I have some of those buts was not sure how to find the others, however i assume that the key bindings will not give me the notifications, ie to tell me what brightness or sound volume I am at
Would you be able to also point me in the direction of how to do that please?
Here’s a list of apps (and their description) being used by the i3 community edtion:
local/artwork-i3 20190912-1 (i3-manjaro)
Wallpapers for manjaro-i3
local/conky-i3 20180507-1 (i3-manjaro)
Conkies for manjaro-i3 in grey, green, solarized or 'maia' colors
local/dmenu-manjaro 5.0-1 (i3-manjaro)
customized recency-aware dmenu for manjaro-i3 with xft- and mouse-support
local/i3-default-artwork 20190912-1 (i3-manjaro)
Default wallpaper and icons for manjaro-i3
local/i3-gaps 4.18.3-1 (i3)
A fork of i3wm tiling window manager with more features, including gaps
local/i3-help 20180110-1 (i3-manjaro)
help-files for manjaro-i3
local/i3-scripts 20200804-1
Scripts and wrappers for manjaro-i3
local/i3-scrot 2-2
simple screenshot script using scrot
local/i3exit 20200217-1 (i3-manjaro)
Systemd/OpenRC-compatible exit-script for i3, including 'blurlock'
local/i3lock 2.12-2 (i3)
Improved screenlocker based upon XCB and PAM
local/i3status-manjaro 2.13-3 (i3-manjaro)
customized status bar for manjaro-i3, dzen2 or xmobar
local/manjaro-i3-settings 20200919-1 (i3-manjaro)
Manjaro Linux i3 settings
local/nitrogen 1.6.1-3
Background browser and setter for X windows
local/dunst 1.5.0-1.0
Customizable and lightweight notification-daemon
local/dunstify 1.5.0-1.0
Notification sending tool included in dunst
Hope this helps.
As far as the keybindings go, maybe the gnome installation defaulted to a different layout. Also I’m not sure which of gnome’s configurations are being ‘imposed’ on i3 - maybe somebody else running gnome has got some idea…
