Hi,
I’ve managed to get myself in a bit of a pickle and not quite sure how to get myself out! I think I’ve made a mess of my /boot partition. I’m not dual booting so think I should have /boot/efi but it seems I only have /efi. How can I get myself out of this mess?
I was trying to upgrade my system and saw that I couldn’t because the error message I got said I didn’t have enough space on my boot partition. I did initially think of trying to expand my boot partition but I have 766M assigned and really that should be enough so I thought I should try and get to the bottom of why I’m maxed out on my boot partition.
So I had a look at usage on my boot partition and noticed that I only see an efi partition which was indeed maxed out
df -h
filesystem Size Used Avail Use% Mounted on
devtmpfs 16G 0 16G 0% /dev
tmpfs 16G 9.2M 16G 1% /dev/shm
tmpfs 6.3G 11M 6.3G 1% /run
/dev/mapper/vg02-lvol--root 98G 39G 55G 42% /
tmpfs 16G 52M 16G 1% /tmp
/dev/mapper/vg01-lvol--install_discs 49G 53M 47G 1% /installDiscs
/dev/mapper/vg02-lvol--home 9.8G 263M 9.1G 3% /home
/dev/mapper/vg01-lvol--libvirt 99G 68G 27G 73% /var/lib/libvirt
/dev/mapper/luks_corporate 40G 3.3G 34G 9% /corporate
/dev/mapper/vg01-lvol--lxd 49G 25G 22G 54% /var/lib/lxd
/dev/mapper/luks_john 49G 20G 27G 43% /home/john
/dev/mapper/vg01-lvol--downloads 49G 42G 5.0G 90% /home/john/Downloads
/dev/loop7 163M 163M 0 100% /var/lib/snapd/snap/gnome-3-28-1804/145
/dev/loop0 242M 242M 0 100% /var/lib/snapd/snap/gnome-3-38-2004/70
/dev/loop6 66M 66M 0 100% /var/lib/snapd/snap/gtk-common-themes/1519
/dev/loop8 66M 66M 0 100% /var/lib/snapd/snap/gtk-common-themes/1515
/dev/loop2 128K 128K 0 100% /var/lib/snapd/snap/bare/5
/dev/loop4 33M 33M 0 100% /var/lib/snapd/snap/snapd/13170
/dev/loop1 33M 33M 0 100% /var/lib/snapd/snap/snapd/12883
/dev/loop3 243M 243M 0 100% /var/lib/snapd/snap/gnome-3-38-2004/76
/dev/loop5 165M 165M 0 100% /var/lib/snapd/snap/gnome-3-28-1804/161
/dev/loop9 56M 56M 0 100% /var/lib/snapd/snap/core18/2074
/dev/loop10 56M 56M 0 100% /var/lib/snapd/snap/core18/2128
/dev/loop11 62M 62M 0 100% /var/lib/snapd/snap/core20/1081
/dev/loop12 65M 65M 0 100% /var/lib/snapd/snap/apple-music-for-linux/38
/dev/loop13 168M 168M 0 100% /var/lib/snapd/snap/alfacast/22
/dev/loop14 166M 166M 0 100% /var/lib/snapd/snap/alfacast/20
tmpfs 100K 0 100K 0% /var/lib/lxd/shmounts
tmpfs 100K 0 100K 0% /var/lib/lxd/devlxd
default/containers/docker2 18G 14G 3.9G 78% /var/lib/lxd/storage-pools/default/containers/docker2
tmpfs 3.2G 2.5M 3.2G 1% /run/user/1002
/dev/sda3 1.6T 259G 1.3T 18% /run/media/john/linux
/dev/sda2 500G 3.0G 498G 1% /run/media/john/Seagate Backup Plus Drive
/dev/nvme1n1p1 766M 766M 0 100% /efi
So I started to look at what I had in boot and efi partitions and started to go down a rabbit hole…
Contents of my boot and efi are shown below
ls -l /boot
-rwxrwxr-x 1 root adm 40960 Jul 19 15:16 amd-ucode.img
-rwxrwxr-x 1 root adm 105872363 Aug 6 22:36 initramfs-5.10-x86_64-fallback.img
-rwxrwxr-x 1 root adm 86235522 Aug 6 22:35 initramfs-5.10-x86_64.img
-rwxrwxr-x 1 root adm 110290772 Aug 6 22:36 initramfs-5.13-x86_64-fallback.img
-rwxrwxr-x 1 root adm 87201254 Aug 6 22:36 initramfs-5.13-x86_64.img
-rwxrwxr-x 1 root adm 4769792 Jun 8 14:31 intel-ucode.img
-rwxrwxr-x 1 root adm 22 Jul 26 03:17 linux510-x86_64.kver
-rwxrwxr-x 1 root adm 21 Jul 26 03:42 linux513-x86_64.kver
drwxrwxr-x 2 root adm 4096 Jul 16 18:14 memtest86+
-rwxrwxr-x 1 root adm 9386432 Aug 6 22:35 vmlinuz-5.10-x86_64
-rwxrwxr-x 1 root adm 9679904 Aug 6 22:35 vmlinuz-5.13-x86_64
ls -l /efi
-rwxrwxr-x 1 root adm 40960 Dec 18 2020 amd-ucode.img
drwxrwxr-x 5 root adm 4096 Jan 3 2021 EFI
-rwxrwxr-x 1 root adm 105832940 Aug 6 23:00 initramfs-5.10-x86_64-fallback.img
-rwxrwxr-x 1 root adm 86169591 Aug 6 23:00 initramfs-5.10-x86_64.img
-rwxrwxr-x 1 root adm 86626304 Aug 6 23:01 initramfs-5.13-x86_64-fallback.img
-rwxrwxr-x 1 root adm 87189235 Aug 6 23:00 initramfs-5.13-x86_64.img
-rwxrwxr-x 1 root adm 3621888 Nov 19 2020 intel-ucode.img
-rwxrwxr-x 1 root adm 22 Jul 11 08:58 linux510-x86_64.kver
drwxrwxr-x 3 root adm 4096 Sep 23 23:51 loader
drwxrwxr-x 3 root adm 4096 Aug 6 22:36 Manjaro
drwxrwxr-x 2 root adm 4096 Jan 3 2021 memtest86+
-rwxrwxr-x 1 root adm 9412768 Jul 17 23:33 vmlinuz-5.10-x86_64
In my fstab, I’ve only got /boot listed:
cat /etc/fstab
# /dev/mapper/vg02-lvol--root
UUID=c4cf79bc-b324-4058-83ba-bead81dc6c08 / ext4 rw,noatime 0 0
# /dev/mapper/vg01-lvol--libvirt
UUID=70520927-21c9-4c47-b757-7da9d86eeaad /var/lib/libvirt ext4 rw,noatime 0 0
# /dev/mapper/vg01-lvol--install_discs
UUID=eca67b5d-4a59-406d-a345-700f5173dfcf /installDiscs ext4 rw,noatime 0 0
# /dev/mapper/vg01-lvol--downloads
UUID=f05a9155-2569-4c9a-872e-31db430f9ec6 /home/john/Downloads ext4 rw,noatime 0 0
# /dev/mapper/vg01-lvol--lxd
UUID=ff677908-74ca-4e2f-b710-ddfe59ab3af1 /var/lib/lxd ext4 rw,noatime 0 0
# /dev/mapper/vg02-lvol--home
UUID=b8e1a944-091a-44f6-9939-b2182746446a /home ext4 rw,noatime 0 0
# /dev/mapper/crypt-john
#UUID=ac03e403-b9d6-444d-9d6c-712caf669cf4 /home/john ext4 rw,noatime 0 0
/dev/mapper/luks_john /home/john ext4 rw,noatime 0 0
# /dev/mapper/crypt-corporate
#UUID=7700b80e-e87f-49b8-89f7-a249e884bcfe /corporate ext4 rw,noatime 0 0
/dev/mapper/luks_corporate /corporate ext4 rw,noatime 0 0
# /dev/nvme1n1p1
UUID=569C-041A /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
# /dev/mapper/crypt-swap
#UUID=c59f0bd6-bb07-4dde-82bf-259b1fc8580f none swap defaults,pri=-2 0 0
/dev/mapper/luks_swap none swap defaults,pri=-2 0 0
cat /efi/loader/entries/manjarolinux5.13.conf
title Manjaro Linux 5.13
linux /Manjaro/vmlinuz-5.13-x86_64
initrd /amd-ucode.img
initrd /intel-ucode.img
initrd /Manjaro/amd-ucode.img
initrd /Manjaro/intel-ucode.img
initrd /initramfs-5.13-x86_64.img
options root=UUID=c4cf79bc-b324-4058-83ba-bead81dc6c08 rw
fdisk -l
Disk /dev/nvme0n1: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: WDC WDS100T2B0C-00PXH0
Disklabel type: gpt
Disk identifier: B11EC886-95B2-4AE1-9DF9-B5AEC67C34F5
Device Start End Sectors Size Type
/dev/nvme0n1p1 2048 1953525134 1953523087 931.5G Linux LVM
Disk /dev/nvme1n1: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: Samsung SSD 970 EVO 1TB
Disklabel type: gpt
Disk identifier: 94D60797-87CB-47FE-BF5C-C993FEA15C0C
/dev/nvme1n1p1 2048 1572864 1570817 767M EFI System
/dev/nvme1n1p2 1574912 1953525134 1951950223 930.8G Linux LVM
Any help or tips on how I might be able to fix this would be very much appreciated.
