Help loading program with Wine
#1
Hi guys, I’m trying to use Manjaro + Wine to launch a program from windows server as client.
The problem is the Windows shortcut is: \10.0.0.1\program\program.exe 10.0.0.1
And I can’t create something like that to work with wine. The program failed to load due server IP as arguments in the end.
I have mounted smb://10.0.0.1/program to /home/user/program and it is fine.
So I created a launcher with command:
  1. wineconsole /home/user/program/program.exe - shortcut error!.
  2. wineconsole /home/user/program/program.exe 10.0.0.1 - file not found!.
  3. /run/user/1000/gvfs/smb-share:server=10.0.0.1,share=program/program.exe 10.0.0.1 - shortcut error!
  4. /run/user/1000/gvfs/smb-share:server=10.0.0.1,share=program/program.exe - file not found!
Any idea? I can’t launch the program without server IP argument.
Thanks
#2
Can you be more specific here?
If running wineconsole /home/user/program/program.exe works from a terminal, then it should work from a launcher.
It also might be useful to say which DE you’re using as each has a different way of creating a desktop launcher (unless you’re creating a .desktop file?).
#3
it doesn’t work from terminal too.
I’m using XFCE, by the way - sorry for missing that :wink:
#4
In what way?
Does it provide any error output?
#5
Tomorrow I will attach some screenshots.
Thanks
#6
Or you could just copy and paste the text instead…
#7
Sorry for delay but I was travelling this weekend.
First attempt using: wine /home/doctor/dental2008/dental2008.exe 192.169.2.201
Result: File not found
000b:fixme:ntdll:find_reg_tz_info Can't find matching timezone information in the registry for -03, bias 180, std (d/m/y): 18/02/2018, dlt (d/m/y): 4/11/2018
000d:fixme:ntdll:find_reg_tz_info Can't find matching timezone information in the registry for -03, bias 180, std (d/m/y): 18/02/2018, dlt (d/m/y): 4/11/2018
000f:fixme:ntdll:find_reg_tz_info Can't find matching timezone information in the registry for -03, bias 180, std (d/m/y): 18/02/2018, dlt (d/m/y): 4/11/2018
0012:fixme:ntdll:find_reg_tz_info Can't find matching timezone information in the registry for -03, bias 180, std (d/m/y): 18/02/2018, dlt (d/m/y): 4/11/2018
001c:fixme:ntdll:find_reg_tz_info Can't find matching timezone information in the registry for -03, bias 180, std (d/m/y): 18/02/2018, dlt (d/m/y): 4/11/2018
0021:fixme:ntdll:find_reg_tz_info Can't find matching timezone information in the registry for -03, bias 180, std (d/m/y): 18/02/2018, dlt (d/m/y): 4/11/2018
0023:fixme:ntdll:find_reg_tz_info Can't find matching timezone information in the registry for -03, bias 180, std (d/m/y): 18/02/2018, dlt (d/m/y): 4/11/2018
000d:err:menubuilder:convert_to_native_icon error 0x88982F50 creating IWICBitmapDecoder
0009:fixme:ntdll:find_reg_tz_info Can't find matching timezone information in the registry for -03, bias 180, std (d/m/y): 18/02/2018, dlt (d/m/y): 4/11/2018
0009:fixme:olepicture:OleLoadPictureEx (0x2146abc,12577,1,{7bf80980-bf32-101a-8bbb-00aa00300cab},x=0,y=0,f=0,0x32f1ac), partially implemented.
0009:err:olepicture:OleLoadPictureEx IPersistStream_Load failed
0009:fixme:olepicture:OleLoadPictureEx (0x2146abc,12577,1,{7bf80980-bf32-101a-8bbb-00aa00300cab},x=0,y=0,f=0,0x32faa0), partially implemented.
Second attempt using: wine /home/doctor/dental2008/dental2008.exe /home/doctor/dental2008
Third attempt using: wine /home/doctor/dental2008/dental2008.exe
Result: shortcut error
Any sugestion?
thanks
#8
Any tip?
#9
https://wiki.winehq.org/Wine_User's_Guide#How_to_run_Windows_programs_from_the_command_line
#10
same problem,
The problem is parsing Server IP as argument. Wine is not accepting it.
#11
WINE will pass any command-line arguments directly to the Windows executable, so I don’t know what’s wrong.
#12
The only problem I have with wine arguments is this beacause it is an IP. Other programs and their arguments (-t -u …) work flawless.
#13
So what happens when you run
wine start /unix "/home/doctor/dental2008/dental2008.exe" "192.169.2.201"
#14
[doctor@doctor-pc ~]$ 002e:fixme:ntdll:find_reg_tz_info Can't find matching timezone information in the registry for -03, bias 180, std (d/m/y): 18/02/2018, dlt (d/m/y): 4/11/2018
002e:fixme:olepicture:OleLoadPictureEx (0x2146abc,12577,1,{7bf80980-bf32-101a-8bbb-00aa00300cab},x=0,y=0,f=0,0x33f1ac), partially implemented.
002e:err:olepicture:OleLoadPictureEx IPersistStream_Load failed
002e:fixme:olepicture:OleLoadPictureEx (0x2146abc,12577,1,{7bf80980-bf32-101a-8bbb-00aa00300cab},x=0,y=0,f=0,0x33faa0), partially implemented.
and File not found as before.
BTW I have tried this using some instructions from wine manual :confused:
#15
What is producing this error? There is no error output in the above terminal output.
#16
Once I add 192.169.2.201 (server IP) as argument :confused:
If I dont use argument, I receive the error to fix the shorcut with server IP or hostname . you can see the print screen on post 7d (Help loading program with Wine) Third attempt
closed #17
