i’m trying to use the hdmi port of my laptop. but apparently only the intel gpu is being used.
there is no option in my bios to disable the intel gpu(but you can disable the ati gpu).
from what i read i might need to use reverse prime. i ran these without any error:
xrandr --setprovideroutputsource "Radeon 540X Series @ pci:0000:02:00.0" Intel
xrandr --output HDMI1 --auto --above LVDS1
but there is nothing displayed in the hdmi display. output of xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
eDP1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 340mm x 190mm
1920x1080 60.06*+
DP1 disconnected (normal left inverted right x axis y axis)
HDMI1 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
output of sudo mhwd
> 0000:03:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
NAME VERSION FREEDRIVER TYPE
network-r8168 2016.04.20 true PCI
> 0000:02:00.0 (0380:1002:6987) Display controller ATI Technologies Inc:
> 0000:00:02.0 (0300:8086:8a56) Display controller Intel Corporation:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
