I have two symptoms with hibernation on this laptop, and I don’t know whether they are related:
- In
platformmode, the machine doesn’t power off after hibernating. - A second hibernate in the same boot doesn’t resume, and the session is lost.
System
- HP ZBook Ultra G1a 14 (AMD Strix Halo), BIOS X89 Ver. 01.01.02 (02/07/2025)
- Kernel 7.2.9-1-MANJARO, systemd 261.3
- LUKS + btrfs, 64 GiB swapfile on its own subvolume (default plasma installation)
- No
resume=/resume_offset=on the kernel command line: resume relies on theHibernateLocationEFI variable written by systemd HOOKS=(base udev autodetect microcode kms modconf block keyboard keymap consolefont plymouth encrypt resume filesystems)
Kernel: 7.2.9-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.7.5 Distro: Manjaro Linux
Type: Laptop System: HP product: HP ZBook Ultra G1a 14 inch Mobile
Workstation PC v: SBKPF,SBKPFV2 serial: <superuser required>
Mobo: HP model: 8D01 v: KBC Version 35.26.00 serial: <superuser required>
Firmware: UEFI vendor: HP v: X89 Ver. 01.01.02 date: 02/07/2025
Info: 12-core model: AMD RYZEN AI MAX PRO 390 w/ Radeon 8050S bits: 64
type: MT MCP cache: L2: 12 MiB
Speed (MHz): avg: 4859 min/max: 609/5057 cores: 1: 4859 2: 4859 3: 4859
4: 4859 5: 4859 6: 4859 7: 4859 8: 4859 9: 4859 10: 4859 11: 4859 12: 4859
13: 4859 14: 4859 15: 4859 16: 4859 17: 4859 18: 4859 19: 4859 20: 4859
21: 4859 22: 4859 23: 4859 24: 4859
Device-1: Advanced Micro Devices [AMD/ATI] Strix Halo [Radeon Graphics /
Radeon 8050S 8060S Graphics] driver: amdgpu v: kernel
Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
dri: radeonsi gpu: amdgpu resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
3: 1920x1200~60Hz
API: EGL v: 1.5 drivers: radeonsi,swrast
API: OpenGL v: 4.6 vendor: amd mesa v: 26.2.4-arch1.1 renderer: AMD
Radeon 8050S Graphics (radeonsi strix_halo ACO DRM 3.64 7.2.9-1-MANJARO)
API: Vulkan v: 1.4.363 drivers: radv surfaces: N/A
x11: xdpyinfo, xprop, xrandr
ID-1: swap-1 type: file size: 64 GiB used: 2.9 GiB (4.5%)
file: /swap/swapfile
Symptom 1: no power-off in platform mode
With the default HibernateMode=platform shutdown, hibernating turns the screen off, but the power LED and fans stay on, even after tens of minutes. After a forced power-off with the power button, the session resumes correctly, so the image was written completely.
- It did power off on 2026-09-18 with kernel 7.2.3, also in
platformmode, with a simpler pre-hibernate unit. - The failure I observed was the first hibernate since upgrading to 7.2.9 (on 2026-10-29). I have one observed failure, so I can’t call this a confirmed regression.
- The log shows no
Wakeup event detected during hibernation, rolling back, which I did get on another occasion when I pressed a key during hibernation. - Nothing is logged for the hang itself: journald is frozen at that point, and resuming discards that memory.
- Wake-enabled in
/proc/acpi/wakeupfor S4:GP11,GP12,XHC1.
What I tried: HibernateMode=shutdown in a sleep.conf.d drop-in. The machine powers off and resumes fine, so I am using this as a workaround.
At the time of the failure, my pre-hibernate unit also ran echo 0 > /sys/power/image_size. I have since removed that line, but I have not retested platform mode without it, so I can’t rule it out as a factor.
Symptom 2: second hibernate in the same boot doesn’t resume
The first hibernate after a boot resumes correctly. A second hibernate in that same boot powers off, but the next start is a fresh boot and the session is lost. This happened 2 times out of 2.
| Time | Hibernate | Mode | image_size=0 |
Result |
| 14:14 | 1st in boot | platform |
yes | resumed (after forced power-off) |
| 17:07 | 2nd in boot | shutdown |
yes | fresh boot, session lost |
| 17:22 | 1st in boot | shutdown |
no | resumed |
| 17:27 | 2nd in boot | shutdown |
no | fresh boot, session lost |
Every hibernate that was the first in its boot logs PM: Image not found (code -16) at entry. Both second hibernates do not:
17:22:10 kernel: PM: Image not found (code -16)
17:22:10 kernel: PM: hibernation: hibernation entry
17:23:46 kernel: efivarfs: removing variable HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67
17:23:46 kernel: PM: hibernation: hibernation exit
17:27:36 kernel: PM: hibernation: hibernation entry
On the fresh boot after 17:07, HibernateLocation was absent, /sys/power/resume was 0:0, and there was no Image not found (code -22). I do get -22 on other boots where resume was attempted and failed.
After the 17:27 hibernate, the first boot froze at the SDDM login screen and left nothing in the journal. The next boot also showed no -22. I don’t know whether the freeze is related.
My guess is that after the first resume, systemd no longer sets up the resume location, but I haven’t verified this.
What I tried: I only need one hibernate per boot, so a drop-in on systemd-hibernate.service aborts a second attempt using a marker file in /run. I haven’t tested this drop-in yet.
I haven’t tried resume= + resume_offset= on the kernel command line, and the ThinkPad P16s thread below suggests it may not be enough.
Questions
- Has anyone with Strix Halo or this ZBook seen the
platformhang, and is it known on 7.2.x? - What is the best way to capture where the power-off hangs? I was thinking of
pm_print_timeswithno_console_suspend. - Is the second-hibernate behaviour expected when using
HibernateLocationwithoutresume=, or is it a systemd bug? - How can I confirm whether the variable is written on the second hibernate?
Related
- ThinkPad P16 sleep and hibernation problems: no power-off, fixed with
HibernateMode=shutdown - Framework 12: ACPI S4 platform mode hangs after hibernate image write
- Hibernation intermittent black screen freeze on ThinkPad P16s Gen 5: also on 7.2.9, second resume fails, but with
resume=set and amdgpu timeouts - drm/amd #5379: linked from that thread as a similar issue
- Never resumes from hibernation, boots as if shut down
AI disclosure: I used Claude Code to analyse my system logs and config and to draft this post, including the guess in Symptom 2. I ran the hibernation tests and observed the hardware behaviour myself, and I reviewed the post before publishing.
