Help for PHP install
Hello,
I am trying to install a program called OSPOS. https://github.com/opensourcepos/opensourcepos/wiki/Getting-Started-installations#local-deploy-install is the link to their installation guide steps. The require the following PHP stuff.
In Debian - php5-curl php5-mysql php5-gd php5-intl php5-openssl
In Fedora - php php-bcmath php-dba php-gd php-openssl
Anyone can help me with installing these PHP extensions on Manjaro. I tried to search for these extensions but failed to find them.
Currently I installed php following this guide https://archived.forum.manjaro.org/t/install-apache-mariadb-php-lamp-2016/1243
Blockquote 4. Install PHP
To install PHP run:
sudo pacman -S php php-apache
After PHP is installed, we need to configure Apache PHP module.
To do so, edit /etc/httpd/conf/httpd.conf file,
sudo nano /etc/httpd/conf/httpd.conf
Find the following line and comment it out:
#LoadModule mpm_event_module modules/mod_mpm_event.so
Uncomment or add the line:
LoadModule mpm_prefork_module modules/mod_mpm_prefork.so
Then, add the following lines at the bottom:
LoadModule php7_module modules/libphp7.so
AddHandler php7-script php
Include conf/extra/php7_module.conf
Save and close the file.
Test PHP
Now create a test.php file in the Apache root directory.
sudo nano /srv/http/test.php
Add the following lines:
<?php
phpinfo();
Restart httpd service.
sudo systemctl restart httpd
Open up your web browser and navigate to http://ip-address/test.php . You should the screen like
You just need php-gd and php-intl .
The other modules are part of the normal php package but need to be enabled in /etc/php/php.ini
You can check all enbaled modules with php -m or you read thru your php test.php page.
Hello xabbu, Thanks you for your reply, it was very helpful. I installed both and enabled all the other extensions required by the app also, but still i get only a blank page in the app. I am trying to get some help from the OSPOS team too.
we can use docker :wink:
