Help needed in identifying offending update
Hello all,
Couple of days ago i noticed that whenever i would restart, GRUB screen with options would not show and instead would boot into default option. This is only happening after a restart. On cold boot after a shutdown, GRUB screen is shown as usual.
Fortunately for me, I happen to take Timeshift snapshots before every major update I do so I thought of restoring the most recent one to see if the issue persists. Lo and behold, the issue disappeared and GRUB screen would show even after a restart.
For context reference, here the output of inxi -zv8
  Kernel: 5.15.179-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=e57b3f5b-e08c-4760-ae88-e11a2597d36d ro quiet apparmor=1
  Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
  Type: Desktop System: Micro-Star product: MS-7C92 v: 1.0
    serial: <superuser required>
  Mobo: Micro-Star model: MPG B550I GAMING EDGE WIFI (MS-7C92) v: 1.0
    serial: <superuser required> uuid: <superuser required>
    UEFI: American Megatrends v: 1.20 date: 08/07/2020
  Device-1: hidpp_battery_0 model: Logitech MX Anywhere 3 serial: <filter>
    charge: 85% rechargeable: yes status: discharging
  Device-2: hidpp_battery_1 model: Logitech K800 serial: <filter>
    charge: 10% (should be ignored) rechargeable: yes status: discharging
  System RAM: total: 16 GiB available: 15.55 GiB used: 3.84 GiB (24.7%)
  Array-1: capacity: 128 GiB note: check slots: 2 modules: 2 EC: None
    max-module-size: 64 GiB note: est.
    (unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMK16GX4M2B3200C16 serial: N/A
  Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 2
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701034
  Topology: cpus: 1x dies: 1 cores: 6 threads: 12 tpc: 2 smt: enabled cache:
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
    L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 2904 min/max: 2200/4208 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 2904 2: 2904 3: 2904
    4: 2904 5: 2904 6: 2904 7: 2904 8: 2904 9: 2904 10: 2904 11: 2904 12: 2904
    bogomips: 86440
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
    sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean
    vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
  Type: spec_rstack_overflow mitigation: safe RET
    prctl and seccomp
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate]
    vendor: Micro-Star MSI driver: nvidia v: 570.133.07
    alternate: nouveau,nvidia_drm non-free: 550-570.xx+ status: current (as
    of 2025-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: none
    off: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 2b:00.0 chip-ID: 10de:2489
    class-ID: 0300
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 79 s-size: 1235x686mm (48.62x27.01")
    s-diag: 1413mm (55.62")
  Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Sony TV 30
    serial: <filter> built: 2020 res: mode: 3840x2160 hz: 60 scale: 100% (1)
    dpi: 80 gamma: 1.2 chroma: red: x: 0.627 y: 0.341 green: x: 0.278 y: 0.596
    blue: x: 0.153 y: 0.071 white: x: 0.282 y: 0.298
    size: 1218x685mm (47.95x26.97") diag: 1397mm (55") ratio: 16:9
    modes: 3840x2160, 4096x2160, 1920x1080, 1680x1050, 1600x900, 1280x1024,
    1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 117 2: parse_edid:
    unhandled CEA mode 118 3: parse_edid: unhandled CEA mode 97 4: parse_edid:
    unhandled CEA mode 96 5: parse_edid: unhandled CEA mode 101 6: parse_edid:
    unhandled CEA mode 102 7: parse_edid: unhandled CEA mode 93 8: parse_edid:
    unhandled CEA mode 94 9: parse_edid: unhandled CEA mode 95 10: parse_edid:
    unhandled CEA mode 98
  API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia platforms: device: 0
    drv: nvidia device: 1 drv: nouveau device: 2 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.133.07
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
    memory: 7.81 GiB
  API: Vulkan v: 1.4.309 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3060 Ti driver: nvidia v: 570.133.07 device-ID: 10de:2489
    surfaces: xcb,xlib
    de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
    link-max: gen: 4 speed: 16 GT/s bus-ID: 2b:00.1 chip-ID: 10de:228b
    class-ID: 0403
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Logitech QuickCam Communicate STX
    driver: gspca_zc3xx,snd-usb-audio type: USB rev: 1.1 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 1-6:3 chip-ID: 046d:08d7 class-ID: 0102
  API: ALSA v: k5.15.179-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with:
    tools: pacat,pactl
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 29:00.0 chip-ID: 8086:2723 class-ID: 0280
  Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 2a:00.0
  IF: enp42s0 state: down mac: <filter>
  Info: services: mld, NetworkManager, systemd-timesyncd, wpa_supplicant
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:4 chip-ID: 8087:0029
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
    lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c0104
  Local Storage: total: 3.64 TiB used: 506.9 GiB (13.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QGXA7 temp: 45.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:9 vendor: Samsung
    model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 42.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST33000651AS
    size: 2.73 TiB block-size: physical: 4096 B logical: 4096 B type: USB
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 7200
    serial: <filter> fw-rev: 0D0B scheme: MBR
  ID-1: / raw-size: 57.17 GiB size: 55.72 GiB (97.46%) used: 39.4 GiB (70.7%)
    fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
    uuid: e57b3f5b-e08c-4760-ae88-e11a2597d36d
  ID-2: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%)
    used: 25.6 MiB (27.0%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: EEEC-C5D6
  ID-3: /home raw-size: 106.85 GiB size: 104.86 GiB (98.14%)
    used: 49.83 GiB (47.5%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
    label: N/A uuid: 41bf1e0a-9200-47a5-af59-e24b9a8543bb
  ID-4: /media/Metal raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
    used: 417.64 GiB (91.3%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:10
    label: Music et al uuid: 298d4f64-ee4a-4f46-8a45-8bbb0149644f
  ID-1: swap-1 type: partition size: 8.79 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: 763e3bc8-3a2d-441c-a4fc-d7dde3cff8f8
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 450 MiB fs: ntfs label: Recovery
    uuid: 60D4EC70D4EC49BC
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 291.91 GiB fs: ntfs label: N/A
    uuid: AA8C063B8C060315
  ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 512.5 MiB fs: vfat label: N/A
    uuid: 3A73-55BC
  ID-5: /dev/sda1 maj-min: 8:1 size: 2.73 TiB fs: ntfs
    label: FreeAgent GoFlex Drive uuid: 20E8B9D4E8B9A884
  Device-1: 1-5:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-6:3 info: Logitech QuickCam Communicate STX type: audio
    driver: gspca_zc3xx,snd-usb-audio interfaces: 3 rev: 1.1
  Device-3: 1-9:4 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Device-4: 1-10:5 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c92 class-ID: 0300
    serial: <filter>
  Device-1: 4-4:2 info: Seagate RSS LLC FreeAgent GoFlex Desk
    type: mass storage driver: usb-storage interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bc2:50a1
    class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 53.4 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1819 libs: 512 tools: pamac pm: flatpak pkgs: 0
    1: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    2: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    3: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    4: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    6: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    7: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    8: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 353
  1: cpu: 6.8% command: strawberry pid: 2549 mem: 380.7 MiB (2.3%)
  2: cpu: 6.5% command: firefox pid: 2641 mem: 522.7 MiB (3.2%)
  3: cpu: 4.7% command: konsole pid: 4230 mem: 136.8 MiB (0.8%)
  4: cpu: 4.0% command: firefox pid: 2866 mem: 358.4 MiB (2.2%)
  5: cpu: 2.7% command: Xorg pid: 1322 mem: 158.0 MiB (0.9%)
  Memory top: 5 of 353
  1: mem: 664.5 MiB (4.1%) command: plasmashell pid: 1673 cpu: 0.3%
  2: mem: 522.7 MiB (3.2%) command: firefox pid: 2641 cpu: 6.5%
  3: mem: 380.7 MiB (2.3%) command: strawberry pid: 2549 cpu: 6.8%
  4: mem: 358.4 MiB (2.2%) command: firefox pid: 2866 cpu: 4.0%
  5: mem: 259.3 MiB (1.6%) command: skypeforlinux pid: 2137 cpu: 0.3%
  Processes: 353 Power: uptime: 49m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.21 GiB services: org_kde_powerdevil,upowerd
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.38
So, my question is two-fold:
  1. Is this behavior something that can be remedied and have GRUB screen appear after a restart?
  2. Failing the above :point_up: , how can i identify the offending update that’s causing this mess and avoid installing it altogether? Between my current state and the previous snapshot - where the issue is not reproduced - there are 680 updates! I can’t possibly go through them one-by-one in order to find which is the guilty one.
Any ideas?
Hi @londino, and welcome!
Yes. While I don’t know what might be the cause of this, I would recommend you do the update, ensure the install-grub script is installed:
pamac install install-grub
…shut down, start up again, and reinstall GRUB:
sudo install-grub
Then reboot and test.
Thanks for the welcome @Mirdarthos . Long time lurker, first time poster here.
I tried your suggestion and the issue still persists :smiling_face: Anything else i could try?
Well, since you asked, you could try giving us more information, such as the outputs of the commands you used. (Run 'em again, copy-and-paste here, the same format as your inxi output.)
Also, then please provide the output of:
fdisk -l
and
lsblk -o NAME,MAJ:MIN,RM,SIZE,RO,TYPE,UUID,MOUNTPOINTS
OK here they are one-by-one:
Preparing...
cp: cannot access '/var/lib/pacman/sync/download-XUkGOV': Permission denied
Warning: install-grub-2:2.12.r260.gaae2ea619-3 is up to date -- skipping
Nothing to do.
P.S. This one had a different output first time i ran it as it did install the grub version that is now skipping, due to having already installed it previously.
sudo install-grub
Grub will be installed on: EFI
Installing for x86_64-efi platform.
Installation finished. No error reported.
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
ERROR: unsupported sector size 4096 on /dev/sda.
Found Windows Boot Manager on /dev/nvme0n1p2@/EFI/Microsoft/Boot/bootmgfw.efi
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
Warning: GRUB bootloader at /boot/efi/EFI/Manjaro was updated,
but it seems like you are not using it by default.
Please check your EFI boot priorities!
Note: Here also i did not get the very last WARNING first time i executed the command.
fdisk -l
Disk /dev/nvme0n1: 465,76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: Samsung SSD 980 PRO 500GB
Disklabel type: gpt
Disk identifier: 0472BE3C-CEAB-4B8F-A253-942FA9A0215C
Device             Start       End   Sectors   Size Type
/dev/nvme0n1p1      2048    923647    921600   450M Windows recovery environment
/dev/nvme0n1p2    923648   1126399    202752    99M EFI System
/dev/nvme0n1p3   1126400   1159167     32768    16M Microsoft reserved
/dev/nvme0n1p4   1159168 613329826 612170659 291,9G Microsoft basic data
/dev/nvme0n1p5 613329827 614379519   1049693 512,5M Microsoft basic data
/dev/nvme0n1p6 614379520 632811519  18432000   8,8G Linux swap
/dev/nvme0n1p7 632811520 752701439 119889920  57,2G Linux filesystem
/dev/nvme0n1p8 752701440 976773119 224071680 106,8G Linux filesystem
Disk /dev/nvme1n1: 465,76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: Samsung SSD 970 EVO Plus 500GB
Disklabel type: gpt
Disk identifier: EB9CEDAC-C9EF-F145-AD2B-2A3FB01E580D
/dev/nvme1n1p1  2048 976766975 976764928 465,8G Linux filesystem
Disk /dev/sda: 2,73 TiB, 3000592977920 bytes, 732566645 sectors
Disk model: FA GoFlex Desk
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0x0007686b
Device     Boot Start       End   Sectors  Size Id Type
/dev/sda1  *       63 732564062 732564000  2,7T  7 HPFS/NTFS/exFAT
NAME        MAJ:MIN RM   SIZE RO TYPE UUID                                 MOUNTPOINTS
sda           8:0    0   2,7T  0 disk
`-sda1        8:1    0   2,7T  0 part 20E8B9D4E8B9A884
nvme0n1     259:0    0 465,8G  0 disk
|-nvme0n1p1 259:1    0   450M  0 part 60D4EC70D4EC49BC
|-nvme0n1p2 259:2    0    99M  0 part EEEC-C5D6                            /boot/efi
|-nvme0n1p3 259:3    0    16M  0 part
|-nvme0n1p4 259:4    0 291,9G  0 part AA8C063B8C060315
|-nvme0n1p5 259:5    0 512,5M  0 part 3A73-55BC
|-nvme0n1p6 259:6    0   8,8G  0 part 763e3bc8-3a2d-441c-a4fc-d7dde3cff8f8 [SWAP]
|-nvme0n1p7 259:7    0  57,2G  0 part e57b3f5b-e08c-4760-ae88-e11a2597d36d /
`-nvme0n1p8 259:8    0 106,8G  0 part 41bf1e0a-9200-47a5-af59-e24b9a8543bb /home
nvme1n1     259:9    0 465,8G  0 disk
`-nvme1n1p1 259:10   0 465,8G  0 part 298d4f64-ee4a-4f46-8a45-8bbb0149644f /media/Metal
@Mirdarthos ICYM :point_up:
