My pc is: ASRock > DeskMini A300 Series
with:
Audio
- 1 x Head Phone with Mic Jack
- 1 x Mic-In
- Realtek ALC233
Before upgrade Pulseaudio 14.0, there’s no problem with my headphone mic.
I’ve try to follow the arch wiki :Advanced Linux Sound Architecture - ArchWiki
Correctly detect microphone plugged in a 4-pin 3.5mm (TRRS) jack
On some modern laptops you may have a combined 3.5mm headset jack, instead of two separated ones, which may not be correctly detected by default. To make ALSA correctly detect plug-in status on your 3.5mm jack, you could put the following line into your /etc/modprobe.d/alsa-base.conf
options snd_hda_intel index=0 model=[YOUR_MODEL_SETTING]
For a complete list of options to put in [YOUR_MODEL_SETTING]
, see HD-Audio Codec-Specific Models. Tested with Gigabyte Aero15 2017 (P65 Model), with ALC255 and set model to dell-headset-multi
But, I’m confuse, because there’s no /etc/modprobe.d/alsa-base.conf
file in /etc/modprobe.d folder. Should I make a new file alsa-base.conf
and
enter: options snd_hda_intel index=0 model=[headset-mic]
Any suggestion are welcome.
Thank you
Anton
