Hello,
used manjaro for half a year without major problems until resently, when my headphone jack stopped working (works perfectly fine in windows). So I switched to bluetooth and just a few minutes ago bluetooth vanished from the laptop … ( again went to windows and no problem everything works there). Has anybody an idea how I can activate the headphone jack and why did it deactivate itself in the first place?
some command with information I found in this forum for audio issue:
output
Type: Laptop System: LENOVO product: 20NECTO1WW v: ThinkPad E495
serial: Chassis: type: 10 serial:
Mobo: LENOVO model: 20NECTO1WW serial: UEFI: LENOVO
v: R11ET44W (1.24 ) date: 01/26/2022
output
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Lenovo ThinkPad E595 driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Lenovo ThinkPad E595 driver: snd_pci_acp3x v: kernel
alternate: snd_rn_pci_acp3x,snd_pci_acp5x pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo ThinkPad E595
bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
Output
Configuration dump generated at Mon Mar 21 17:23:50 2022
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id=“0” name=“pci-0000_05_00.1” card_name=“alsa_card.pci-0000_05_00.1” namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties=“module-udev-detect.discovered=1”
load-module module-alsa-card device_id=“1” name=“pci-0000_05_00.6” card_name=“alsa_card.pci-0000_05_00.6” namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties=“module-udev-detect.discovered=1”
load-module module-jackdbus-detect channels=2
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-x11-publish display=:0 xauthority=/home/johannes/.Xauthority
load-module module-x11-xsmp display=:0 xauthority=/home/johannes/.Xauthority session_manager=local/Zen1Plus:@/tmp/.ICE-unix/738,unix/Zen1Plus:/tmp/.ICE-unix/738
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_05_00.1.hdmi-stereo-extra1 0x10000
set-sink-mute alsa_output.pci-0000_05_00.1.hdmi-stereo-extra1 no
suspend-sink alsa_output.pci-0000_05_00.1.hdmi-stereo-extra1 yes
set-sink-volume alsa_output.pci-0000_05_00.6.analog-stereo 0x5973
set-sink-mute alsa_output.pci-0000_05_00.6.analog-stereo no
suspend-sink alsa_output.pci-0000_05_00.6.analog-stereo yes
set-source-volume alsa_output.pci-0000_05_00.1.hdmi-stereo-extra1.monitor 0x10000
set-source-mute alsa_output.pci-0000_05_00.1.hdmi-stereo-extra1.monitor no
suspend-source alsa_output.pci-0000_05_00.1.hdmi-stereo-extra1.monitor yes
set-source-volume alsa_output.pci-0000_05_00.6.analog-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_05_00.6.analog-stereo.monitor no
suspend-source alsa_output.pci-0000_05_00.6.analog-stereo.monitor yes
set-source-volume alsa_input.pci-0000_05_00.6.analog-stereo 0xffff
set-source-mute alsa_input.pci-0000_05_00.6.analog-stereo yes
suspend-source alsa_input.pci-0000_05_00.6.analog-stereo yes
set-card-profile alsa_card.pci-0000_05_00.1 output:hdmi-stereo-extra1
set-card-profile alsa_card.pci-0000_05_00.6 output:analog-stereo+input:analog-stereo
set-default-sink alsa_output.pci-0000_05_00.6.analog-stereo
set-default-source alsa_input.pci-0000_05_00.6.analog-stereo
EOF
regarding bluetooth sudo systemctl start bluetooth
didn’t do anything:
Summary
bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: inactive (dead)
Docs: man:bluetoothd(8)
Mär 21 17:28:00 Zen1Plus systemd[1]: Bluetooth service was skipped because of a failed condition check (ConditionPathIsDirect>
