A couple of weeks back I set up a new Manjaro workstation using architect. During the installation process I selected systemd-boot
as the bootloader, but received a warning message to the effect of there being no functional bootloader present in the installation. So, I went back a few steps and installed grub
. Everything booted and appeared okay, so I thought nothing more of it. Recently, when updating the system via pacman -Syyu
I noticed that one of pacman’s hooks seemed to indicate that systemd-boot
was still present on the system somewhere. Sorry, I can’t be any more specific than this at the moment. The system is at my partner’s office, I don’t have remote access, and only get to use it for a few hours every couple of weeks. Could someone advise on how to completely remove systemd-boot
in this context, or let me know what outputs could prove helpful in finding where the problem lies.
Just uninstall it?
pamac remove systemd-boot-manager
Ah… well now I feel like an idiot. Tried running sudo pacman -R systemd-boot
before, but nothing was found. It didn’t occur to me that I might have the name wrong. I assumed something more complex was required.
Thank you. Will sort it next time I’m in.
Just had a chance to do this. Thank you for your help.
