Hi folks,
I have a new laptop from work (a Lenovo Legion i5) with both the on-chip Intel video card and a nVidia dedicated GPU. I can’t use ‘prime-run’ to start any application, I always get this error :
prime-run glxgears X Error of failed request: BadValue (integer parameter out of range for operation)
I’ve tried reinstalling the drivers and different combinations of Kernels and or GPU drivers, no luck.
Below are some data :
inxi -F output:
System: Host: i-r-legion Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.20.2 Distro: Manjaro Linux
Machine: Type: Laptop System: LENOVO product: 82AU v: Lenovo Legion 5 15IMH05 serial: <superuser/root required>
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser/root required> UEFI: LENOVO v: EFCN31WW
date: 04/27/2020
Battery: ID-1: BAT0 charge: 78.8 Wh condition: 80.3/80.0 Wh (100%)
CPU: Info: 6-Core model: Intel Core i7-10750H bits: 64 type: MT MCP L2 cache: 12.0 MiB
Speed: 800 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
9: 800 10: 800 11: 800 12: 800
Graphics: Device-1: Intel UHD Graphics driver: i915 v: kernel
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] driver: nvidia v: 455.38
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.9 driver: modesetting unloaded: nvidia resolution: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.2.1
Audio: Device-1: Intel Comet Lake PCH cAVS driver: snd_hda_intel
Sound Server: ALSA v: k5.8.18-1-MANJARO
Network: Device-1: Intel Wireless-AC 9462/9560 driver: iwlwifi
IF: wlp0s20f3 state: up mac: e4:5e:37:aa:0f:dc
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: enp7s0 state: down mac: 00:2b:67:79:48:0b
Drives: Local Storage: total: 476.94 GiB used: 66.10 GiB (13.9%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L2 size: 476.94 GiB
Partition: ID-1: / size: 434.35 GiB used: 66.10 GiB (15.2%) fs: ext4 dev: /dev/nvme0n1p2
Swap: ID-1: swap-1 type: partition size: 34.35 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 40.0 C mobo: N/A
Info: Processes: 277 Uptime: 14m Memory: 31.23 GiB used: 1.83 GiB (5.8%) Shell: Bash inxi: 3.1.08
/etc/X11/mhwd.d/nvidia.conf contents:
`Section "Files"
ModulePath "/usr/lib/xorg/modules"
ModulePath "/usr/lib/nvidia/xorg"
EndSection
Section "ServerLayout"
Identifier "layout"
Screen 0 "iGPU"
Inactive "nGPU"
Option "AllowNVIDIAGPUScreens"
EndSection
Section "Device"
Identifier "nGPU"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce GTX 1650 Ti Mobile"
BusID "PCI:1:0:0"
EndSection
Section "Device"
Identifier "iGPU"
Driver "modesetting"
BusID "PCI:0:2:0"
Option "DRI" "3"
EndSection
Section "Screen"
Identifier "iGPU"
Device "iGPU"
EndSection
Section "Screen"
Identifier "nGPU"
Device "nGPU"
EndSection`
I’ve added these in /etc/mkinitcpio.conf :
MODULES=(nvidia nvidia_modeset nvidia_uvm nvidia_drm)
xrandr --listproviders output:
Providers: number : 2
Provider 0: id: 0x43 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 3 outputs: 1 associated providers: 1 name:modesetting
Provider 1: id: 0xcb cap: 0x2, Sink Output crtcs: 4 outputs: 3 associated providers: 1 name:modesetting
nvidia-smi output :
| NVIDIA-SMI 455.38 Driver Version: 455.38 CUDA Version: 11.1 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 GeForce GTX 165... Off | 00000000:01:00.0 Off | N/A |
| N/A 39C P8 1W / N/A | 6MiB / 3911MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| No running processes found |
These are the drivers installed :
video-hybrid-intel-nvidia-455xx-prime 2020.10.04 false PCI
video-modesetting 2020.01.13 true PCI
Using 5.8.18-1-MANJARO Kernel (I saw that 5.9 has some issues with the nvidia driver)
Can anyone help ? Thanks
