Hi everyone, I’m new to the forum and I recently installed Manjaro KDE and I must say that I’m very happy with it but I have a problem. I’m a fan of the game of Go and I would like to compile an engine called Katago to analyze my games in the opencl version. Someone can you help me to reach my goal thank you.
Hi @Emiya, and welcome!
There is a package katago-opencl
in the AUR:
$ pamac search katago
katago-opencl 1.11.0-1 AUR
Baduk engine with no human-provided knowledge.
So it might be as simple as building it from there:
pamac build katago-opencl
But first, you need to make sure your kernel headers are installed:
pamac install $(pamac list --installed --quiet | grep "^linux" | grep "^linux[0-9]*[-rt]*$" | awk '{print $1"-headers"}' ORS=' ')
This will install the headers for all currently installed kernels.
…as well as the base-devel
package:
pamac install base-devel
a Reminder:
While use of the AUR is possible, it’s neither recommended nor supported.
I recommend pamac
instead of pacman
, especially for newcomers as pamac
was developed by Manajaro (developers) for Manjaro and just takes care of more thing than pacman
Hope this helps!
Great I managed to compile engine but now another problem arises, the program I use lizzie if I start the engine asks me for the opencl drivers and I have installed the opencl-amd package installed I start the program and manjaro goes haywire by removing and Do you know how I can resolve this by replaying the video?
This is a separate issue. Please start a separate thread about that — hint: put it in the Graphics & Display category.
