hello so i’m having some problems after latest update like right after i restarted the laptop after update it did not detected the wired conection any more, strage thing is it works with wifi any idea why and how to fix it?
impossible to answer - start by checking the [Stable Update] 2023-09-18 - Kernels, Mesa, Pipewire, Systemd, LibreOffice, KDE, Thunderbird - #2 by philm
what is the textual output from the command
inxi -Nxxxc0
paste the result inbetween a code fence like this
~~~ $ inxi -Nxxxc0 Network: Device-1: Aquantia AQC107 NBase-T/IEEE 802.3bz Ethernet [AQtion] vendor: Lenovo driver: atlantic v: kernel pcie: speed: 8 GT/s lanes: 4 port: N/A bus-ID: 01:00.0 chip-ID: 1d6a:07b1 class-ID: 0200 temp: 67.1 C ~~~
Can you post ip -a
on console ?
I had exactly that problem also. Apparently it was due to my router being reset. I was able to fix it by manually redoing router settings. See here:
[quote=“[Stable Update] 2023-09-18 - Kernels, Mesa, Pipewire, Systemd, LibreOffice, KDE, Thunderbird, post:22, topic:148194”]
ed that the update had succeeded without a hitch; however, on restarting my computer, it would no-longer recognize my router. Both the wired ethernet connection (which is what I normally use) and the both of my wireless networks (2.4GHz & 5.0GHz, both from the same router as my wired network) were all invisible. Even attempting to connect Firefox to “192.168.63.72” in order to check the configuration of my router also failed; I got “there is n…
[/quote]
Might be totally unrelated, but I had to switch my VPN from wireguard to openvpn to get my network working.
yeah thx but i reinstaled the system again i think it woss kernel related it give me vm something error i reverted to the LTS kernel but kept geting erors so i moved from manjaro xfce to kde sice i wanted to see whats it like, but still have some wierd stuf i can not install red shift says gt something not detected and it does not apear in aps in app instaler apears instald any idea why in xfce i have not had that problem, but in kde hapens?
