Yes, it varies, ip-address/ipp/p1 most often, but there are other
Debian has 2-3 wiki pages on airprint/driverless
Thank you for your help.
I finally figured out how to configure the printer and was able to successfully print. I found an article on the arch wiki and it says to use the ipp://printeripaddress:631/ipp/print. On the cups browser, I tried to configure the brother printer driver (driverless driver) to the source address above. It would communicate with the printer but print multiple blank pages. Then I decided to setup a new printer on the cups page. This time not using the brother driver but manually setting up airprint ipp. I added the source address above and manually called it Brother and it worked. Finally got my printer set up. Thank you all once again for your patience and support.
Ah, yes that is one of the âgotchaâsâ you DON"T use the x86 ppd, because it has a x86 driver reference in it,
but generic which come from the printers rom
Is it possible to use the scanner feature through airplay?
I think so, I have never done this, but most printer companies have
an android phone app that I think has scanning
I think there is a driver that enables the scanning âbrscan4â though that may be for x86 as it doesnt build on aarch64
I noticed cups drivers had an update and now printer doesnât work again. I tried to reinstall the cups and enable systemctl service:
systemctl enable --now org.cups.cupsd.service
I get a failed to enable unit. Does not exist. Anyone know what its been changed to? I get an error when I go to local host:631/admin now on my browser as well.
***UPDATE: cups page is working again and was able to set my printer up again. I donât know if the
org.cups.cupsd.service is necessary. Restarting the cups-browsed.service seem to do the trick.
