Kernel: 6.1.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1 Desktop: GNOME v: 44.3
Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05 serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <superuser required>
UEFI-[Legacy]: LENOVO v: EUCN19WW date: 05/12/2020
ID-1: BAT0 charge: 42.5 Wh (100.0%) condition: 42.5/60.0 Wh (70.9%) volts: 17.2 min: 15.4
model: Celxpert L19C4PC0 status: full
Info: 8-core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2
rev: 1 cache: L1: 512 KiB L2: 4 MiB L3: 8 MiB
Speed (MHz): avg: 1779 high: 3599 min/max: 1400/2900 boost: enabled cores: 1: 1848 2: 1722
3: 1648 4: 1400 5: 1632 6: 1400 7: 1400 8: 1723 9: 1400 10: 1400 11: 2671 12: 3599 13: 1975
14: 1400 15: 1859 16: 1400 bogomips: 92660
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo driver: nvidia v: 535.54.03
arch: Turing bus-ID: 01:00.0
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 bus-ID: 05:00.0
temp: 51.0 C
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB bus-ID: 1-3:2
Display: x11 server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2 driver: X:
loaded: amdgpu,nvidia dri: radeonsi gpu: amdgpu resolution: 1920x1080~120Hz
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A bus-ID: 05:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 05:00.6
API: ALSA v: k6.1.38-1-MANJARO status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 0.3.73 status: active
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169
v: kernel port: 2000 bus-ID: 03:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
IF: wlp4s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB bus-ID: 3-3:3
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 414.43 GiB (86.9%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L2 size: 476.94 GiB temp: 48.9 C
ID-1: / size: 459.72 GiB used: 414.42 GiB (90.1%) fs: ext4 dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 8.8 GiB used: 5.5 MiB (0.1%) dev: /dev/nvme0n1p2
System Temperatures: cpu: 64.0 C mobo: N/A gpu: amdgpu temp: 51.0 C
Processes: 363 Uptime: 7h 42m Memory: total: 16 GiB note: est. available: 15 GiB
used: 5.88 GiB (39.2%) Init: systemd Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1725
Client: gnome-shell v: 44.3 inxi: 3.3.28
After the recent update I can no longer use the compose key with ~ and n to make ñ. What can I do/check to make it work again?
