HDMI/LAN adapter for Laptop with USB-C
Hi,
currently I use an UGreen adapter, that I connect to a USB-c connector, to extend my laptop with a second screen and a LAN connection.
The LAN connection is using an AX88179 which makes for about 1-2 weeks problems, that it does not work anymore.
It is detected but ip a shows the interface as down. Sometimes if I disconnect and connect it again it works and it also starts working sometime if I just wait 10-90 minutes:
Bus 003 Device 031: ID 0b95:1790 ASIX Electronics Corp. AX88179 Gigabit Ethernet
I’m not sure if that is a problem that was introduced by an update or if this is maybe a hardware problem.
Can anyone recommend maybe a connector that has USB-c to connect to the laptop and at least HDMI and LAN (having more USB ports is also welcome, but not required), which works fine with Manjaro XFCE?
Waiting for others to blindly ask questions can be counter-productive – typically, nobody has a :crystal_ball: at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
Highly Recommended
Technical Resources
Required Reading
Topic closed (forum rules violation).
See #11: Product Recommendation Requests
