@Mahafuj Sorry, I don’t know. I downloaded the .tar.gz archive and it fails to extract in my computer for some reason.
tar: This does not look like a tar archive
tar: Skipping to next header
tar: Exiting with failure status due to previous errors
Were you able to extract it? If so, can you run the command ls in a terminal in the directory, and post the output?
(ls lists all the file in the directory)
And i do really appreciate your helping. You have download the package for me and trying to install it. I could not ask for more. Thank you. I just don’t want to change the distro, but I need that software badly.
It is a very strangely packed file - it is a .tar.gz which has been gzipped again
I unpacked it with gunzip glade5_linux64_ub20.tar.gz
and then with: tar xzf glade5_linux64_ub20.tar
Then I did set up the environment like instructed: export GLADE_HOME=/home/me/build/glade5_linux64_ub20 export PATH=$GLADE_HOME/bin:$PATH
and could start glade
but it failed with: glade: error while loading shared libraries: libicui18n.so.66: cannot open shared object file: No such file or directory
It seems it is very specifically built for that version of Ubuntu which has this libicui18n.so.66
I haven’t got much hope that you can make this work here.
It would be possible if it could be built from source, but I don’t think they provide that.
Just tested it out of curiosity.
It works in the current Linux Mint.
Of course in Ubuntu as well.
The probably easiest way is to spin up a Mint or Ubuntu VM with Gnome Boxes
or with Virtualbox (which is a bit more involved)
and use the program that way.
