Hello, I’ve just installed Manjaro XFCE on my HP ENVY Touchsmart 14 k-012x. However, I’m facing an ongoing issue with getting headphones to work:
- Even without headphones, only the right hand side speaker of the laptop works. This means you can’t hear the left channel of stereo sound when listening to audio.
- When headphones are plugged in, they aren’t detected by PulseAudio, and if I play audio, it comes from the laptop speakers and not the headphones.
I’m only mentioning point 1 for context. For now, I’d just appreciate your help in fixing point 2, and I’ll create a separate post for point 1 if needed.
FYI, my laptop has a dual 3.5mm input/output slot for headphone. Do let me know if there’s any further information I can share to give you more detailed info about the problem.
Thanks!
