Kernel: 6.10.11-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
root=UUID=88e97bd3-d24e-4067-b187-da9e53363f40 rw nvidia_drm.fbdev=1 quiet
splash udev.log_priority=3
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Desktop Mobo: Micro-Star model: B550-A PRO (MS-7C56) v: 2.0
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: A.70 date: 06/23/2021
System RAM: total: 32 GiB available: 31.27 GiB used: 2.3 GiB (7.4%)
(unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: TeamGroup
part-no: UD4-3000 serial: <filter>
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMH16GX4M2E3200C16 serial: N/A
Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 2 microcode: 0xA201204
desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2200 min/max: 2200/4650 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200 3: 2200
4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
bogomips: 88841
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
affected
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: ZOTAC driver: nvidia
v: 550.120 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: DVI-D-1,HDMI-A-1 empty: DP-1 bus-ID: 2b:00.0
chip-ID: 10de:1f82 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3520x1080 s-dpi: 92 s-size: 972x301mm (38.27x11.85")
s-diag: 1018mm (40.06")
Monitor-1: DVI-D-1 mapped: DVI-D-0 note: disabled pos: primary,left
model: Sceptre C24 built: 2018 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.137
y: 0.059 white: x: 0.314 y: 0.329 size: 530x300mm (20.87x11.81")
diag: 609mm (24") ratio: 16:9 modes: 1920x1080, 1680x1050, 1600x900,
1280x1024, 1440x900, 1280x960, 1366x768, 1152x864, 1280x768, 1280x720,
1024x768, 800x600, 720x576, 720x480, 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: right
model: Sceptre E20 built: 2019 res: 1600x900 hz: 60 dpi: 99 gamma: 1.2
chroma: red: x: 0.659 y: 0.322 green: x: 0.275 y: 0.592 blue: x: 0.137
y: 0.106 white: x: 0.298 y: 0.345 size: 410x280mm (16.14x11.02")
diag: 496mm (19.5") ratio: 3:2 modes: 1600x900, 1280x1024, 1440x900,
1280x960, 1366x768, 1152x864, 1280x720, 1024x768, 800x600, 720x576,
720x480, 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.120
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
memory: 3.91 GiB
API: Vulkan v: 1.3.295 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: nvidia v: 550.120 device-ID: 10de:1f82
surfaces: xcb,xlib
Device-1: NVIDIA vendor: ZOTAC driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 2b:00.1 chip-ID: 10de:10fa class-ID: 0403
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.10.11-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 2a:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp42s0 state: down mac: <filter>
Device-2: NetGear A6210 driver: mt76x2u type: USB rev: 3.0 speed: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-3:2 chip-ID: 0846:9053 class-ID: 0000
serial: <filter>
IF: wlp45s0f3u3 state: up mac: <filter>
Local Storage: total: 931.51 GiB used: 232.54 GiB (25.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 232.54 GiB (25.4%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 88e97bd3-d24e-4067-b187-da9e53363f40
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 2D66-FF99
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-5:3 info: Pixart Imaging Gaming Mouse type: mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 093a:2530 class-ID: 0301
Device-2: 1-6:4 info: SONiX USB DEVICE type: keyboard,mouse
lanes: 1 mode: 1.1 power: 400mA chip-ID: 320f:5037 class-ID: 0301
Device-3: 1-7:5 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c56 class-ID: 0300
serial: <filter>
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Device-1: 4-3:2 info: NetGear A6210 type: Network driver: mt76x2u
interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
power: 800mA chip-ID: 0846:9053 class-ID: 0000 serial: <filter>
System Temperatures: cpu: 45.9 C mobo: N/A gpu: nvidia temp: 30 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 50%
Packages: 1323 pm: pacman pkgs: 1283 libs: 366 tools: pamac pm: flatpak
pkgs: 40
1: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
7: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 292
1: cpu: 8.3% command: firefox pid: 1149 mem: 537.2 MiB (1.6%)
2: cpu: 5.1% command: firefox pid: 1919 mem: 239.2 MiB (0.7%)
3: cpu: 1.7% command: zsh pid: 2096 mem: 10.0 MiB (0.0%)
4: cpu: 1.5% command: plasmashell pid: 768 mem: 493.9 MiB (1.5%)
5: cpu: 1.4% command: kwin_x11 pid: 745 mem: 233.9 MiB (0.7%)
Memory top: 5 of 292
1: mem: 537.2 MiB (1.6%) command: firefox pid: 1149 cpu: 8.3%
2: mem: 493.9 MiB (1.5%) command: plasmashell pid: 768 cpu: 1.5%
3: mem: 239.2 MiB (0.7%) command: firefox pid: 1919 cpu: 5.1%
4: mem: 233.9 MiB (0.7%) command: kwin_x11 pid: 745 cpu: 1.4%
5: mem: 186.1 MiB (0.5%) command: firefox pid: 1304 cpu: 1.3%
Processes: 292 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.32
running-in: konsole inxi: 3.3.36
Here’s the complete output of the command. I’m afraid I can only paste it while running the 1650, but using the rx6600 I did notice that it recognized the GPU and its temp/fans, which is probably a good thing!
