Hello everyone, I need your help with something. I’m running a Lenovo Legion Y740-15ICHg (81HE) – inxi below – and it’s running hot. Doing office work, browsing the internet or just going through files in my system, my sensors report a temperature of anywhere from 55 to 62 °C. All that’s running at this point is Steam and Firefox, as far as foreground applications go.
Now, that’s not distressingly hot, but it is rather warm, considering nothing is really going on. I’ve tried several things to get the fan speeds under control, but everything seems to fail at some point:
sensors
does find a fan now, but I think I just tricked it into finding something, because it claims that it is a Thinkpad-related thing rather than a general Lenovo or Legion device, and there should be 2 fans rather than one, although it might be the case that they can’t be seperately controlled, so it can only find one controller:
thinkpad-isa-0000
Adapter: ISA adapter
fan1: 257 RPM
- thinkfan doesn’t seem to work, as it gave me weird errors about
hwmon
not being found - I tried the solution proffered here: Cant see my fan under sensors! fancontrol.service; disabled; vendor preset: disabled, alas this package “extremecooling4linux” told me that my laptop does not, in fact, support extreme cooling.
There has to be some sort thermal fan control going on, as my fans do start up, once I start an intensive game or something like that, but I still have the feeling that they don’t go full-throttle and my laptop’s warmer than it should be. I haven’t yet found a way to change how this fan control works and I’d be really grateful for some advice here, especially as this seems to be an issue very much related to my device rather than the OS or some piece of software.
Edit: Further testing revealed that the RPM output for fan1 by sensors
cannot be correct or at the very least it isn’t being updated. I started up a game and I could hear the fans speeding up and doing work, however, sensors
still reported them at 257 RPM, which just couldn’t be.
Something’s weird here.
Some outputs for your consideration:
$ sudo sensors-detect
# sensors-detect version 3.6.0+git
# System: LENOVO 81HE [Lenovo Legion Y740-15ICHg] (laptop)
# Board: LENOVO LNVNB161216
# Kernel: 5.10.105-1-MANJARO x86_64
# Processor: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz (6/158/10)
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you're doing.
Some south bridges, CPUs or memory controllers contain embedded sensors.
Do you want to scan for them? This is totally safe. (YES/no): yes
Silicon Integrated Systems SIS5595... No
VIA VT82C686 Integrated Sensors... No
VIA VT8231 Integrated Sensors... No
AMD K8 thermal sensors... No
AMD Family 10h thermal sensors... No
AMD Family 11h thermal sensors... No
AMD Family 12h and 14h thermal sensors... No
AMD Family 15h thermal sensors... No
AMD Family 16h thermal sensors... No
AMD Family 17h thermal sensors... No
AMD Family 15h power sensors... No
AMD Family 16h power sensors... No
Hygon Family 18h thermal sensors... No
AMD Family 19h thermal sensors... No
Intel digital thermal sensor... Success!
(driver `coretemp')
Intel AMB FB-DIMM thermal sensor... No
Intel 5500/5520/X58 thermal sensor... No
VIA C7 thermal sensor... No
VIA Nano thermal sensor... No
Some Super I/O chips contain embedded sensors. We have to write to
standard I/O ports to probe them. This is usually safe.
Do you want to scan for Super I/O sensors? (YES/no):
Probing for Super-I/O at 0x2e/0x2f
Trying family `National Semiconductor/ITE'... No
Trying family `SMSC'... No
Trying family `VIA/Winbond/Nuvoton/Fintek'... No
Trying family `ITE'... No
Probing for Super-I/O at 0x4e/0x4f
Some hardware monitoring chips are accessible through the ISA I/O ports.
We have to write to arbitrary I/O ports to probe them. This is usually
safe though. Yes, you do have ISA I/O ports even if you do not have any
ISA slots! Do you want to scan the ISA I/O ports? (YES/no):
Probing for `National Semiconductor LM78' at 0x290... No
Probing for `National Semiconductor LM79' at 0x290... No
Probing for `Winbond W83781D' at 0x290... No
Probing for `Winbond W83782D' at 0x290... No
Lastly, we can probe the I2C/SMBus adapters for connected hardware
monitoring devices. This is the most risky part, and while it works
reasonably well on most systems, it has been reported to cause trouble
on some systems.
Do you want to probe the I2C/SMBus adapters now? (YES/no):
Using driver `i2c-i801' for device 0000:00:1f.4: Cannon Lake-H (PCH)
Next adapter: NVIDIA GPU I2C adapter (i2c-0)
Do you want to scan it? (YES/no/selectively):
Next adapter: Synopsys DesignWare I2C adapter (i2c-1)
Adapter doesn't support all probing functions.
Some addresses won't be probed.
Client found at address 0x5c
Probing for `Analog Devices ADT7462'... No
Probing for `SMSC EMC1072'... No
Probing for `SMSC EMC1073'... No
Probing for `SMSC EMC1074'... No
Next adapter: Synopsys DesignWare I2C adapter (i2c-2)
Next adapter: SMBus I801 adapter at 5000 (i2c-3)
Client found at address 0x18
Probing for `Analog Devices ADM1021'... No
Probing for `Analog Devices ADM1021A/ADM1023'... No
Probing for `Maxim MAX1617'... No
Probing for `Maxim MAX1617A'... No
Probing for `Maxim MAX1668'... No
Probing for `Maxim MAX1805'... No
Probing for `Maxim MAX1989'... No
Probing for `Maxim MAX6655/MAX6656'... No
Probing for `TI THMC10'... No
Probing for `National Semiconductor LM84'... No
Probing for `Genesys Logic GL523SM'... No
Probing for `Onsemi MC1066'... No
Probing for `Maxim MAX1618'... No
Probing for `Maxim MAX1619'... No
Probing for `National Semiconductor LM82/LM83'... No
Probing for `Maxim MAX6654'... No
Probing for `Maxim MAX6690'... No
Probing for `Maxim MAX6680/MAX6681'... No
Probing for `Maxim MAX6695/MAX6696'... No
Probing for `Texas Instruments TMP400'... No
Probing for `Texas Instruments AMC6821'... No
Probing for `National Semiconductor LM95233'... No
Probing for `National Semiconductor LM95234'... No
Probing for `National Semiconductor LM95235'... No
Probing for `National Semiconductor LM95245'... No
Probing for `National Semiconductor LM64'... No
Probing for `SMSC EMC1047'... No
Probing for `SMSC EMC1402'... No
Probing for `SMSC EMC1403'... No
Probing for `SMSC EMC1404'... No
Probing for `ST STTS424'... No
Probing for `ST STTS424E'... No
Probing for `ST STTS2002'... No
Probing for `ST STTS3000'... No
Probing for `NXP SE97/SE97B'... No
Probing for `NXP SE98'... No
Probing for `Analog Devices ADT7408'... No
Probing for `IDT TS3000/TSE2002'... No
Probing for `IDT TSE2004'... No
Probing for `IDT TS3001'... No
Probing for `Maxim MAX6604'... No
Probing for `Microchip MCP9804'... No
Probing for `Microchip MCP9808'... No
Probing for `Microchip MCP98242'... No
Probing for `Microchip MCP98243'... No
Probing for `Microchip MCP98244'... No
Probing for `Microchip MCP9843'... No
Probing for `ON CAT6095/CAT34TS02'... No
Probing for `ON CAT34TS02C'... No
Probing for `ON CAT34TS04'... No
Probing for `Atmel AT30TS00'... No
Probing for `Giantec GT30TS00'... No
Client found at address 0x1a
Client found at address 0x50
Handled by driver `ee1004' (already loaded), chip type `ee1004'
(note: this is probably NOT a sensor chip!)
Client found at address 0x52
Probing for `Analog Devices ADM1033'... No
Probing for `Analog Devices ADM1034'... No
Probing for `SPD EEPROM'... Yes
(confidence 8, not a hardware monitoring chip)
Next adapter: NVIDIA i2c adapter 1 at 1:00.0 (i2c-4)
Do you want to scan it? (yes/NO/selectively):
Next adapter: NVIDIA i2c adapter 2 at 1:00.0 (i2c-5)
Next adapter: NVIDIA i2c adapter 3 at 1:00.0 (i2c-6)
Next adapter: NVIDIA i2c adapter 4 at 1:00.0 (i2c-7)
Next adapter: NVIDIA i2c adapter 5 at 1:00.0 (i2c-8)
Next adapter: NVIDIA i2c adapter 6 at 1:00.0 (i2c-9)
Next adapter: NVIDIA i2c adapter 7 at 1:00.0 (i2c-10)
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `coretemp':
* Chip `Intel digital thermal sensor' (confidence: 9)
Do you want to overwrite /etc/conf.d/lm_sensors? (YES/no):
$ sensors
hidpp_battery_1-hid-3-12
Adapter: HID adapter
in0: 3.96 V
iwlwifi_1-virtual-0
Adapter: Virtual device
temp1: +46.0°C
BAT1-acpi-0
Adapter: ACPI interface
in0: 12.90 V
thinkpad-isa-0000
fan1: 257 RPM
coretemp-isa-0000
Package id 0: +54.0°C (high = +100.0°C, crit = +100.0°C)
Core 0: +54.0°C (high = +100.0°C, crit = +100.0°C)
Core 1: +52.0°C (high = +100.0°C, crit = +100.0°C)
Core 2: +53.0°C (high = +100.0°C, crit = +100.0°C)
Core 3: +53.0°C (high = +100.0°C, crit = +100.0°C)
Core 4: +53.0°C (high = +100.0°C, crit = +100.0°C)
Core 5: +53.0°C (high = +100.0°C, crit = +100.0°C)
pch_cannonlake-virtual-0
temp1: +59.0°C
nvme-pci-3e00
Adapter: PCI adapter
Composite: +44.9°C (low = -5.2°C, high = +79.8°C)
(crit = +84.8°C)
$ full-system-info
Kernel: 5.10.105-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=628f24a1-5443-4159-99a5-4a1e4dfaa518 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.3 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 81HE v: Lenovo Legion Y740-15ICHg
serial: <superuser required> Chassis: type: 10 v: Lenovo Legion Y740-15ICHg
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN
serial: <superuser required> UEFI: LENOVO v: AVCN22WW(V1.12)
date: 07/20/2020
ID-1: BAT1 charge: 53.6 Wh (99.6%) condition: 53.8/57.0 Wh (94.3%)
volts: 12.9 min: 11.5 model: SMP L17M3PG2 type: Li-ion serial: <filter>
status: N/A cycles: 28
ID-2: hidpp_battery_1 charge: N/A condition: N/A volts: 4.0 min: N/A
model: Logitech G903 Wired/Wireless Gaming Mouse type: N/A serial: <filter>
status: discharging
RAM: total: 31.27 GiB used: 6.82 GiB (21.8%)
RAM Report:
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 800 min/max: 800/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 52815
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: NVIDIA TU106BM [GeForce RTX 2060 Mobile] vendor: Lenovo
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f51 class-ID: 0300
Device-2: Razer USA Kiyo Pro type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 6-1.1:3 chip-ID: 1532:0e05 class-ID: 0102
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: DP-4 size-res: N/A modes: N/A
Monitor-2: HDMI-0 pos: primary res: 2560x1440 hz: 144 dpi: 93
size: 697x392mm (27.44x15.43") diag: 800mm (31.48") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA 510.54
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
Device-2: NVIDIA TU106 High Definition Audio vendor: Lenovo
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: C-Media Q9-1 type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-5.4:11 chip-ID: 0d8c:0135 class-ID: 0300
Device-4: Razer USA Kiyo Pro type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.10.105-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi
vendor: Rivet Networks Killer Wireless-AC 1550i Wireless driver: iwlwifi
v: kernel bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 3f:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp63s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: ASIX AX88179 Gigabit Ethernet type: USB driver: ax88179_178a
bus-ID: 6-1.3:4 chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: enp61s0u1u3 state: down mac: <filter>
IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> scope: global
IP v6: <filter> scope: global
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:9 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.38 TiB used: 1.02 TiB (73.9%)
model: PC SN720 SDAPNTW-512G-1101 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 10130001 temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
type: SSD serial: <filter> rev: 033 scheme: GPT
ID-1: / raw-size: 204.8 GiB size: 200.59 GiB (97.94%)
used: 160.63 GiB (80.1%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 628f24a1-5443-4159-99a5-4a1e4dfaa518
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 29 MiB (11.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM_DRV uuid: D48E-60B3
ID-3: /mnt/8EC28FE8C28FD2BF raw-size: 475.69 GiB
size: 475.69 GiB (100.00%) used: 428.13 GiB (90.0%) fs: ntfs
dev: /dev/nvme0n1p3 maj-min: 259:3 label: Windows-SSD
uuid: 8EC28FE8C28FD2BF
ID-4: /mnt/Data raw-size: 726.7 GiB size: 714.29 GiB (98.29%)
used: 452.07 GiB (63.3%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: Data
uuid: 39551567-427b-4331-a647-794215db1966
ID-1: swap-1 type: file size: 8 GiB used: 15.5 MiB (0.2%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs
label: WINRE_DRV uuid: D28E90838E9061B1
ID-3: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-1:13 info: Logitech USB Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c539 class-ID: 0300
Device-2: 1-3:3 info: Cherry GmbH Keyboard type: Keyboard,Mouse
power: 500mA chip-ID: 046a:00dd class-ID: 0301
Device-3: 1-4:4 info: Integrated Express ITE Device(8910) type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 048d:c936 class-ID: 0301
Hub-2: 1-5:5 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2817 class-ID: 0900
Device-1: 1-5.2:8 info: Razer USA Goliathus Extended type: Mouse,Keyboard
driver: razeraccessory,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1532:0c02 class-ID: 0300
Hub-3: 1-5.3:10 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-5.4:11 info: C-Media Q9-1 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0135 class-ID: 0300
Device-2: 1-5.5:12 info: VIA Labs USB Billboard Device type: Billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
chip-ID: 2109:8888 class-ID: 1100 serial: <filter>
Device-3: 1-6:6
info: Integrated Express Corsair Gaming K95 RGB PLATINUM Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 048d:c935 class-ID: 0300
Device-4: 1-14:9 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-4: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-7: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-8: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-9: 6-1:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 2109:0817 class-ID: 0900
Device-1: 6-1.1:3 info: Razer USA Kiyo Pro type: Video,Audio
driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 3.2 speed: 5 Gb/s
power: 896mA chip-ID: 1532:0e05 class-ID: 0102
Device-2: 6-1.3:4 info: ASIX AX88179 Gigabit Ethernet type: Network
driver: ax88179_178a interfaces: 1 rev: 3.2 speed: 5 Gb/s power: 184mA
System Temperatures: cpu: 58.0 C pch: 60.0 C mobo: N/A gpu: nvidia
temp: 53 C
Fan Speeds (RPM): cpu: 257
Processes: 339 Uptime: 2h 9m wakeups: 8 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1698 pacman: 1694 lib: 462
flatpak: 0 snap: 4 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
