Hi.
Sometime in the recent past my number lock has stopped turning on automatically. The option is turned on in the KDE system settings but the setting has no effect. Here’s my system info. I’d appreciate any help on this issue. Thanks!
inxi -v7azy
Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=a8c0cc32-a321-4bc8-95a7-dc4103443512 rw quiet
resume=UUID=34818188-e359-4b02-86bd-53a0f3b237d2 udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: HP product: HP Elite Slice v: N/A
serial: <superuser required> Chassis: type: 15 serial: <superuser required>
Mobo: HP model: 81C3 v: KBC Version 05.77 serial: <superuser required>
UEFI: HP v: N25 Ver. 02.58 date: 07/28/2022
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K540e
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
RAM: total: 7.18 GiB used: 2.62 GiB (36.5%)
Info: model: Intel Core i5-6500T bits: 64 type: MCP arch: Skylake-S
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x5E (94) stepping: 3 microcode: 0xF0
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/3100 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 20004
dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp
hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc
tsc_adjust tsc_deadline_timer vme x2apic xgetbv1 xsave xsavec xsaveopt
xsaves xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 530 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
active: HDMI-A-2 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:1912 class-ID: 0300
Device-2: Logitech HD Webcam C510 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-11.1:5 chip-ID: 046d:081d class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-2 mapped: HDMI-2 model: Asus VG248 serial: <filter>
built: 2015 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 531x299mm (20.91x11.77") diag: 609mm (24") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel HD Graphics 530 (SKL
GT2) direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio
vendor: Hewlett-Packard driver: snd_hda_intel bus-ID: 1-11.1:5 v: kernel
chip-ID: 046d:081d bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0e02
serial: <filter> class-ID: 0403
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Intel Ethernet I219-LM vendor: Hewlett-Packard driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
IP v6: <filter> type: noprefixroute scope: global
Device-1: Broadcom Bluetooth Device type: USB driver: btusb v: 0.8
bus-ID: 1-11.4:6 chip-ID: 0a5c:2046 class-ID: fe01 serial: <filter>
Local Storage: total: 704.24 GiB used: 174.12 GiB (24.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 500GB SSD
type: SSD serial: <filter> rev: 0615 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Apacer model: Apricorn
size: 238.47 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 0132 scheme: GPT
ID-1: / raw-size: 456.66 GiB size: 448.43 GiB (98.20%)
used: 174.12 GiB (38.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: a8c0cc32-a321-4bc8-95a7-dc4103443512
ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%)
used: 164 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: EFI
uuid: A7C6-1687
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 34818188-e359-4b02-86bd-53a0f3b237d2
ID-1: /dev/sdb1 maj-min: 8:17 size: 260 MiB fs: vfat label: N/A
uuid: 10E9-1764
ID-2: /dev/sdb2 maj-min: 8:18 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sdb3 maj-min: 8:19 size: 238.1 GiB fs: ntfs label: Windows 10
uuid: 4E8E10218E10045D
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Device-2: 1-3:3 info: HP Slice Collaboration Cover type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 03f0:204a class-ID: 0300
Hub-2: 1-11:4 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2817 class-ID: 0900
Device-1: 1-11.1:5 info: Logitech HD Webcam C510 type: Audio,Video
power: 500mA chip-ID: 046d:081d class-ID: 0e02 serial: <filter>
Device-2: 1-11.4:6 info: Broadcom Bluetooth Device type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:2046
Device-3: 1-11.5:7 info: AnkerInnovations Anker USB-C Hub Device
type: Billboard driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 291a:8346 class-ID: 1100 serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
Device-1: 2-4:2 info: Apricorn type: Mass Storage driver: usb-storage
interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 8mA chip-ID: 0984:0301
class-ID: 0806 serial: <filter>
Hub-4: 2-6:3 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 2109:0817 class-ID: 0900
Device-1: 2-6.3:4 info: Norelsys NS1081 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 152mA
chip-ID: 2537:1081 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 40.0 C pch: 46.0 C mobo: N/A
Processes: 196 Uptime: 6m wakeups: 2 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1401 libs: 356 tools: pamac pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16
running-in: konsole inxi: 3.3.24
