thank you very much, you are a lifesaver. how did you figure it out so fast. i couldnt figure it out and i caused it somehow. again thank you
you mentioned that you tried installing kernel/drivers for gpu, so you check which kernel is installed with mhwd-kernel -li;
then you check what drivers are available for your gpu with mhwd -l;
then you check what drivers you have installed with mhwd -li
but how did you changed the uuid from your efi partition i have no idea, did you reinstalled grub?
Mentioned the fact that i reinstalled grub here
finally solved by removing anbox, its modules and its systemctl entries inside tty and rebooting
