Hello,
after the latest manjaro updates i missed the little shield in the tray bar.
I opened the gnome extension manager and saw that this extension had a error.
So i deinstalled the gnome-shell-extension-manjaro-update (7-2) using Pamac.
My idea was to reinstall it, but i can’t find it anymore. Where can i get it?
Hello,
You are looking for pamac-gnome-integration
package.
Edit:
On second thought it seems that now the extension is part of the pamac-gtk
package, and regardless of the DE installed, the /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org
will be present. So, if in Gnome, you just have to restart the shell and then enable the extension …
Thank you, but now i think i’am completely wrong.
I miss the following icon in the tray bar , and i thought it is part
of gnome-shell-extension-manjaro-update, but this seems not to be the case, because this extension uses the manjaro M as icon and seems to be the indicator for kernel updates.
Anyway i was able to reinstall the package from the cache using the following commandline.
sudo pacman -U /var/cache/pacman/pkg/gnome-shell-extension-manjaro-update-7-2-any.pkg.tar.xz
The extension still fails again, but this is another problem.
I,ve got the wanted tray icon back and this is like you said part of the pamac-gtk package.
I just had to switch it on again. Thank you.
