Help with HP Envy x360 15-ds000CTO Ryzen 7 3700U
I seem to be one of several people who recently picked up this HP Envy system with a Ryzen 7 3700U. In this thread, I outlined how I got the machine working by cobbling together various hints from others around the Internet.
I'm left in a state where the keyboard and touchpad don't work (I don't think power management does either), and I'm hoping somebody can help me. Here are my hardware details:
inxi -Fxxxza --no-host:
System:    Kernel: 5.1.21-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.1.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.1-x86_64 root=UUID=a58f2ccf-b9f2-45e8-a76f-103656a83220 rw quiet splash
           Desktop: KDE Plasma 5.16.4 tk: Qt 5.13.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Convertible System: HP product: HP ENVY x360 Convertible 15-ds0xxx v: N/A serial: <filter> Chassis: type: 31
           serial: <filter>
           Mobo: HP model: 85DD v: 40.33 serial: <filter> UEFI: AMI v: F.12 date: 07/24/2019
CPU:       Topology: Quad Core model: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen+
           family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108102 L1 cache: 384 KiB L2 cache: 2048 KiB
           L3 cache: 4096 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 36748
           Speed: 1223 MHz min/max: N/A Core speeds (MHz): 1: 1223 2: 1227 3: 1231 4: 1298 5: 1226 6: 1224 7: 1225 8: 1229
           Vulnerabilities: Type: l1tf status: Not affected
           Type: spectre_v1 mitigation: __user pointer sanitization
           Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Picasso vendor: Hewlett-Packard driver: amdgpu v: kernel bus ID: 04:00.0
           chip ID: 1002:15d8
           Display: x11 server: X.Org 1.20.5 driver: amdgpu FAILED: ati unloaded: modesetting alternate: fbdev,vesa
           compositor: kwin_x11 resolution: 1920x1080~60Hz
           OpenGL: renderer: AMD RAVEN (DRM 3.30.0 5.1.21-1-MANJARO LLVM 8.0.1) v: 4.5 Mesa 19.1.4 direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
           driver: snd_hda_intel v: kernel bus ID: 04:00.1 chip ID: 1002:15de
           Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Hewlett-Packard
           driver: N/A bus ID: 04:00.5 chip ID: 1022:15e2
           Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
           bus ID: 04:00.6 chip ID: 1022:15e3
           Sound Server: ALSA v: k5.1.21-1-MANJARO
Network:   Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: Hewlett-Packard driver: r8822be v: kernel
           port: f000 bus ID: 02:00.0 chip ID: 10ec:b822
Drives:    Local Storage: total: 953.87 GiB used: 17.08 GiB (1.8%)
           ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW010T8 size: 953.87 GiB block size: physical: 512 B logical: 512 B
           speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 002C scheme: GPT
Partition: ID-1: / raw size: 100.00 GiB size: 97.93 GiB (97.93%) used: 16.35 GiB (16.7%) fs: ext4 block size: 4096 B
           dev: /dev/nvme0n1p3
           ID-2: /home raw size: 805.96 GiB size: 792.31 GiB (98.31%) used: 567.4 MiB (0.1%) fs: ext4 block size: 4096 B
           dev: /dev/nvme0n1p5
           ID-3: /opt raw size: 15.71 GiB size: 15.40 GiB (98.03%) used: 172.8 MiB (1.1%) fs: ext4 block size: 4096 B
           dev: /dev/nvme0n1p4
           ID-4: swap-1 size: 32.00 GiB used: 0 KiB (0.0%) fs: swap swappiness: 60 (default) cache pressure: 100 (default)
           dev: /dev/nvme0n1p2
Sensors:   System Temperatures: cpu: 48.9 C mobo: N/A gpu: amdgpu temp: 48 C
Info:      Processes: 227 Uptime: 2m Memory: 13.67 GiB used: 886.1 MiB (6.3%) Init: systemd v: 242 Compilers: gcc: 9.1.0
           Shell: bash (sudo) v: 5.0.7 running in: konsole inxi: 3.0.35
libinput list-devices (note: a USB keyboard and mouse are attached to the system so I can do this:
Device:           HD-Audio Generic HDMI/DP,pcm=3
Kernel:           /dev/input/event1
Group:            1
Seat:             seat0, default
Capabilities:
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Middle emulation: n/a
Calibration:      n/a
Scroll methods:   none
Click methods:    none
Disable-w-typing: n/a
Accel profiles:   n/a
Rotation:         n/a
Device:           USB Keyboard
Kernel:           /dev/input/event5
Group:            2
Capabilities:     keyboard
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           USB Keyboard System Control
Kernel:           /dev/input/event6
Group:            2
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           USB Keyboard Consumer Control
Kernel:           /dev/input/event7
Group:            2
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           USB Keyboard Mouse
Kernel:           /dev/input/event8
Group:            2
Capabilities:     pointer
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      disabled
Nat.scrolling:    disabled
Middle emulation: disabled
Calibration:      n/a
Scroll methods:   button
Click methods:    none
Accel profiles:   flat *adaptive
Rotation:         n/a
Kernel:           /dev/input/event9
Group:            2
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           USB OPTICAL MOUSE
Kernel:           /dev/input/event10
Group:            3
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Calibration:      n/a
Click methods:    none
Rotation:         n/a
Device:           HP Wide Vision HD Camera: HP Wi
Kernel:           /dev/input/event4
Group:            4
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           HD-Audio Generic Mic
Kernel:           /dev/input/event2
Group:            1
Capabilities:
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           HD-Audio Generic Headphone
Kernel:           /dev/input/event3
Group:            1
Capabilities:
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
hwinfo --mouse (note: a USB mouse and keyboard are attached so I can do this):
37: USB 00.2: 10503 USB Mouse
  [Created at usb.122]
  Unique ID: FNCT.45J2aErgYu8
  Parent ID: 2UT6.d7FDLX76qXB
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3.2/1-3.2:1.2
  SysFS BusID: 1-3.2:1.2
  Hardware Class: mouse
  Model: "Holtek USB Keyboard"
  Hotplug: USB
  Vendor: usb 0x04d9 "Holtek Semiconductor, Inc."
  Device: usb 0x0132 "USB Keyboard"
  Revision: "1.10"
  Serial ID: "000000000008"
  Compatible to: int 0x0210 0x0023
  Driver: "usbhid"
  Driver Modules: "usbhid"
  Device File: /dev/input/mice (/dev/input/mouse0)
  Device Files: /dev/input/mice, /dev/input/mouse0, /dev/input/event8, /dev/input/by-path/pci-0000:04:00.3-usb-0:3.2:1.2-event-mouse, /dev/input/by-id/usb-04d9_USB_Keyboard_000000000008-if02-event-mouse, /dev/input/by-id/usb-04d9_USB_Keyboard_000000000008-if02-mouse, /dev/input/by-path/pci-0000:04:00.3-usb-0:3.2:1.2-mouse
  Device Number: char 13:63 (char 13:32)
  Speed: 12 Mbps
  Module Alias: "usb:v04D9p0132d0110dc00dsc00dp00ic03isc00ip00in02"
  Driver Info #0:
    Buttons: 3
    Wheels: 2
    XFree86 Protocol: explorerps/2
    GPM Protocol: exps2
  Config Status: cfg=new, avail=yes, need=no, active=unknown
  Attached to: #41 (Hub)
42: USB 00.0: 10503 USB Mouse
  Unique ID: n8KV.VqQxadZ7ky5
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3.3/1-3.3:1.0
  SysFS BusID: 1-3.3:1.0
  Model: "Pixart Imaging Optical Mouse"
  Hotplug: USB
  Vendor: usb 0x093a "Pixart Imaging, Inc."
  Device: usb 0x2521 "Optical Mouse"
  Revision: "1.00"
  Compatible to: int 0x0210 0x0045
  Driver: "usbhid"
  Device File: /dev/input/mice (/dev/input/mouse1)
  Device Files: /dev/input/mice, /dev/input/mouse1, /dev/input/event10, /dev/input/by-path/pci-0000:04:00.3-usb-0:3.3:1.0-event-mouse, /dev/input/by-id/usb-093a_USB_OPTICAL_MOUSE-event-mouse, /dev/input/by-id/usb-093a_USB_OPTICAL_MOUSE-mouse, /dev/input/by-path/pci-0000:04:00.3-usb-0:3.3:1.0-mouse
  Device Number: char 13:63 (char 13:33)
  Speed: 1.5 Mbps
  Module Alias: "usb:v093Ap2521d0100dc00dsc00dp00ic03isc01ip02in00"
  Driver Info #0:
    Buttons: 5
    Wheels: 4
    GPM Protocol: exps2
lspci -v:
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Root Complex
        Subsystem: Hewlett-Packard Company Raven/Raven2 Root Complex
        Flags: fast devsel
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 IOMMU
        Subsystem: Hewlett-Packard Company Raven/Raven2 IOMMU
        Flags: bus master, fast devsel, latency 0, IRQ 24
        Capabilities: [40] Secure device <?>
        Capabilities: [64] MSI: Enable+ Count=1/4 Maskable- 64bit+
        Capabilities: [74] HyperTransport: MSI Mapping Enable+ Fixed+
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
        Flags: fast devsel
00:01.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0] (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 25
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
        I/O behind bridge: 00001000-00001fff [size=4K]
        Memory behind bridge: fe700000-fe7fffff [size=1M]
        Prefetchable memory behind bridge: 0000000420000000-00000004201fffff [size=2M]
        Capabilities: [50] Power Management version 3
        Capabilities: [58] Express Root Port (Slot+), MSI 00
        Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Capabilities: [c0] Subsystem: Hewlett-Packard Company Raven/Raven2 PCIe GPP Bridge [6:0]
        Capabilities: [c8] HyperTransport: MSI Mapping Enable+ Fixed+
        Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
        Capabilities: [150] Advanced Error Reporting
        Capabilities: [270] Secondary PCI Express <?>
        Capabilities: [2a0] Access Control Services
        Capabilities: [370] L1 PM Substates
        Kernel driver in use: pcieport
00:01.5 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0] (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 26
        Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
        I/O behind bridge: 0000f000-0000ffff [size=4K]
        Memory behind bridge: fe600000-fe6fffff [size=1M]
        Prefetchable memory behind bridge: None
00:01.7 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0] (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 27
        Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
        I/O behind bridge: 00002000-00002fff [size=4K]
        Memory behind bridge: fe500000-fe5fffff [size=1M]
        Prefetchable memory behind bridge: 0000000420200000-00000004203fffff [size=2M]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
        Flags: fast devsel
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus A (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 28
        Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
        I/O behind bridge: 0000e000-0000efff [size=4K]
        Memory behind bridge: fe000000-fe4fffff [size=5M]
        Prefetchable memory behind bridge: 00000000e0000000-00000000f01fffff [size=258M]
        Capabilities: [58] Express Root Port (Slot-), MSI 00
        Capabilities: [c0] Subsystem: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus A
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
        Subsystem: Hewlett-Packard Company FCH SMBus Controller
        Flags: 66MHz, medium devsel
        Kernel driver in use: piix4_smbus
        Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
        Subsystem: Hewlett-Packard Company FCH LPC Bridge
        Flags: bus master, 66MHz, medium devsel, latency 0
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 0
        Flags: fast devsel
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 1
        Flags: fast devsel
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 2
        Flags: fast devsel
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 3
        Flags: fast devsel
        Kernel driver in use: k10temp
        Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 4
        Flags: fast devsel
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 5
        Flags: fast devsel
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 6
        Flags: fast devsel
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 7
        Flags: fast devsel
01:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS522A PCI Express Card Reader (rev 01)
        DeviceName: Realtek PCIE CardReader
        Subsystem: Hewlett-Packard Company RTS522A PCI Express Card Reader
        Physical Slot: 0
        Flags: bus master, fast devsel, latency 0, IRQ 38
        Memory at fe700000 (32-bit, non-prefetchable) [size=4K]
        Capabilities: [40] Power Management version 3
        Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Capabilities: [70] Express Endpoint, MSI 00
        Capabilities: [100] Advanced Error Reporting
        Capabilities: [140] Device Serial Number 00-00-00-01-00-4c-e0-00
        Capabilities: [150] Latency Tolerance Reporting
        Capabilities: [158] L1 PM Substates
        Kernel driver in use: rtsx_pci
        Kernel modules: rtsx_pci
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822BE 802.11a/b/g/n/ac WiFi adapter
        DeviceName: Realtek RTL8822BE 802.11 ac 2x2 WiFi + BT 4.2 Combo Adapter (MU-MIMO supported)
        Subsystem: Hewlett-Packard Company RTL8822BE 802.11a/b/g/n/ac WiFi adapter
        Flags: bus master, fast devsel, latency 0, IRQ 57
        I/O ports at f000 [size=256]
        Memory at fe600000 (64-bit, non-prefetchable) [size=64K]
        Capabilities: [148] Device Serial Number 00-e0-4c-ff-fe-b8-22-01
        Capabilities: [158] Latency Tolerance Reporting
        Capabilities: [160] L1 PM Substates
        Kernel driver in use: r8822be
        Kernel modules: r8822be
03:00.0 Non-Volatile memory controller: Intel Corporation SSDPEKNW020T8 [660p, 2TB] (rev 03) (prog-if 02 [NVM Express])
        Subsystem: Intel Corporation SSDPEKNW020T8 [660p, 2TB]
        Physical Slot: 0-1
        Flags: bus master, fast devsel, latency 0, IRQ 10, NUMA node 0
        Memory at fe500000 (64-bit, non-prefetchable) [size=16K]
        Capabilities: [50] MSI: Enable- Count=1/8 Maskable+ 64bit+
        Capabilities: [b0] MSI-X: Enable+ Count=16 Masked-
        Capabilities: [158] Secondary PCI Express <?>
        Capabilities: [178] Latency Tolerance Reporting
        Capabilities: [180] L1 PM Substates
        Kernel driver in use: nvme
04:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Picasso (rev c1) (prog-if 00 [VGA controller])
        Subsystem: Hewlett-Packard Company Picasso
        Flags: bus master, fast devsel, latency 0, IRQ 58
        Memory at e0000000 (64-bit, prefetchable) [size=256M]
        Memory at f0000000 (64-bit, prefetchable) [size=2M]
        I/O ports at e000 [size=256]
        Memory at fe400000 (32-bit, non-prefetchable) [size=512K]
        [virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
        Capabilities: [48] Vendor Specific Information: Len=08 <?>
        Capabilities: [64] Express Legacy Endpoint, MSI 00
        Capabilities: [a0] MSI: Enable+ Count=1/4 Maskable- 64bit+
        Capabilities: [c0] MSI-X: Enable- Count=3 Masked-
        Capabilities: [200] Resizable BAR <?>
        Capabilities: [2b0] Address Translation Service (ATS)
        Capabilities: [2c0] Page Request Interface (PRI)
        Capabilities: [2d0] Process Address Space ID (PASID)
        Capabilities: [320] Latency Tolerance Reporting
        Kernel driver in use: amdgpu
        Kernel modules: amdgpu
04:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio Controller
        Subsystem: Hewlett-Packard Company Raven/Raven2/Fenghuang HDMI/DP Audio Controller
        Flags: bus master, fast devsel, latency 0, IRQ 55
        Memory at fe4c8000 (32-bit, non-prefetchable) [size=16K]
        Kernel driver in use: snd_hda_intel
        Kernel modules: snd_hda_intel
04:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
        Subsystem: Hewlett-Packard Company Family 17h (Models 10h-1fh) Platform Security Processor
        Flags: bus master, fast devsel, latency 0, IRQ 4
        Memory at fe300000 (32-bit, non-prefetchable) [size=1M]
        Memory at fe4ce000 (32-bit, non-prefetchable) [size=8K]
        Capabilities: [64] Express Endpoint, MSI 00
        Capabilities: [a0] MSI: Enable- Count=1/2 Maskable- 64bit+
        Capabilities: [c0] MSI-X: Enable- Count=2 Masked-
04:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Raven USB 3.1 (prog-if 30 [XHCI])
        Subsystem: Hewlett-Packard Company Raven USB 3.1
        Flags: bus master, fast devsel, latency 0, IRQ 11
        Memory at fe200000 (64-bit, non-prefetchable) [size=1M]
        Capabilities: [a0] MSI: Enable- Count=1/8 Maskable- 64bit+
        Capabilities: [c0] MSI-X: Enable+ Count=8 Masked-
        Kernel driver in use: xhci_hcd
        Kernel modules: xhci_pci
04:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Raven USB 3.1 (prog-if 30 [XHCI])
        Memory at fe100000 (64-bit, non-prefetchable) [size=1M]
04:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor
        Subsystem: Hewlett-Packard Company Raven/Raven2/FireFlight/Renoir Audio Processor
        Flags: fast devsel, IRQ 5
        Memory at fe480000 (32-bit, non-prefetchable) [size=256K]
        Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit+
        Kernel modules: snd_pci_acp3x
04:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller
        DeviceName: HD Audio Controller
        Subsystem: Hewlett-Packard Company Family 17h (Models 10h-1fh) HD Audio Controller
        Flags: bus master, fast devsel, latency 0, IRQ 56
        Memory at fe4c0000 (32-bit, non-prefetchable) [size=32K]
04:00.7 Non-VGA unclassified device: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/Renoir Sensor Fusion Hub
        Subsystem: Hewlett-Packard Company Raven/Raven2/Renoir Sensor Fusion Hub
        Memory at fe000000 (32-bit, non-prefetchable) [size=1M]
        Memory at fe4cc000 (32-bit, non-prefetchable) [size=8K]
cat /var/log/Xorg.0.log:
[     2.884] (--) Log file renamed from "/var/log/Xorg.pid-700.log" to "/var/log/Xorg.0.log"
[     2.884]
X.Org X Server 1.20.5
[     2.885] Build Operating System: Linux Arch Linux
[     2.885] Current Operating System: Linux enterprise-e 5.1.21-1-MANJARO #1 SMP PREEMPT Sun Jul 28 09:33:43 UTC 2019 x86_64
[     2.885] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.1-x86_64 root=UUID=a58f2ccf-b9f2-45e8-a76f-103656a83220 rw quiet splash
[     2.885] Build Date: 30 June 2019  09:52:01AM
[     2.885]
[     2.885] Current version of pixman: 0.38.4
[     2.885]    Before reporting problems, check http://wiki.x.org
[     2.885] Markers: (--) probed, (**) from config file, (==) default setting,
[     2.885] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Aug 14 18:48:50 2019
[     2.886] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     2.886] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     2.887] (==) No Layout section.  Using the first Screen section.
[     2.887] (==) No screen section available. Using defaults.
[     2.887] (**) |-->Screen "Default Screen Section" (0)
[     2.887] (**) |   |-->Monitor "<default monitor>"
[     2.887] (==) No monitor specified for screen "Default Screen Section".
[     2.887] (==) Automatically adding devices
[     2.887] (==) Automatically enabling devices
[     2.887] (==) Automatically adding GPU devices
[     2.887] (==) Automatically binding GPU devices
[     2.887] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     2.889] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     2.889]    Entry deleted from font path.
[     2.889] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[     2.889]    (Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[     2.889] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[     2.889]    (Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[     2.889] (==) FontPath set to:
        /usr/share/fonts/misc,
        /usr/share/fonts/TTF,
        /usr/share/fonts/OTF
[     2.889] (==) ModulePath set to "/usr/lib/xorg/modules"
[     2.889] (II) The server relies on udev to provide the list of input devices.
[     2.889] (II) Module ABI versions:
[     2.889]    X.Org ANSI C Emulation: 0.4
[     2.889]    X.Org Video Driver: 24.0
[     2.889]    X.Org XInput driver : 24.1
[     2.889]    X.Org Server Extension : 10.0
[     2.889] (++) using VT number 1
[     2.889] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     2.890] (II) xfree86: Adding drm device (/dev/dri/card0)
[     2.894] (--) PCI:*(4@0:0:0) 1002:15d8:103c:85dd rev 193, Mem @ 0xe0000000/268435456, 0xf0000000/2097152, 0xfe400000/524288, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[     2.894] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     2.894] (II) LoadModule: "glx"
[     2.896] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     2.904] (II) Module glx: vendor="X.Org Foundation"
[     2.904]    compiled for 1.20.5, module version = 1.0.0
[     2.904]    ABI class: X.Org Server Extension, version 10.0
[     2.904] (II) Applying OutputClass "AMDgpu" to /dev/dri/card0
[     2.904]    loading driver: amdgpu
[     2.904] (==) Matched amdgpu as autoconfigured driver 0
[     2.904] (==) Matched ati as autoconfigured driver 1
[     2.904] (==) Matched modesetting as autoconfigured driver 2
[     2.904] (==) Matched fbdev as autoconfigured driver 3
[     2.904] (==) Matched vesa as autoconfigured driver 4
[     2.904] (==) Assigned the driver to the xf86ConfigLayout
[     2.904] (II) LoadModule: "amdgpu"
[     2.904] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[     2.907] (II) Module amdgpu: vendor="X.Org Foundation"
[     2.907]    compiled for 1.20.4, module version = 19.0.1
[     2.907]    Module class: X.Org Video Driver
[     2.907]    ABI class: X.Org Video Driver, version 24.0
[     2.907] (II) LoadModule: "ati"
[     2.907] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[     2.907] (II) Module ati: vendor="X.Org Foundation"
[     2.908] (II) LoadModule: "modesetting"
[     2.908] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     2.908] (II) Module modesetting: vendor="X.Org Foundation"
[     2.908]    compiled for 1.20.5, module version = 1.20.5
[     2.908]    Module class: X.Org Video Driver
[     2.908]    ABI class: X.Org Video Driver, version 24.0
[     2.909] (II) LoadModule: "fbdev"
[     2.909] (WW) Warning, couldn't open module fbdev
[     2.909] (EE) Failed to load module "fbdev" (module does not exist, 0)
[     2.909] (II) LoadModule: "vesa"
[     2.909] (WW) Warning, couldn't open module vesa
[     2.909] (EE) Failed to load module "vesa" (module does not exist, 0)
[     2.909] (II) AMDGPU: Driver for AMD Radeon:
        All GPUs supported by the amdgpu kernel driver
[     2.909] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     2.909] (II) AMDGPU(0): [KMS] Kernel modesetting enabled.
[     2.909] (WW) Falling back to old probe method for modesetting
[     2.909] (II) AMDGPU(0): Creating default Display subsection in Screen section
        "Default Screen Section" for depth/fbbpp 24/32
[     2.909] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[     2.909] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[     2.909] (==) AMDGPU(0): Default visual is TrueColor
[     2.909] (==) AMDGPU(0): RGB weight 888
[     2.909] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[     2.909] (--) AMDGPU(0): Chipset: "Unknown AMD Radeon GPU" (ChipID = 0x15d8)
[     2.909] (II) Loading sub module "fb"
[     2.909] (II) LoadModule: "fb"
[     2.910] (II) Loading /usr/lib/xorg/modules/libfb.so
[     2.910] (II) Module fb: vendor="X.Org Foundation"
[     2.910]    compiled for 1.20.5, module version = 1.0.0
[     2.910]    ABI class: X.Org ANSI C Emulation, version 0.4
[     2.910] (II) Loading sub module "dri2"
[     2.910] (II) LoadModule: "dri2"
[     2.910] (II) Module "dri2" already built-in
[     3.071] (II) Loading sub module "glamoregl"
[     3.071] (II) LoadModule: "glamoregl"
[     3.071] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[     3.076] (II) Module glamoregl: vendor="X.Org Foundation"
[     3.076]    compiled for 1.20.5, module version = 1.0.1
[     3.076]    ABI class: X.Org ANSI C Emulation, version 0.4
[     3.093] (II) AMDGPU(0): glamor X acceleration enabled on AMD RAVEN (DRM 3.30.0, 5.1.21-1-MANJARO, LLVM 8.0.1)
[     3.093] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[     3.093] (==) AMDGPU(0): TearFree property default: auto
[     3.093] (==) AMDGPU(0): VariableRefresh: disabled
[     3.093] (II) AMDGPU(0): KMS Pageflipping: enabled
[     3.093] (II) AMDGPU(0): Output eDP has no monitor section
[     3.093] (II) AMDGPU(0): Output HDMI-A-0 has no monitor section
[     3.093] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[     3.095] (II) AMDGPU(0): EDID for output eDP
[     3.095] (II) AMDGPU(0): Manufacturer: AUO  Model: 23ed  Serial#: 0
[     3.095] (II) AMDGPU(0): Year: 2018  Week: 0
[     3.095] (II) AMDGPU(0): EDID Version: 1.4
[     3.095] (II) AMDGPU(0): Digital Display Input
[     3.095] (II) AMDGPU(0): 6 bits per channel
[     3.095] (II) AMDGPU(0): Digital interface is DisplayPort
[     3.095] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 34  vert.: 19
[     3.095] (II) AMDGPU(0): Gamma: 2.20
[     3.095] (II) AMDGPU(0): No DPMS capabilities specified
[     3.095] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4
[     3.095] (II) AMDGPU(0): First detailed timing is preferred mode
[     3.095] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[     3.095] (II) AMDGPU(0): Display is continuous-frequency
[     3.095] (II) AMDGPU(0): redX: 0.575 redY: 0.346   greenX: 0.347 greenY: 0.572
[     3.095] (II) AMDGPU(0): blueX: 0.158 blueY: 0.117   whiteX: 0.313 whiteY: 0.329
[     3.095] (II) AMDGPU(0): Manufacturer's mask: 0
[     3.095] (II) AMDGPU(0): Supported detailed timing:
[     3.095] (II) AMDGPU(0): clock: 141.0 MHz   Image Size:  344 x 194 mm
[     3.095] (II) AMDGPU(0): h_active: 1920  h_sync: 2028  h_sync_end 2076 h_blank_end 2100 h_border: 0
[     3.095] (II) AMDGPU(0): v_active: 1080  v_sync: 1090  v_sync_end 1100 v_blanking: 1118 v_border: 0
[     3.095] (II) AMDGPU(0): clock: 94.0 MHz   Image Size:  344 x 194 mm
[     3.095] (II) AMDGPU(0): Unknown vendor-specific block 2
[     3.095] (II) AMDGPU(0): EDID (in hex):
[     3.095] (II) AMDGPU(0):    00ffffffffffff0006afed2300000000
[     3.095] (II) AMDGPU(0):    001c010495221378036e859358589228
[     3.095] (II) AMDGPU(0):    1e505400000001010101010101010101
[     3.095] (II) AMDGPU(0):    010101010101143780b4703826406c30
[     3.095] (II) AMDGPU(0):    aa0058c210000018b82480b470382640
[     3.095] (II) AMDGPU(0):    6c30aa0058c210000018000000000000
[     3.095] (II) AMDGPU(0):    00000000000000000000000000000002
[     3.095] (II) AMDGPU(0):    001048ff0f3c6e0f16286e2020200031
[     3.095] (II) AMDGPU(0): Printing probed modes for output eDP
[     3.095] (II) AMDGPU(0): Modeline "1920x1080"x60.1  141.00  1920 2028 2076 2100  1080 1090 1100 1118 -hsync -vsync (67.1 kHz eP)
[     3.095] (II) AMDGPU(0): Modeline "1920x1080"x40.0   94.00  1920 2028 2076 2100  1080 1090 1100 1118 -hsync -vsync (44.8 kHz e)
[     3.095] (II) AMDGPU(0): Modeline "1680x1050"x60.1  141.00  1680 2028 2076 2100  1050 1090 1100 1118 -hsync -vsync (67.1 kHz e)
[     3.095] (II) AMDGPU(0): Modeline "1280x1024"x60.1  141.00  1280 2028 2076 2100  1024 1090 1100 1118 -hsync -vsync (67.1 kHz e)
[     3.095] (II) AMDGPU(0): Modeline "1440x900"x60.1  141.00  1440 2028 2076 2100  900 1090 1100 1118 -hsync -vsync (67.1 kHz e)
[     3.095] (II) AMDGPU(0): Modeline "1280x800"x60.1  141.00  1280 2028 2076 2100  800 1090 1100 1118 -hsync -vsync (67.1 kHz e)
[     3.095] (II) AMDGPU(0): Modeline "1280x720"x60.1  141.00  1280 2028 2076 2100  720 1090 1100 1118 -hsync -vsync (67.1 kHz e)
[     3.095] (II) AMDGPU(0): Modeline "1024x768"x60.1  141.00  1024 2028 2076 2100  768 1090 1100 1118 -hsync -vsync (67.1 kHz e)
[     3.095] (II) AMDGPU(0): Modeline "800x600"x60.1  141.00  800 2028 2076 2100  600 1090 1100 1118 -hsync -vsync (67.1 kHz e)
[     3.095] (II) AMDGPU(0): Modeline "640x480"x60.1  141.00  640 2028 2076 2100  480 1090 1100 1118 -hsync -vsync (67.1 kHz e)
[     3.095] (II) AMDGPU(0): EDID for output HDMI-A-0
[     3.095] (II) AMDGPU(0): EDID for output DisplayPort-0
[     3.095] (II) AMDGPU(0): Output eDP connected
[     3.095] (II) AMDGPU(0): Output HDMI-A-0 disconnected
[     3.095] (II) AMDGPU(0): Output DisplayPort-0 disconnected
[     3.095] (II) AMDGPU(0): Using exact sizes for initial modes
[     3.095] (II) AMDGPU(0): Output eDP using initial mode 1920x1080 +0+0
[     3.095] (II) AMDGPU(0): mem size init: gart size :bf7d0000 vram size: s:7e852000 visible:7e852000
[     3.095] (==) AMDGPU(0): DPI set to (96, 96)
[     3.095] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[     3.095] (II) Loading sub module "ramdac"
[     3.095] (II) LoadModule: "ramdac"
[     3.095] (II) Module "ramdac" already built-in
[     3.095] (II) UnloadModule: "modesetting"
[     3.095] (II) Unloading modesetting
[     3.095] (II) AMDGPU(0): [DRI2] Setup complete
[     3.095] (II) AMDGPU(0): [DRI2]   DRI driver: radeonsi
[     3.095] (II) AMDGPU(0): [DRI2]   VDPAU driver: radeonsi
[     3.095] (II) AMDGPU(0): Front buffer pitch: 7680 bytes
[     3.096] (II) AMDGPU(0): SYNC extension fences enabled
[     3.096] (II) AMDGPU(0): Present extension enabled
[     3.096] (==) AMDGPU(0): DRI3 enabled
[     3.096] (==) AMDGPU(0): Backing store enabled
[     3.096] (II) AMDGPU(0): Direct rendering enabled
[     3.100] (II) AMDGPU(0): Use GLAMOR acceleration.
[     3.100] (II) AMDGPU(0): Acceleration enabled
[     3.100] (==) AMDGPU(0): DPMS enabled
[     3.100] (==) AMDGPU(0): Silken mouse disabled
[     3.100] (II) AMDGPU(0): Set up textured video (glamor)
[     3.105] (II) Initializing extension Generic Event Extension
[     3.105] (II) Initializing extension SHAPE
[     3.105] (II) Initializing extension MIT-SHM
[     3.105] (II) Initializing extension XInputExtension
[     3.105] (II) Initializing extension XTEST
[     3.105] (II) Initializing extension BIG-REQUESTS
[     3.106] (II) Initializing extension SYNC
[     3.106] (II) Initializing extension XKEYBOARD
[     3.106] (II) Initializing extension XC-MISC
[     3.106] (II) Initializing extension SECURITY
[     3.106] (II) Initializing extension XFIXES
[     3.106] (II) Initializing extension RENDER
[     3.106] (II) Initializing extension RANDR
[     3.106] (II) Initializing extension COMPOSITE
[     3.106] (II) Initializing extension DAMAGE
[     3.106] (II) Initializing extension MIT-SCREEN-SAVER
[     3.106] (II) Initializing extension DOUBLE-BUFFER
[     3.106] (II) Initializing extension RECORD
[     3.106] (II) Initializing extension DPMS
[     3.106] (II) Initializing extension Present
[     3.106] (II) Initializing extension DRI3
[     3.107] (II) Initializing extension X-Resource
[     3.107] (II) Initializing extension XVideo
[     3.107] (II) Initializing extension XVideo-MotionCompensation
[     3.107] (II) Initializing extension GLX
[     3.110] (II) AIGLX: Loaded and initialized radeonsi
[     3.110] (II) GLX: Initialized DRI2 GL provider for screen 0
[     3.110] (II) Initializing extension XFree86-VidModeExtension
[     3.110] (II) Initializing extension XFree86-DGA
[     3.110] (II) Initializing extension XFree86-DRI
[     3.110] (II) Initializing extension DRI2
[     3.112] (II) AMDGPU(0): Setting screen physical size to 508 x 285
[     3.204] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=3 (/dev/input/event1)
[     3.204] (II) No input driver specified, ignoring this device.
[     3.204] (II) This device may have been added with another device file.
[     3.204] (II) config/udev: Adding input device USB Keyboard (/dev/input/event5)
[     3.204] (**) USB Keyboard: Applying InputClass "evdev keyboard catchall"
[     3.204] (**) USB Keyboard: Applying InputClass "libinput keyboard catchall"
[     3.204] (**) USB Keyboard: Applying InputClass "system-keyboard"
[     3.204] (II) LoadModule: "libinput"
[     3.205] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     3.208] (II) Module libinput: vendor="X.Org Foundation"
[     3.208]    compiled for 1.20.3, module version = 0.28.2
[     3.208]    Module class: X.Org XInput Driver
[     3.208]    ABI class: X.Org XInput driver, version 24.1
[     3.208] (II) Using input driver 'libinput' for 'USB Keyboard'
[     3.208] (**) USB Keyboard: always reports core events
[     3.208] (**) Option "Device" "/dev/input/event5"
[     3.208] (**) Option "_source" "server/udev"
[     3.213] (II) event5  - USB Keyboard: is tagged by udev as: Keyboard
[     3.213] (II) event5  - USB Keyboard: device is a keyboard
[     3.213] (II) event5  - USB Keyboard: device removed
[     3.257] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3.2/1-3.2:1.0/0003:04D9:0132.0001/input/input5/event5"
[     3.257] (II) XINPUT: Adding extended input device "USB Keyboard" (type: KEYBOARD, id 6)
[     3.257] (**) Option "xkb_model" "pc105"
[     3.257] (**) Option "xkb_layout" "us"
[     3.259] (II) event5  - USB Keyboard: is tagged by udev as: Keyboard
[     3.259] (II) event5  - USB Keyboard: device is a keyboard
[     3.259] (II) config/udev: Adding input device USB Keyboard System Control (/dev/input/event6)
[     3.259] (**) USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[     3.259] (**) USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[     3.259] (**) USB Keyboard System Control: Applying InputClass "system-keyboard"
[     3.260] (II) Using input driver 'libinput' for 'USB Keyboard System Control'
[     3.260] (**) USB Keyboard System Control: always reports core events
[     3.260] (**) Option "Device" "/dev/input/event6"
[     3.260] (**) Option "_source" "server/udev"
[     3.261] (II) event6  - USB Keyboard System Control: is tagged by udev as: Keyboard
[     3.261] (II) event6  - USB Keyboard System Control: device is a keyboard
[     3.261] (II) event6  - USB Keyboard System Control: device removed
[     3.284] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3.2/1-3.2:1.2/0003:04D9:0132.0003/input/input6/event6"
[     3.284] (II) XINPUT: Adding extended input device "USB Keyboard System Control" (type: KEYBOARD, id 7)
[     3.284] (**) Option "xkb_model" "pc105"
[     3.284] (**) Option "xkb_layout" "us"
[     3.285] (II) event6  - USB Keyboard System Control: is tagged by udev as: Keyboard
[     3.285] (II) event6  - USB Keyboard System Control: device is a keyboard
[     3.286] (II) config/udev: Adding input device USB Keyboard Consumer Control (/dev/input/event7)
[     3.286] (**) USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[     3.286] (**) USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[     3.286] (**) USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[     3.286] (II) Using input driver 'libinput' for 'USB Keyboard Consumer Control'
[     3.286] (**) USB Keyboard Consumer Control: always reports core events
[     3.286] (**) Option "Device" "/dev/input/event7"
[     3.286] (**) Option "_source" "server/udev"
[     3.287] (II) event7  - USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[     3.287] (II) event7  - USB Keyboard Consumer Control: device is a keyboard
[     3.287] (II) event7  - USB Keyboard Consumer Control: device removed
[     3.377] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3.2/1-3.2:1.2/0003:04D9:0132.0003/input/input7/event7"
[     3.377] (II) XINPUT: Adding extended input device "USB Keyboard Consumer Control" (type: KEYBOARD, id 8)
[     3.377] (**) Option "xkb_model" "pc105"
[     3.377] (**) Option "xkb_layout" "us"
[     3.379] (II) event7  - USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[     3.379] (II) event7  - USB Keyboard Consumer Control: device is a keyboard
[     3.379] (II) config/udev: Adding input device USB Keyboard Mouse (/dev/input/event8)
[     3.379] (**) USB Keyboard Mouse: Applying InputClass "evdev pointer catchall"
[     3.379] (**) USB Keyboard Mouse: Applying InputClass "libinput pointer catchall"
[     3.379] (II) Using input driver 'libinput' for 'USB Keyboard Mouse'
[     3.379] (**) USB Keyboard Mouse: always reports core events
[     3.379] (**) Option "Device" "/dev/input/event8"
[     3.379] (**) Option "_source" "server/udev"
[     3.381] (II) event8  - USB Keyboard Mouse: is tagged by udev as: Mouse
[     3.381] (II) event8  - USB Keyboard Mouse: device is a pointer
[     3.381] (II) event8  - USB Keyboard Mouse: device removed
[     3.457] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3.2/1-3.2:1.2/0003:04D9:0132.0003/input/input8/event8"
[     3.457] (II) XINPUT: Adding extended input device "USB Keyboard Mouse" (type: MOUSE, id 9)
[     3.457] (**) Option "AccelerationScheme" "none"
[     3.457] (**) USB Keyboard Mouse: (accel) selected scheme none/0
[     3.457] (**) USB Keyboard Mouse: (accel) acceleration factor: 2.000
[     3.457] (**) USB Keyboard Mouse: (accel) acceleration threshold: 4
[     3.458] (II) event8  - USB Keyboard Mouse: is tagged by udev as: Mouse
[     3.458] (II) event8  - USB Keyboard Mouse: device is a pointer
[     3.459] (II) config/udev: Adding input device USB Keyboard Mouse (/dev/input/mouse0)
[     3.459] (II) No input driver specified, ignoring this device.
[     3.459] (II) This device may have been added with another device file.
[     3.459] (II) config/udev: Adding input device USB Keyboard (/dev/input/event9)
[     3.459] (**) USB Keyboard: Applying InputClass "evdev keyboard catchall"
[     3.459] (**) USB Keyboard: Applying InputClass "libinput keyboard catchall"
[     3.459] (**) USB Keyboard: Applying InputClass "system-keyboard"
[     3.459] (II) Using input driver 'libinput' for 'USB Keyboard'
[     3.459] (**) USB Keyboard: always reports core events
[     3.459] (**) Option "Device" "/dev/input/event9"
[     3.459] (**) Option "_source" "server/udev"
[     3.461] (II) event9  - USB Keyboard: is tagged by udev as: Keyboard
[     3.461] (II) event9  - USB Keyboard: device is a keyboard
[     3.461] (II) event9  - USB Keyboard: device removed
[     3.497] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3.2/1-3.2:1.2/0003:04D9:0132.0003/input/input9/event9"
[     3.497] (II) XINPUT: Adding extended input device "USB Keyboard" (type: KEYBOARD, id 10)
[     3.497] (**) Option "xkb_model" "pc105"
[     3.497] (**) Option "xkb_layout" "us"
[     3.499] (II) event9  - USB Keyboard: is tagged by udev as: Keyboard
[     3.499] (II) event9  - USB Keyboard: device is a keyboard
[     3.500] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/event10)
[     3.500] (**) USB OPTICAL MOUSE: Applying InputClass "evdev pointer catchall"
[     3.500] (**) USB OPTICAL MOUSE: Applying InputClass "libinput pointer catchall"
[     3.500] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE'
[     3.500] (**) USB OPTICAL MOUSE: always reports core events
[     3.500] (**) Option "Device" "/dev/input/event10"
[     3.500] (**) Option "_source" "server/udev"
[     3.556] (II) event10 - USB OPTICAL MOUSE: is tagged by udev as: Mouse
[     3.556] (II) event10 - USB OPTICAL MOUSE: device set to 1000 DPI
[     3.556] (II) event10 - USB OPTICAL MOUSE: device is a pointer
[     3.556] (II) event10 - USB OPTICAL MOUSE: device removed
[     3.631] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3.3/1-3.3:1.0/0003:093A:2521.0004/input/input10/event10"
[     3.631] (II) XINPUT: Adding extended input device "USB OPTICAL MOUSE" (type: MOUSE, id 11)
[     3.631] (**) Option "AccelerationScheme" "none"
[     3.631] (**) USB OPTICAL MOUSE: (accel) selected scheme none/0
[     3.631] (**) USB OPTICAL MOUSE: (accel) acceleration factor: 2.000
[     3.631] (**) USB OPTICAL MOUSE: (accel) acceleration threshold: 4
[     3.689] (II) event10 - USB OPTICAL MOUSE: is tagged by udev as: Mouse
[     3.689] (II) event10 - USB OPTICAL MOUSE: device set to 1000 DPI
[     3.689] (II) event10 - USB OPTICAL MOUSE: device is a pointer
[     3.690] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/mouse1)
[     3.690] (II) No input driver specified, ignoring this device.
[     3.690] (II) This device may have been added with another device file.
[     3.691] (II) config/udev: Adding input device HP Wide Vision HD Camera: HP Wi (/dev/input/event4)
[     3.691] (**) HP Wide Vision HD Camera: HP Wi: Applying InputClass "evdev keyboard catchall"
[     3.691] (**) HP Wide Vision HD Camera: HP Wi: Applying InputClass "libinput keyboard catchall"
[     3.691] (**) HP Wide Vision HD Camera: HP Wi: Applying InputClass "system-keyboard"
[     3.691] (II) Using input driver 'libinput' for 'HP Wide Vision HD Camera: HP Wi'
[     3.691] (**) HP Wide Vision HD Camera: HP Wi: always reports core events
[     3.691] (**) Option "Device" "/dev/input/event4"
[     3.691] (**) Option "_source" "server/udev"
[     3.692] (II) event4  - HP Wide Vision HD Camera: HP Wi: is tagged by udev as: Keyboard
[     3.692] (II) event4  - HP Wide Vision HD Camera: HP Wi: device is a keyboard
[     3.692] (II) event4  - HP Wide Vision HD Camera: HP Wi: device removed
[     3.791] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1:1.0/input/input4/event4"
[     3.791] (II) XINPUT: Adding extended input device "HP Wide Vision HD Camera: HP Wi" (type: KEYBOARD, id 12)
[     3.791] (**) Option "xkb_model" "pc105"
[     3.791] (**) Option "xkb_layout" "us"
[     3.793] (II) event4  - HP Wide Vision HD Camera: HP Wi: is tagged by udev as: Keyboard
[     3.793] (II) event4  - HP Wide Vision HD Camera: HP Wi: device is a keyboard
[     3.793] (II) config/udev: Adding input device HD-Audio Generic Mic (/dev/input/event2)
[     3.793] (II) No input driver specified, ignoring this device.
[     3.793] (II) This device may have been added with another device file.
[     3.794] (II) config/udev: Adding input device HD-Audio Generic Headphone (/dev/input/event3)
[     3.794] (II) No input driver specified, ignoring this device.
[     3.794] (II) This device may have been added with another device file.
[     3.794] (II) config/udev: Adding input device PC Speaker (/dev/input/event0)
[     3.801] (EE) Failed to open authorization file "/var/run/sddm/{a0729092-68ec-4339-af44-be1264cb2630}": No such file or directory
[    12.125] (II) AMDGPU(0): EDID vendor "AUO", prod id 9197
[    12.126] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    12.126] (II) AMDGPU(0): Modeline "1920x1080"x0.0  141.00  1920 2028 2076 2100  1080 1090 1100 1118 -hsync -vsync (67.1 kHz eP)
[    12.126] (II) AMDGPU(0): Modeline "1920x1080"x0.0   94.00  1920 2028 2076 2100  1080 1090 1100 1118 -hsync -vsync (44.8 kHz e)
[    12.652] (II) AMDGPU(0): EDID vendor "AUO", prod id 9197
[    12.652] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    12.652] (II) AMDGPU(0): Modeline "1920x1080"x0.0  141.00  1920 2028 2076 2100  1080 1090 1100 1118 -hsync -vsync (67.1 kHz eP)
[    12.652] (II) AMDGPU(0): Modeline "1920x1080"x0.0   94.00  1920 2028 2076 2100  1080 1090 1100 1118 -hsync -vsync (44.8 kHz e)
[   143.526] (II) AMDGPU(0): EDID vendor "AUO", prod id 9197
[   143.526] (II) AMDGPU(0): Printing DDC gathered Modelines:
[   143.526] (II) AMDGPU(0): Modeline "1920x1080"x0.0  141.00  1920 2028 2076 2100  1080 1090 1100 1118 -hsync -vsync (67.1 kHz eP)
[   143.526] (II) AMDGPU(0): Modeline "1920x1080"x0.0   94.00  1920 2028 2076 2100  1080 1090 1100 1118 -hsync -vsync (44.8 kHz e)
Thanks for any help!
add
iommu=pt
to boot options
also go for latest kernel - 5.3 if you can.
Actually heres a list to try ..
iommu=pt idle=nomwait acpi_backlight=vendor acpi_enforce_resources=lax vga=current
ok so both the keyboard and touchpad are not even recognized, never mind working.
:point_up: this, 5.1 is EOL anyhow.
in the other thread you mentioned making changes to initrd and grub
exactly what is currently changed? and are you certain you needed to change all that you did change?
Regarding the kernel version, the Realtek wireless that comes with this laptop works with kernel 5.1; it doesn't seem to work with 5.2 or 5.3. So since I have three (actually four, I think: power management doesn't seem to recognize the battery, but I only noticed that on kernel 5.1) things that don't work, I figured I'd reduce them to two by using kernel 5.1. But if I can get the keyboard/touchpad/battery working, I do have an old USB wireless adapter that works.
So the whole story is I got this laptop, tried to install Manjaro, and ran into problems (lockups). Googling revealed this Ask Ubuntu, which revealed this kernel.org thread, which revealed this blog post.
When I discovered that I could supply acpi=off nospec_store_bypass_disable to both the Arch ISO and the Manjaro ISO in this thread, I realized I could install Manjaro on the machine using a USB keyboard and mouse, and then attempt the ACPI table thing from the instructions above.
So I did that: on Windows, I extracted the ACPI tables, made the recommended changes, and compiled them back. I then saved the files to a USB stick. I then installed Manjaro (I considered Arch because I figured it likely had a newer kernel, but their ISO doesn't apparently allow you to boot the kernel in UEFI mode and still provide custom parameters to it---plus I actually use Manjaro), creating a new partition table and completely blowing away Windows. I then booted the machine using acpi=off nospec_store_bypass_disable and created the custom initrd with the ACPI tables concatenated as described in the Ask Ubuntu, kernel.org thread, and blog post above.
Using that, the machine boots without parameters, but with no touchpad, keyboard, wireless, and possibly battery (at least on kernel 5.1). So that's where I am currently; in the other thread I was trying various kernel boot parameters I also found in various threads around the Internet which some people had reported success with on other machines, but they don't seem to be working with mine. I'll try the ones @cscs mentioned above with the RC kernel 5.3 that Manjaro provides and get back to you.
:dizzy_face:
thats a bit over my head tbh, i just tried the whole acpi tables thing and couldnt understand what the syntax errors even were, when i checked they looks fine. im curious to know though, if a kernel parameter is specified, does it take priority over whats in the initrd? i would assume it would but it's only assuming.
is acpi=off the only option you tried. the nospec bypass shouldnt have any effect on the keyboard/touchpad so that can be left alone as you have it. here is the acpi parameter definitions from kernel.org's kernel paramter documentation
acpi=		[HW,ACPI,X86,ARM64]
			Advanced Configuration and Power Interface
			Format: { force | on | off | strict | noirq | rsdt |
				  copy_dsdt }
			force -- enable ACPI if default was off
			on -- enable ACPI but allow fallback to DT [arm64]
			off -- disable ACPI if default was on
			noirq -- do not use ACPI for IRQ routing
			strict -- Be less tolerant of platforms that are not
				strictly ACPI specification compliant.
			rsdt -- prefer RSDT over (default) XSDT
			copy_dsdt -- copy DSDT to memory
			See also Documentation/power/runtime_pm.txt, pci=noacpi
theres also noacpi you can try instead of disabling acpi entirely with acpi=off
noacpi		[X86] Do not use ACPI for IRQ routing
also, didnt i see you mention in one of your previous posts about the acpi tables, and that there were more of them than needed and you removed some of them? if so, maybe they were not so unneeded after all. have you tried repeating the process without removing them?
Okay, I installed kernel 5.3 RC4, which is the latest offered by Manjaro. Using @cscs's parameters above makes no difference; the system locks up with them or without them. noacpi does the same thing.
Yesterday, I was able to get the machine to boot by adding the extracted ACPI table to the initrd; I'll do that to the 5.3 kernel next. I know at least that I'll be back to where I was: no keyboard, no touchpad, no wireless, and I'll have to check to see if power management is working.
Kernel 5.3 RC4 boots with the modified initrd, but now I don't have keyboard, touchpad, wireless, or power management. I'm completely at a loss; I don't see any way forward at this point. :frowning:
theres actually 1 existing hardware probe of your laptop believe it or not
might be able to find out something, theres a ton of info in there including user confirmed functionality
[    0.000000] Linux version 5.1.20-050120-generic (kernel@kathleen) (gcc version 9.1.0 (Ubuntu 9.1.0-9ubuntu2)) #201907260839 SMP Fri Jul 26 08:41:56 UTC 2019
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.1.20-050120-generic root=UUID=db1c3a67-2fe8-412e-a599-4218bce8e9b3 ro quiet splash vt.handoff=1 acpi_osi=Linux
Those parameters (vt.handoff=1 acpi_osi=Linux) also don't seem to have an effect; the unmodified initrd still results in a lockup. I'll have to look more closely at that page. One of the things I remember in all my reading is that AMD is apparently working directly with Canonical on supporting this CPU, and that there are patches in their kernels to make things work.
theres a lot of info on that hw probe, maybe you can also probe your hardware. it gets randomized before it's posted and lets others (possibly devs?) see where something may be going wrong. you can also link it into a bug report wherever.
you got the hard part done, it boots. which for a lot of HP owners is a miracle on it's own. if you can manage to get ubuntu booted even just as a live environment and probe that as well, and if the touchpad and keyboard work you can see what firmware/drivers they are using and get device/vendor id's you should be able to add those device id's to the drivers here on manjaro so they are recognized.
if you can manage the ACPI table fix, your surely capable enough to add the device id's to the appropriate drivers. or pull the drivers right from ubuntu and compile them here?
Ha. I can follow directions, but I don't want to pretend I know what I'm doing. Plus I don't have gobs of time to pursue this, unfortunately.
did the touchpad and/or keyboard work on the live environment or never at all?
check in bios for a touchpad option, if it's there it's usually "basic" or "advanced" as options (something like that).
go over every section and subsection of bios settings for anything that may be related. HP bios can be tricky with a bunch of useless settings, especially the "HP advanced blah-blah-blah" options. unless they are crucial, disable them.
have you tried any of these parameters?
psmous.proto=imps
psmous.proto=any
psmous.proto=exps
i8042.nopnp
Hello there :slight_smile:
Could you please tell me how you got your system running?
I have a HP envy x360 DS-00005 with a Ryzen 3700U, too.
I tried many many things to install any kind of Linux, but nothing worked.
Today I did a BIOS Update which was suggested and performed automatically by my Windows (latest version is AMI F12 now). I hoped that this would changed my issues.
I also tried this: https://askubuntu.com/questions/1162746/why-wont-my-hp-envy-x360-laptop-with-ryzen-7-3700u-boot-ubuntu-live-cd (Solution 1, which didnt work).
I always get a black screen or a screen which says that ive gotten a kernel panic.
How did you make it this far?
Greetings
research and persistence. Start by reading this in the previous thread and then read this thread here. That would get you caught up to the progress so far. Then you can try different things and help solve this riddle of how to make linux work on this new hardware. So far no one knows yet.
can you give us the output of cpupower idle-info?
I've tried all those parameters, and there's no change. The keyboard never worked in the live environment either. It worked fine in Windows, and it works fine in Grub to set boot parameters, but not when the OS is booted.
Certainly. Here's sudo cpupower idle-info:
CPUidle driver: none
CPUidle governor: menu
analyzing CPU 0:
CPU 0: No idle states
The system certainly seems stable enough when I'm using it (like, to post this forum post). I'm assuming this reveals that there is no power management working whatsoever, as the CPU can't idle itself? The fan isn't on, so I hope it's not in danger of overheating....
Thanks , it was for curiosity. For me. In the r5 3550h amd I have 3 c states, the usb is not working in my Asus and the battery drains so much. I am thinking between return the laptop and buy a intel one or use windows only ..m because I am not going to use Linux with that batter drajn
i dont usually say this or ever really, but it seems these laptops are working with ubuntu so maybe for now give it a try and if it works do what i suggest in post #10 . go to linux-hardware.org and run a full hardware probe so you may refer to it later and others can help you compare whats different. having the necessary data is needed to do anything resembling progress. OR you wait until these systems are better supported
I have tried Ubuntu and manjaro. Manjaro the only problem that have vs Ubuntu is that don't boot with live CD. But this is because the kernel. Manjaro has 4.19 and Ubuntu has 5.0. Ubuntu boots and manjaro not, if you instal manjaro and after install newer kernel manjaro are going to work almost as good as Ubuntu. And other thing. Ubuntu has more power drain than manjaro with a few mW, don't make the people confuse saying distross has different hardware conoability. The real reason of manjaro don't booting up in newer hardware is to having a old kernel in its iso.. like in the actual iso that is 4.19.. (much old) 3 versiones older than modern kernel
