i suddenly notice this output after updating my laptop… help me out pls
You have zsh running but it is not configured … it is attempting to prompt you to create the necessary configuration files.
Execute touch ~/.zshrc
and copy this content
# Source manjaro-zsh-configuration
if [[ -e /usr/share/zsh/manjaro-zsh-config ]]; then
source /usr/share/zsh/manjaro-zsh-config
fi
# Use manjaro zsh prompt
if [[ -e /usr/share/zsh/manjaro-zsh-prompt ]]; then
source /usr/share/zsh/manjaro-zsh-prompt
fi
And Restart your pc,
p.s.- I am not sure if this will work.
I use oh-my-zsh which has quite a few cool plugins and helps with the setup.
Give it a try if you want something automated.
You’ll still need to deal with the rest of your profile setup if you’ll do some development though (paths, aliases, etc)
