Hi everyone. I am having trouble with a segfault which keeps preventing me from being able to boot up. It started the other day when a family member had a frozen screen, which was the second time in the last couple of weeks that the computer did this. As with the first time, I proceeded to restart the computer, only unlike the first time, it did not work and I got the segfault error. The following is from the most recent start up attempt:
[ 94.084804] systemd[1]: segfault at 7ffdd0a48a88 ip 00007f68e04b5388 sp 00007ffdd0a48a88 error 6 in libsystemd-shared-255.2-2.so[7f68e0319000+287000]
[ 94.086201] Code: ff 15 8c 69 20 00 66 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 55 48 89 e5 41 57 41 56 41 55 41 54 53 48 81 ec 00 10 00 00 <48> 83 0c 24 00 48 81 ec 98 01 00 00 89 bd 7c ee ff ff 89 f3 4d 89
[ 94.088391] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000008b
[ 94.091713] CPU: 3 PID: 1 Comm: systemd Not tainted 5.10.206-1-MANJARO #1
[ 94.091713] Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./B450M Pro4, BIOS P1.60 11/05/2018
[ 94.091713] Call Trace:
[ 94.091713] dump_stack+0x6b/0x83
[ 94.091713] panic+0x11a/0x2ee
[ 94.091713] do_exit.cold+0x2c/0xb3
[ 94.091713] do_group_exit+0x33/0xa0
[ 94.091713] get_signal+0x107/0x8f0
[ 94.091713] arch_do_signal_or_restart+0xb3/0x740
[ 94.091713] exit_to_user_mode_prepare+0xd0/0x160
[ 94.091713] ? asm_exc_page_fault+0x8/0x30
[ 94.091713] irqentry_exit_to_user_mode+0x5/0x20
[ 94.091713] asm_exc_page_fault+0x1e/0x30
[ 94.091713] RIP: 0033:0x7f68e04b5388
[ 94.091713] Code: ff 15 8c 69 20 00 66 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 55 48 89 e5 41 57 41 56 41 55 41 54 53 48 81 ec 00 10 00 00 <48> 83 0c 24 00 48 81 ec 98 01 00 00 89 bd 7c ee ff ff 89 f3 4d 89
[ 94.091713] RSP: 002b:00007ffdd0a48a88 EFLAGS: 00010206
[ 94.091713] RAX: 0000000000000000 RBX: 00007ffdd049ba0 RCX: 000000000000006f
[ 94.091713] RDX: 0000564922533612 RSI: 0000000000000000 RDI: 0000000000000000
[ 94.091713] RBP: 00007ffdd0a49ab0 R08: 0000564922536ce2 R09: 0000564922533940
[ 94.091713] R10: 0000000000000000 R11: 0000000000000246 R12: 00000000e00cc860
[ 94.091713] R13: 00007ffdd0a49ba8 R14: 0000000000000923 R15: 0000564922533612
[ 94.091713] Kernel Offset: 0x39a00000 from 0xffffffff81000000 (relocation range: 0xffffffff80000000-0xffffffffbfffffff)
[ 94.091713] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000008b ]---
Things I have tried:
Replaced ram (ran old sticks through Memtest86+ v.7 and they were bad). New ram didn’t help (ran them through a few passes of Memtest and they’re good), but it did spit out some more information during the boot process than the old ram did.
Tried booting using different kernels: 6.6.10-1-MANJARO x64, 6.1.71-1-MANJARO x64, 5.15.146-1-MANJARO x64, 5.10.206-1-MANJARO x64.
Tried editing the run-levels.
Tried using a live USB and chroot to access my system but received this:
[manjaro@manjaro ~]$ manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/sda1]
--> mount: [/mnt]
[manjaro /]#
At this point I don’t know where to turn next so I am hoping someone can help out. Thanks and much appreciation in advance.
