Hearing a lot of bad noise when no audio is playing (on battery)
Hello,
I usually have headphones on, but whenever the system is not charging and no audio being played, I hear a lot of bad noise, which forces me take the headphones on and off all the time.
Is there any fix for this?
Thanks.
Is the noise constant, or is there a short burst of noise some time after audio stops playing?
Please post system information
inxi -Fazy
and PulseAudio information for audio devices
pacmd list-cards
The noise is constant, with some intermittent beep sounds in the middle.
  Kernel: 5.9.3-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
  root=UUID=73036dd4-76d9-492e-ab0f-055ca28fa40e rw pcie_aspm=off
  intel_idle.max_cstate=1 quiet apparmor=1 security=apparmor
  resume=UUID=866158db-e867-41da-b8af-91b73b6302cd udev.log_priority=3
  Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
  dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Laptop System: ASUSTeK product: N552VW v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: N552VW v: 1.0 serial: <filter>
  UEFI: American Megatrends v: N552VW.304 date: 05/08/2019
  ID-1: BAT0 charge: 4.5 Wh condition: 26.6/47.5 Wh (56%) volts: 14.4/14.4
  model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Charging
  cycles: 1366
  Info: Quad Core model: Intel Core i7-6700HQ bits: 64 type: MT MCP
  arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: D6
  L2 cache: 6144 KiB
  bogomips: 41621
  Speed: 901 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 900 2: 901 3: 900
  4: 900 5: 900 6: 900 7: 901 8: 900
  Type: l1tf
  Type: srbds status: Vulnerable: No microcode
  Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
  Device-1: Intel HD Graphics 530 vendor: ASUSTeK driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:191b
  Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: ASUSTeK driver: nouveau
  v: kernel bus ID: 01:00.0 chip ID: 10de:139b
  Device-3: Chicony HD WebCam (Asus N-series) type: USB driver: uvcvideo
  bus ID: 1-4:2 chip ID: 04f2:b3fd serial: <filter>
  Display: x11 server: X.Org 1.20.9 driver: intel,nouveau
  unloaded: modesetting alternate: fbdev,nv,vesa display ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
  s-diag: 583mm (23")
  Monitor-1: HDMI2 res: 1920x1080 hz: 60 dpi: 102 size: 480x270mm (18.9x10.6")
  diag: 551mm (21.7")
  OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 20.2.1
  direct render: Yes
  Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a170
  Sound Server: ALSA v: k5.9.3-1-MANJARO
  Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: e000
  bus ID: 02:00.0 chip ID: 8086:095a
  vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus ID: 03:00.1
  chip ID: 10ec:8168
  IF: enp3s0f1 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 1.94 TiB used: 50.84 GiB (2.6%)
  ID-1: /dev/sda vendor: Samsung model: MZNLF128HCHP-00004 size: 119.24 GiB
  block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
  rev: 301Q scheme: GPT
  ID-2: /dev/sdb vendor: Seagate model: ST2000LM003 HN-M201RAD size: 1.82 TiB
  block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  rotation: 5400 rpm serial: <filter> rev: 0001 scheme: GPT
  ID-1: / raw size: 106.19 GiB size: 104.02 GiB (97.96%)
  used: 50.84 GiB (48.9%) fs: ext4 dev: /dev/sda2
  ID-1: swap-1 type: partition size: 12.76 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/sda3
  System Temperatures: cpu: 42.0 C mobo: N/A gpu: nouveau temp: 38.0 C
  Fan Speeds (RPM): cpu: 2000
  Processes: 278 Uptime: 1h 38m Memory: 11.60 GiB used: 2.99 GiB (25.7%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1333 pacman: 1327
  lib: 379 flatpak: 0 snap: 6 Shell: Bash v: 5.0.18 running in: xfce4-terminal
  inxi: 3.1.08
1 card(s) available.
    index: 0
	driver: <module-alsa-card.c>
	owner module: 6
	properties:
		alsa.card = "0"
		alsa.long_card_name = "HDA Intel PCH at 0xdf428000 irq 142"
		sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
		device.bus = "pci"
		device.vendor.id = "8086"
		device.product.id = "a170"
		device.product.name = "100 Series/C230 Series Chipset Family HD Audio Controller"
		device.string = "0"
		device.description = "Built-in Audio"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
	profiles:
		input:analog-stereo: Analog Stereo Input (priority 65, available: unknown)
		output:analog-stereo: Analog Stereo Output (priority 6500, available: unknown)
		output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 6565, available: unknown)
		output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
		output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (priority 5965, available: no)
		output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
		output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI) Output + Analog Stereo Input (priority 865, available: no)
		output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
		output:hdmi-surround71+input:analog-stereo: Digital Surround 7.1 (HDMI) Output + Analog Stereo Input (priority 865, available: no)
		output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
		output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2) Output + Analog Stereo Input (priority 5765, available: no)
		output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
		output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: no)
		output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
		output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: no)
		output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
		output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3) Output + Analog Stereo Input (priority 5765, available: no)
		output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
		output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: no)
		output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
		output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: no)
		output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
		output:hdmi-stereo-extra3+input:analog-stereo: Digital Stereo (HDMI 4) Output + Analog Stereo Input (priority 5765, available: no)
		output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
		output:hdmi-surround-extra3+input:analog-stereo: Digital Surround 5.1 (HDMI 4) Output + Analog Stereo Input (priority 665, available: no)
		output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
		output:hdmi-surround71-extra3+input:analog-stereo: Digital Surround 7.1 (HDMI 4) Output + Analog Stereo Input (priority 665, available: no)
		off: Off (priority 0, available: unknown)
	active profile: <output:analog-stereo+input:analog-stereo>
	sinks:
		alsa_output.pci-0000_00_1f.3.analog-stereo/#0: Built-in Audio Analog Stereo
	sources:
		alsa_output.pci-0000_00_1f.3.analog-stereo.monitor/#0: Monitor of Built-in Audio Analog Stereo
		alsa_input.pci-0000_00_1f.3.analog-stereo/#1: Built-in Audio Analog Stereo
	ports:
		analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 0 usec, available: unknown)
			properties:
		analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: no)
			properties:
		analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: no)
			properties:
		analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: yes)
			properties:
		hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
			properties:
		hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
			properties:
		hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
			properties:
		hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
			properties:
This Asus laptop has been mentioned by Manjaro users on the old forum, but not usually in connection with an audio problem
Search results for ‘N552VW’ - Manjaro Archived Forum
the sort of noise you describe might be coming from the internal microphone
please post response to
amixer --card=0
to show audio level settings
I finally found the source of the problem, I have a USB mouse connected to the laptop which causes both the constant noise and the intermittent beep (whenever the mouse moves).
The strange part is that plugging the charger (or playing audio) magically mutes all of it.
Just in case, here’s:
amixer - -card=0
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Playback channels: Mono
  Limits: Playback 0 - 87
  Mono: Playback 75 [86%] [-9.00dB] [on]
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch
  Mono:
  Front Left: Playback 87 [100%] [0.00dB] [on]
  Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Speaker',0
  Mono:
  Front Left: Playback 0 [0%] [-65.25dB] [off]
  Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Mic',0
  Limits: Playback 0 - 31
  Mono:
  Front Left: Playback 0 [0%] [-34.50dB] [off]
  Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Mic Boost',0
  Capabilities: volume
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Mono: Playback [off]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
Simple mixer control 'IEC958',3
  Mono: Playback [on]
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 63
  Front Left: Capture 63 [100%] [30.00dB] [on]
  Front Right: Capture 63 [100%] [30.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Enabled'
Simple mixer control 'Internal Mic Boost',0
  Limits: 0 - 3
  Front Left: 1 [33%] [10.00dB]
  Front Right: 1 [33%] [10.00dB]
Simple mixer control 'Loopback Mixing',0
  Capabilities: enum
  Item0: 'Disabled'
Update, Ad-hoc solution:
For now connecting the USB mouse to the USB port on the opposite side of the headphone jack, resolves the problem.
I was looking in alsamixer to see if audio playback from the microphone was unmuted and turned up in alsamixer, but it is not
you appear to have found the cause of the problem with the mouse and USB socket
a different mouse might not cause the same audio interference
replacing the laptop battery might supply better power to the system to prevent this happening
but switching to another USB socket works without replacing anything
I’m not sure since this was a while ago, but I guess on Windows, either the audio driver or the system prevented this from happening, so is there any way to force the system to do this?
There is this suggestion from Archwiki to turn off power saving for the audio device
Pops when starting and stopping playback | Advanced Linux Sound Architecture | ArchWiki
modprobe snd_hda_intel power_save=0
but this may not work for you with constant noise source
This may help to keep the audio device active by creating an inaudible subsonic audio stream
pacmd load-module module-sine frequency=1
and set the volume of this module to 0 so it does not affect other audio streams
pacmd set-sink-input-volume $(LANG=C pacmd list-sink-inputs | grep -B 1 "driver: <module-sine.c>" | grep index | sed 's/[^0-9]//g') 0
