 5120x2133 hz: 75
    scale: 100% (1) dpi: 148 size: 880x367mm (34.65x14.45") diag: 953mm (37.54")
    modes: N/A
  Monitor-2: eDP-1 pos: primary,bottom-l res: mode: 2880x1800 hz: 120
    scale: 100% (1) dpi: 242 size: 302x189mm (11.89x7.44") diag: 356mm (14.03")
    modes: N/A
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.3-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc Graphics (MTL)
    device-ID: 8086:7d55 memory: 14.64 GiB unified: yes
  API: Vulkan v: 1.4.321 layers: 1 device: 0 type: integrated-gpu name: Intel
    Arc Graphics (MTL) driver: mesa intel v: 25.2.3-arch1.2
    device-ID: 8086:7d55 surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Meteor Lake-P HD Audio vendor: ASUSTeK
    driver: sof-audio-pci-intel-mtl
    alternate: snd_hda_intel,snd_sof_pci_intel_mtl bus-ID: 0000:00:1f.3
    chip-ID: 8086:7e28 class-ID: 0401
  API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.8 status: n/a (root, process) with:
  Device-1: Intel Meteor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 0000:00:14.3 chip-ID: 8086:7e40 class-ID: 0280
  Device-2: ASUSTek USB 10/100/1000 LAN driver: cdc_ether type: USB rev: 3.2
    speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1.2:3 chip-ID: 0b05:65f1
    class-ID: 0a00 serial: <filter>
  IF: enp0s13f0u1u2c2 state: unknown speed: 1000 Mbps duplex: half
    mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0033
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 4 state: up address: N/A
  Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
    driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:7d0b rev:
    class-ID: 0104
  Local Storage: total: 953.87 GiB used: 109.15 GiB (11.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron
    model: MTFDKBA1T0QFM-1BD1AABGB size: 953.87 GiB block-size: physical: 512 B
    fw-rev: V3MA101 temp: 43.9 C scheme: GPT
  SMART: yes health: PASSED on: 73d 11h cycles: 215
    read-units: 11,743,539 [6.01 TB] written-units: 11,063,345 [5.66 TB]
  ID-1: / raw-size: 836.88 GiB size: 836.88 GiB (100.00%)
    used: 108.44 GiB (13.0%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p7
    maj-min: 259:7 label: N/A uuid: fdc01839-1b01-459f-96a4-dbdaa3edd4c2
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 114.4 MiB (44.7%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: SYSTEM uuid: 566B-E77D
  ID-3: /home raw-size: 836.88 GiB size: 836.88 GiB (100.00%)
  ID-4: /mnt/system_share raw-size: N/A size: 3.58 TiB
    used: 1.47 TiB (41.1%) fs: cifs dev: /dev/system_share
  ID-5: /var/cache raw-size: 836.88 GiB size: 836.88 GiB (100.00%)
  ID-6: /var/log raw-size: 836.88 GiB size: 836.88 GiB (100.00%)
  ID-1: swap-1 type: partition size: 16 GiB used: 609.4 MiB (3.7%)
    priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: e01157a8-4b44-493c-afce-1eced696794c
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
    uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 99 GiB fs: ntfs label: OS
    uuid: 6E8E6DA58E6D6715
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1.46 GiB fs: ntfs
    label: RECOVERY uuid: B4ECDC60ECDC1E84
  ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 260 MiB fs: vfat label: MYASUS
    uuid: 7082-794F
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
  Hub-3: 2-1:2 info: Realtek Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
  Device-1: 2-1.2:3 info: ASUSTek USB 10/100/1000 LAN
    type: ethernet network,CDC-data driver: cdc_ether interfaces: 2 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 112mA
    chip-ID: 0b05:65f1 class-ID: 0a00 serial: <filter>
  Hub-4: 2-1.3:4 info: Realtek Hub ports: 4 rev: 3.0
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-6: 3-1:2 info: Realtek RTS5411 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
  Device-1: 3-1.1:9 info: DigitalPersona Fingerprint Reader
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 200mA
    chip-ID: 05ba:000a class-ID: 0000 serial: <filter>
  Hub-7: 3-1.3:6 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
  Device-1: 3-1.4:7 info: Logitech C920 PRO HD Webcam type: video,audio
  Device-2: 3-1.5:8 info: Realtek BillBoard Device type: billboard
    driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 chip-ID: 0bda:5418 class-ID: 1100
  Device-3: 3-9:3 info: Shinetech USB2.0 FHD UVC WebCam type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 3277:0055 class-ID: fe01
    serial: <filter>
  Device-4: 3-10:5 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  Hub-8: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Src: /sys System Temperatures: cpu: 57.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 2000
  Packages: pm: pacman pkgs: 1813 libs: 430 tools: gnome-software,pamac,yay
    pm: flatpak pkgs: 0
  Active pacman repo servers in: /etc/pacman.conf
    1: https://download.sublimetext.com/arch/stable/x86_64
    1: https://manjaro.kurdy.org/stable/$repo/$arch
    2: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    3: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    7: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    8: https://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 462
  1: cpu: 5.1% command: firefox pid: 3290 mem: 539.2 MiB (3.5%)
  2: cpu: 4.3% command: kwin_wayland pid: 1803 mem: 231.5 MiB (1.5%)
  3: cpu: 3.5% command: baloo_file_extractor pid: 3188 mem: 77.5 MiB (0.5%)
  4: cpu: 1.7% command: plasmashell pid: 2588 mem: 457.2 MiB (2.9%)
  5: cpu: 1.7% command: [kworker/u89:55-btrfs-endio] pid: 7676
    mem: 0.00 MiB (0.0%)
  Memory top: 5 of 462
  1: mem: 539.2 MiB (3.5%) command: firefox pid: 3290 cpu: 5.1%
  2: mem: 457.2 MiB (2.9%) command: plasmashell pid: 2588 cpu: 1.7%
  3: mem: 369.6 MiB (2.4%) command: firefox pid: 4242 cpu: 1.4%
  4: mem: 350.3 MiB (2.2%) command: thunderbird pid: 3315 cpu: 1.2%
  5: mem: 262.2 MiB (1.7%) command: firefox pid: 17631 cpu: 1.3%
  Processes: 462 Power: uptime: 12m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 5.98 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Sudo (sudo) v: 1.9.17p1
    default: Bash v: 5.3.3 running-in: tmux: inxi: 3.3.39
I indeed misread the wiki page. I will add the hook to mkinitcpio.conf.
That kind of did it. However, the screen still freezes on hibernate and the laptop does not shut off (looks just like before). After restart, it then just loads the frozen screen again and I have to wait a couple of seconds for the system to become usable again. So hibernation did work, I just had to power off the machine manually. Any ideas?
Me?
No.
But I think I saw your machine (or a similar one) mentioned here.
Did you look?
That was about a different issue when waking (some keys not working). I don’t have that issue.
I’m guessing that will be your problem. Not enough Swap to hibernate. Try 20 GB or possibly more.
For Hibernate to work, Swap needs to be larger than your RAM.
As I said earlier, hibernation works now. The laptop just doesn’t shut off after hibernation is complete.
As suggested, for hibernation to work effectively:
Then, hibernation hasn’t really completed, has it? I should think you might wish to rule out any possible contributors.
Rather than dismissing the idea completely, consider increasing your swap partition size and perhaps configuring zswap.
