Kernel: 6.5.13-7-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=4e18be9d-1c64-41af-8e57-e7ca2cf5b6ee rw quiet apparmor=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: light-locker dm: LightDM v: 1.32.0 Distro: Manjaro
base: Arch Linux
Type: Desktop System: Shuttle product: DS81D v: V1.0 serial: N/A
Mobo: Shuttle model: FS81 v: 1.0 serial: <filter> part-nu: 1.0
uuid: 03000200-0400-0500-0006-000700080009 UEFI: American Megatrends v: 3.14
date: 09/17/2018
Device-1: hid-36:11:5c:33:02:3a-battery model: Bluetooth 5.1 Keyboard
serial: N/A charge: N/A status: discharging
System RAM: total: 16 GiB available: 15.51 GiB used: 3.76 GiB (24.2%)
igpu: 64 MiB
Array-1: capacity: 32 GiB slots: 4 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
speed: 1600 MT/s volts: curr: 1.5 min: 1.35 max: 1.5 width (bits): data: 64
total: 64 manufacturer: Crucial part-no: CT102464BF160B.C16
serial: <filter>
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
serial: <filter>
Device-4: ChannelB-DIMM1 type: no module installed
Slot: 0 type: PCIe lanes: 16 status: in use info: J6B2 length: long
volts: 3.3 bus-ID: 00:01.0
Slot: 1 type: PCIe lanes: 1 status: in use info: J6B1 length: short
volts: 3.3 bus-ID: 00:1c.3 children: 1: 03:00.0 class-ID: 0200 type: network
Slot: 2 type: PCIe lanes: 1 status: in use info: J6D1 length: short
volts: 3.3 bus-ID: 00:1c.4
Slot: 3 type: PCIe lanes: 1 status: in use info: J7B1 length: short
volts: 3.3 bus-ID: 00:1c.5
Slot: 4 type: PCIe lanes: 1 status: in use info: J8B4 length: short
volts: 3.3 bus-ID: 00:1c.6
Info: model: Intel Core i7-4785T socket: BGA1155 bits: 64 type: MT MCP
arch: Haswell gen: core 4 level: v3 note: check built: 2013-15
process: Intel 22nm family: 6 model-id: 0x3C (60) stepping: 3
microcode: 0x28
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1381 high: 2195 min/max: 800/3200 base/boost: 2200/3800
scaling: driver: intel_cpufreq governor: schedutil volts: 1.2 V
ext-clock: 100 MHz cores: 1: 800 2: 800 3: 2175 4: 1300 5: 2195 6: 800
7: 800 8: 2183 bogomips: 35132
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Holco Enterprise Co /Shuttle driver: i915 v: kernel arch: Gen-7.5
process: Intel 22nm built: 2013 ports: active: DP-1,HDMI-A-3 empty: DP-2,
HDMI-A-1, HDMI-A-2, VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0412 class-ID: 0300
Display: x11 server: X.Org v: 21.1.12 with: Xwayland v: 23.2.6
compositor: xfwm4 v: 4.18.0 driver: X: loaded: modesetting
alternate: fbdev,vesa dri: crocus gpu: i915 display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: DP-1 pos: primary,right model: 100027813 serial: <filter>
built: 2021 res: 1920x1080 hz: 60 dpi: 80 gamma: 1.2 chroma: red: x: 0.651
y: 0.329 green: x: 0.318 y: 0.620 blue: x: 0.149 y: 0.071 white: x: 0.314
y: 0.329 size: 609x348mm (23.98x13.7") diag: 690mm (27.2") ratio: 16:9
modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800,
1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480, 640x480,
720x400
Monitor-2: HDMI-A-3 mapped: HDMI-3 pos: left model: 100094417
serial: <filter> built: 2022 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2 chroma:
red: x: 0.651 y: 0.329 green: x: 0.318 y: 0.620 blue: x: 0.149 y: 0.071
white: x: 0.314 y: 0.329 size: 598x336mm (23.54x13.23") diag: 685mm (27")
ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960,
1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576,
720x480, 640x480, 720x400
API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
device: 1 drv: swrast surfaceless: drv: crocus x11: drv: crocus
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4600 (HSW GT2)
device-ID: 8086:0412 memory: 1.46 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 4600 (HSW GT2) driver: mesa intel v: 24.0.2-manjaro1.1
device-ID: 8086:0412 surfaces: xcb,xlib
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Holco
Enterprise Co /Shuttle 8 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
API: ALSA v: k6.5.13-7-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: n/a (root, process)
with: pipewire-media-session status: active tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
vendor: Holco Enterprise Co /Shuttle RTL8111/8168/8411 driver: r8169
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0
Info: services: mld, NetworkManager, systemd-timesyncd
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-6:5
chip-ID: 0a12:0001 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0
lmp-v: 6 status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 1.49 TiB used: 442.46 GiB (29.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Fanxiang model: S301 512GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 195 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 045 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 model: Mass Storage Device size: 119.08 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 112.44 GiB size: 110.37 GiB (98.16%) used: 59 GiB (53.5%)
fs: ext4 block-size: 4096 B dev: /dev/sda4 maj-min: 8:4 label: Manjaro
uuid: 4e18be9d-1c64-41af-8e57-e7ca2cf5b6ee
ID-2: /boot/efi raw-size: 1.79 GiB size: 1.78 GiB (99.80%)
used: 53.9 MiB (2.9%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
label: N/A uuid: 80E5-D996
ID-3: /home raw-size: 430.78 GiB size: 422.95 GiB (98.18%)
used: 177.17 GiB (41.9%) fs: ext4 block-size: 4096 B dev: /dev/sdb1
maj-min: 8:17 label: home uuid: bfa899b9-f545-4ead-a125-da3138006af5
ID-4: /run/media/gnuorder/Camera raw-size: 119.08 GiB
size: 119.08 GiB (100.00%) used: 54.65 GiB (45.9%) fs: exfat
block-size: 512 B dev: /dev/sdc1 maj-min: 8:33 label: Camera
uuid: E0D1-C26C
ID-5: /run/media/windows10 raw-size: 160.45 GiB size: 160.45 GiB (100.00%)
used: 151.59 GiB (94.5%) fs: ntfs block-size: 4096 B dev: /dev/sda3
maj-min: 8:3 label: Windows 10 uuid: 5208F48108F464FF
ID-1: swap-1 type: partition size: 32.22 GiB used: 512 KiB (0.0%)
priority: -2 dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: 53407d13-0072-41a0-ac00-e7ab77c673cf
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-2: /dev/sda5 maj-min: 8:5 size: 79.77 GiB fs: ext4 label: Ubuntu
uuid: 0ce37a6d-d76f-4599-ae2e-a701a9836721
ID-3: /dev/sdb4 maj-min: 8:20 size: 500.7 GiB fs: ntfs label: N/A
uuid: 0E3C0AAA0E3C0AAA
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8008
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 10 rev: 2.0
Hub-6: 3-2:2 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 chip-ID: 045b:0209 class-ID: 0900
Hub-7: 3-2.1:4 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
Device-1: 3-2.1.2:8 info: T & A Mobile Phones TCL TAB 8 LE
type: <vendor specific> driver: usbfs interfaces: 1 rev: 2.0
chip-ID: 1bbb:0c01 class-ID: 0000 serial: <filter>
Device-2: 3-2.1.3:10 info: Super Top microSD card reader (SY-T18)
type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
chip-ID: 14cd:1212 class-ID: 0806 serial: <filter>
Device-3: 3-2.1.4:13 info: T & A Mobile Phones Alcatel JOY TAB 2
chip-ID: 1bbb:201c class-ID: 0000 serial: <filter>
Device-4: 3-5:3 info: Areson Corp 2.4G Wireless Receiver
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 25a7:fa10 class-ID: 0301
Device-5: 3-6:5 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-8: 3-7:9 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 3-8:11 info: Genesys Logic GL827L SD/MMC/MS Flash Card Reader
chip-ID: 05e3:0723 class-ID: 0806
Hub-9: 4-0:1 info: super-speed hub ports: 2 rev: 3.0
Hub-10: 4-2:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 chip-ID: 045b:0210 class-ID: 0900
Hub-11: 4-2.1:3 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
System Temperatures: cpu: 56.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 2076 libs: 525 tools: pamac,yay pm: flatpak
pkgs: 0
1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
2: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
3: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
4: https://mirror.init7.net/manjaro/stable/$repo/$arch
5: https://mirrors.netix.net/manjaro/stable/$repo/$arch
6: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
7: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
8: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
Processes:
CPU top: 5 of 267
1: cpu: 10.4% command: Xorg pid: 1211 mem: 151.9 MiB (0.9%)
2: cpu: 6.4% command: scrcpy pid: 2420 mem: 137.8 MiB (0.8%)
3: cpu: 5.4% command: firefox pid: 4701 mem: 720.4 MiB (4.5%)
4: cpu: 4.0% command: baloo_file pid: 1763 mem: 40.3 MiB (0.2%)
5: cpu: 3.4% command: adb pid: 2408 mem: 13.0 MiB (0.0%)
Memory top: 5 of 267
1: mem: 720.4 MiB (4.5%) command: firefox pid: 4701 cpu: 5.4%
2: mem: 319.1 MiB (2.0%) command: firefox pid: 6607 cpu: 2.8%
3: mem: 296.4 MiB (1.8%) command: firefox pid: 12998 cpu: 2.0%
4: mem: 231.2 MiB (1.4%) command: firefox pid: 8281 cpu: 0.3%
5: mem: 218.4 MiB (1.3%) command: firefox pid: 4945 cpu: 1.0%
Processes: 267 Power: uptime: 20h 13m states: freeze,standby,mem,disk
suspend: s2idle avail: shallow wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.2 GiB
services: upowerd,xfce4-power-manager Init: systemd v: 255
Compilers: clang: 16.0.6 gcc: 13.2.1 alt: 12 Shell: Sudo (sudo) v: 1.9.15p5
default: Bash v: 5.2.26 running-in: xfce4-terminal inxi: 3.3.34
