Hello how do i post without starting a new topic
Tips for posting
Use a “keyword search” to make sure your question has not already been asked. For example “failed to verify key” or “sound is muted”.
Make sure you include enough detail so people know what you are running. A useful command is inxi -Fxz; copy and paste the text and format as “code” (e.g. use the </> button above).
If possible, paste text rather than upload a photo. Text is easier to read, searchable, and takes up less space on the server. Please don’t upload high-resolution photos.
For more information read this post: How to provide good information in your posts
Remember to remove all of this help text before you post.
click the green “reply” button at the bottom of the topic you want to post on.
thanks
[aries@aries-pc ~]$ inxi -Fxz
  Host: aries-pc Kernel: 4.14.67-1-MANJARO x86_64 bits: 64 compiler: gcc
  v: 8.2.0 Desktop: N/A Distro: Manjaro Linux
  Type: Desktop System: Hewlett-Packard product: HP Pro 3500 Series v: N/A
  serial: <filter>
  Mobo: Foxconn model: 2ABF v: 3.10 serial: <filter> BIOS: AMI v: 8.12
  date: 12/14/2012
  Topology: Dual Core model: Intel Core i3-3240 bits: 64 type: MT MCP
  arch: Ivy Bridge rev: 9 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 27147
  Speed: 1597 MHz min/max: 1600/3400 MHz Core speeds (MHz): 1: 1596 2: 1596
  3: 1596 4: 1597
  Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics
  driver: i915 v: kernel bus ID: 00:02.0
  Display: x11 server: N/A driver: intel unloaded: modesetting
  resolution: <xdpyinfo missing>
  OpenGL: renderer: Mesa DRI Intel Ivybridge Desktop v: 4.2 Mesa 18.1.7
  direct render: Yes
  driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  Sound Server: ALSA v: k4.14.67-1-MANJARO
  Device-1: Ralink RT5390R 802.11bgn PCIe Wireless Network Adapter
  driver: rt2800pci v: 2.3.0 bus ID: 03:00
  driver: r8168 v: 8.045.08-NAPI port: e000 bus ID: 04:00
  IF: enp4s0 state: down mac: <filter>
  Local Storage: total: 1.36 TiB used: 25.04 GiB (1.8%)
  ID-1: /dev/sda type: USB vendor: Seagate model: Expansion size: 931.51 GiB
  ID-2: /dev/sdb type: USB vendor: Seagate model: ST500LM012 HN-M500MBB
  ID-1: / size: 907.77 GiB used: 14.42 GiB (1.6%) fs: ext4 dev: /dev/sda1
  ID-2: swap-1 size: 8.24 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
  System Temperatures: cpu: 29.8 C mobo: 27.8 C
  Processes: 163 Uptime: 1d 38m Memory: 3.75 GiB used: 1.46 GiB (39.0%)
  Init: systemd Compilers: gcc: 8.2.0 Shell: bash v: 4.4.23 inxi: 3.0.21
[aries@aries-pc ~]$
OK now you need to edit your original post to tell us what your problem is. Click on the pencil icon at bottom to edit your post. Then do the same to edit your title.
Welcome to the forum.
