Hi, How can I install wiznote (which is note available in "add/remove software) and in general how to install my favorite apps in manjaro because in internet there is just tutorial for ubuntu!
with special thanks!
And happy new year 2021!
Wiznote is in the normal repos, so it can be installed for example by
sudo pacman -Syu wiznote
I usually use a GUI like pkgbrowser, octopi or pamac to check if packages are in Manjaro’s repos or in AUR. If packages are in Manjaro’s repos, then yes, they can be all installed analogous.
