~ wickrme ✔
Gtk-Message: 13:32:16.151: Failed to load module "xapp-gtk3-module"
Gtk-Message: 13:32:16.151: Failed to load module "canberra-gtk-module"
(WickrMe:4598): Gtk-WARNING **: 13:32:16.162: Theme parsing error: gtk.css:3536:25: 'font-feature-settings' is not a valid property name
Gtk-Message: 13:32:16.173: Failed to load module "colorreload-gtk-module"
Gtk-Message: 13:32:16.174: Failed to load module "window-decorations-gtk-module"
Fri Jul 8 13:32:16.188 Info: "Linux v5.106.6\r\nbuild 1"
Fri Jul 8 13:32:16.188 Info: Qt Version: 5.15.9
Fri Jul 8 13:32:16.188 Info: QLocale::system().name() "en_AG"
Fri Jul 8 13:32:16.188 Info: Application "WickrMe" for "Wickr, LLC"
Fri Jul 8 13:32:16.189 Info: SWITCHBOARD SERVICE: Started. Client Switchboard API Version = 2
Fri Jul 8 13:32:16.196 Warning: QObject::startTimer: Timers cannot have negative intervals
Fri Jul 8 13:32:16.196 Info: TASK SERVICE: Started.
Fri Jul 8 13:32:16.196 Info: MESSAGE SERVICE: Started.
Fri Jul 8 13:32:16.196 Info: SHREDDER SERVICE: Started.
Fri Jul 8 13:32:16.196 Info: FILE TRANSFER SERVICE: Started.
Fri Jul 8 13:32:16.196 Info: DIRECTORY SEARCH SERVICE: Started.
Fri Jul 8 13:32:16.196 Info: DATABASE SERVICE: Started.
Fri Jul 8 13:32:16.199 Info: SET EMAIL-AS-USERID = false
Fri Jul 8 13:32:16.203 Info: LOGGING SUBSYSTEM: Initialization, logging enabled = true
Fri Jul 8 13:32:16.203 Info: LOGGING SUBSYSTEM: Started { enabled = true , logging level = 1 , production = true }
Fri Jul 8 13:32:16.203 Info: Crash reporting started
Fri Jul 8 13:32:16.203 Info: PRODUCT LINE : MESSENGER
Fri Jul 8 13:32:16.203 Info: APPLICATION NAME : wickrme
Fri Jul 8 13:32:16.203 Info: VERSION : linux v5.106.6 build 1
Fri Jul 8 13:32:16.203 Info: NPL VERSION : v2.79.2.a1536e4d, 2022-05-20 12:33:29 -0400, tag 2.79.2, release build, Linux-x86_64, 12 cores, NPL OpenSSL:
Fri Jul 8 13:32:16.203 Info: DEVICE LOGIN: Forced Device Lockout is disabled.
Fri Jul 8 13:32:16.204 Info: Using SSL Library Version: "OpenSSL 1.1.1 11 Sep 2018"
Fri Jul 8 13:32:16.206 Info: SPELLCHECK LOCALE USED: "en_US"
Fri Jul 8 13:32:16.336 Info: DASHBOARD: Found camera device: "HD Webcam: HD Webcam"
Fri Jul 8 13:32:16.346 Info: DASHBOARD: Found audio input device: "default"
Fri Jul 8 13:32:16.346 Info: DASHBOARD: Found audio input device: "alsa_output.pci-0000_00_1f.3.analog-stereo.monitor"
Fontconfig warning: FcPattern object weight does not accept value [40 210)
zsh: segmentation fault (core dumped) wickrme
Any thoughts? Any help would be great. Trying my hardest now more then ever to get away from windows dependency.
Many thanks.
