HDMI 4K issue, occasional blank/black screen
First, is this a good place to post this issue? Or, if it’s looking like driver investigation is needed, should I post to kernel dot org?
I won’t drop all the hardware specs jet, but can do.
I’m using a newish laptop with Intel Iris Plus Graphics G7.
I have 2 problems, I’ll mention the second one for interest, I don’t know if it’s going to be related.
issue 1
Using the laptop, lid closed with an external monitor, HDMI, 3840x2160 at 60Hz.
The display (HDMI output) is mostly working fine.
But, for about the first 15 mins of uptime, the screen (signal I assume) will drop to blank/black, for a second or two, come back for a bit, and repeat.
No pattern, just short drop-outs.
It seams to settle after a few minutes, but I can’t be 100% sure, I’ve only had this monitor for a couple of days. NB. This also happened on another 4K monitor I tried, again, just for a couple of days.
If anyone would like to look into it, just let me know and we can share tech. stuff.
Thanks.
ps. issue 2
Using gimp, taking a screen shot will not grab the ‘current’ screen.
That is, when using the laptop screen.
It will grab a desktop background, but some old one (maybe the boot background) and with no windows.
I just tried it on the external HDMI screen, and it worked fine.
When the signal goes away, please run journalctl -b0 and check if you can see any messages around the time the issue occurred.
Thanks @pobrn - here it is as my ‘user’ account, let me know if you want it run as root?
$ uptime
 15:32:15 up  1:28,  1 user,  load average: 1.10, 0.52, 0.67
So boot time was about 14:04:
$ journalctl -b0
Hint: You are currently not seeing messages from other users and the system.
      Users in groups 'adm', 'systemd-journal', 'wheel' can see all messages.
      Pass -q to turn off this notice.
-- Logs begin at Thu 2020-07-09 18:20:07 EDT, end at Sun 2020-10-11 15:30:29 EDT. --
Oct 11 14:04:22 grommet9 systemd[1271]: /home/coach/.config/autostart/xcape.desktop:9: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Oct 11 14:04:22 grommet9 systemd[1271]: Configuration file /home/coach/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Oct 11 14:04:22 grommet9 systemd[1271]: Configuration file /home/coach/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Oct 11 14:04:22 grommet9 systemd[1271]: /home/coach/.config/autostart/xfce-pbw.sh:2: Assignment outside of section. Ignoring.
Oct 11 14:04:22 grommet9 systemd[1271]: /home/coach/.config/autostart/xfce-pbw.sh:3: Assignment outside of section. Ignoring.
Oct 11 14:04:22 grommet9 systemd[1271]: /home/coach/.config/autostart/xfce-pbw.sh:4: Assignment outside of section. Ignoring.
Oct 11 14:04:22 grommet9 systemd[1271]: /home/coach/.config/autostart/xfce-pbw.sh:5: Assignment outside of section. Ignoring.
Oct 11 14:04:22 grommet9 systemd[1271]: /home/coach/.config/autostart/xfce-pbw.sh:6: Assignment outside of section. Ignoring.
Oct 11 14:04:22 grommet9 systemd[1271]: /home/coach/.config/autostart/xfce-pbw.sh:7: Assignment outside of section. Ignoring.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-blueman-autostart.service, it is hidden.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Rfkill-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-xapp\x2dsn\x2dwatcher-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Smartcard-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Wwan-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-light\x2dlocker-autostart.service, it is hidden.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-gnome\x2dkeyring\x2dsecrets-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Datetime-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-pulseaudio-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-compiz\x2dxfce\x2dautostart\x2dsetup-autostart.service, it is hidden.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Power-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-xfce\x2duser\x2dlogin\x2dscript-autostart.service, it is hidden.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-at\x2dspi\x2ddbus\x2dbus-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Keyboard-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.MediaKeys-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Wacom-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-xfce4\x2dsettings\x2dhelper\x2dautostart-autostart.service, it is hidden.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Sound-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-gnome\x2dkeyring\x2dpkcs11-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Housekeeping-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-xfce4\x2dnotes\x2dautostart-autostart.service, it is hidden.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-msm_notifier-autostart.service, it is hidden.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-xfce\x2dpbw.sh-autostart.service, only Type=Application is supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-xfconf\x2dmigration\x2d4.6-autostart.service, it is hidden.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-gnome\x2dkeyring\x2dssh-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.XSettings-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-xfce4\x2dclipman\x2dplugin\x2dautostart-autostart.service, only Type=Application is supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.A11ySettings-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-xscreensaver-autostart.service, only Type=Application is supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.UsbProtection-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.PrintNotifications-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Color-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.ScreensaverProxy-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Sharing-autostart.service, startup phases are not supported.
Oct 11 14:04:22 grommet9 systemd[1271]: Not generating service for XDG autostart app-xfce4\x2dtips\x2dautostart-autostart.service, it is hidden.
Oct 11 14:04:22 grommet9 systemd[1263]: Queued start job for default target Main User Target.
Oct 11 14:04:22 grommet9 systemd[1263]: Reached target Paths.
Oct 11 14:04:22 grommet9 systemd[1263]: Reached target Timers.
Oct 11 14:04:22 grommet9 systemd[1263]: Starting D-Bus User Message Bus Socket.
Oct 11 14:04:22 grommet9 systemd[1263]: Listening on GnuPG network certificate management daemon.
Oct 11 14:04:22 grommet9 systemd[1263]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Oct 11 14:04:22 grommet9 systemd[1263]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Oct 11 14:04:22 grommet9 systemd[1263]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Oct 11 14:04:22 grommet9 systemd[1263]: Listening on GnuPG cryptographic agent and passphrase cache.
Oct 11 14:04:22 grommet9 systemd[1263]: Listening on p11-kit server.
Oct 11 14:04:22 grommet9 systemd[1263]: Listening on Multimedia System.
Oct 11 14:04:22 grommet9 systemd[1263]: Listening on Sound System.
Oct 11 14:04:22 grommet9 systemd[1263]: Listening on D-Bus User Message Bus Socket.
Oct 11 14:04:22 grommet9 systemd[1263]: Reached target Sockets.
Oct 11 14:04:22 grommet9 systemd[1263]: Reached target Basic System.
Oct 11 14:04:22 grommet9 systemd[1263]: Starting Update XDG user dir configuration...
Oct 11 14:04:22 grommet9 systemd[1263]: xdg-user-dirs-update.service: Succeeded.
Oct 11 14:04:22 grommet9 systemd[1263]: Finished Update XDG user dir configuration.
Oct 11 14:04:22 grommet9 systemd[1263]: Reached target Main User Target.
Oct 11 14:04:22 grommet9 systemd[1263]: Startup finished in 58ms.
Oct 11 14:04:22 grommet9 systemd[1263]: Started D-Bus User Message Bus.
Oct 11 14:04:22 grommet9 dbus-daemon[1285]: [session uid=1001 pid=1285] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.1' (uid=1001 pid=1283 comm="flatpak --installations " label="unconfined")
Oct 11 14:04:22 grommet9 systemd[1263]: Starting Virtual filesystem service...
Oct 11 14:04:22 grommet9 dbus-daemon[1285]: [session uid=1001 pid=1285] Successfully activated service 'org.gtk.vfs.Daemon'
Oct 11 14:04:22 grommet9 systemd[1263]: Started Virtual filesystem service.
Oct 11 14:04:22 grommet9 dbus-daemon[1285]: [session uid=1001 pid=1285] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.8' (uid=1001 pid=1279 comm="xfce4-session " label="unconfined")
Oct 11 14:04:22 grommet9 systemd[1263]: Starting Accessibility services bus...
Oct 11 14:04:22 grommet9 dbus-daemon[1285]: [session uid=1001 pid=1285] Successfully activated service 'org.a11y.Bus'
Oct 11 14:04:22 grommet9 systemd[1263]: Started Accessibility services bus.
Oct 11 14:04:22 grommet9 dbus-daemon[1285]: [session uid=1001 pid=1285] Activating service name='org.xfce.Xfconf' requested by ':1.7' (uid=1001 pid=1279 comm="xfce4-session " label="unconfined")
Oct 11 14:04:22 grommet9 dbus-daemon[1285]: [session uid=1001 pid=1285] Successfully activated service 'org.xfce.Xfconf'
Oct 11 14:04:22 grommet9 at-spi-bus-launcher[1320]: dbus-daemon[1320]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=1001 pid=1279 comm="xfce4-session " label="unconfined")
Oct 11 14:04:22 grommet9 at-spi-bus-launcher[1320]: dbus-daemon[1320]: Successfully activated service 'org.a11y.atspi.Registry'
Oct 11 14:04:22 grommet9 at-spi-bus-launcher[1328]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Oct 11 14:04:22 grommet9 systemd[1263]: Started GnuPG cryptographic agent and passphrase cache.
Oct 11 14:04:22 grommet9 gpg-agent[1336]: gpg-agent (GnuPG) 2.2.23 starting in supervised mode.
Oct 11 14:04:22 grommet9 gpg-agent[1336]: using fd 3 for extra socket (/run/user/1001/gnupg/S.gpg-agent.extra)
Oct 11 14:04:22 grommet9 gpg-agent[1336]: using fd 4 for ssh socket (/run/user/1001/gnupg/S.gpg-agent.ssh)
Oct 11 14:04:22 grommet9 gpg-agent[1336]: using fd 5 for std socket (/run/user/1001/gnupg/S.gpg-agent)
Oct 11 14:04:22 grommet9 gpg-agent[1336]: using fd 6 for browser socket (/run/user/1001/gnupg/S.gpg-agent.browser)
Oct 11 14:04:22 grommet9 gpg-agent[1336]: listening on: std=5 extra=3 browser=6 ssh=4
Oct 11 14:04:23 grommet9 systemd[1263]: Starting Sound Service...
Oct 11 14:04:23 grommet9 dbus-daemon[1285]: [session uid=1001 pid=1285] Activating service name='org.freedesktop.thumbnails.Thumbnailer1' requested by ':1.19' (uid=1001 pid=1367 comm="xfdesktop " label="unconfined")
Oct 11 14:04:23 grommet9 org.freedesktop.thumbnails.Thumbnailer1[1383]: Registered thumbnailer ffmpegthumbnailer -i %i -o %o -s %s -f
Oct 11 14:04:23 grommet9 org.freedesktop.thumbnails.Thumbnailer1[1383]: Registered thumbnailer /usr/bin/gdk-pixbuf-thumbnailer -s %s %u %o
Oct 11 14:04:23 grommet9 org.freedesktop.thumbnails.Thumbnailer1[1383]: Registered thumbnailer gsf-office-thumbnailer -i %i -o %o -s %s
Oct 11 14:04:23 grommet9 org.freedesktop.thumbnails.Thumbnailer1[1383]: Registered thumbnailer heif-thumbnailer -s %s %i %o
Oct 11 14:04:23 grommet9 dbus-daemon[1285]: [session uid=1001 pid=1285] Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service' requested by ':1.22' (uid=1001 pid=1383 comm="/usr/lib/tumbler-1/tumblerd " label="unconfined")
Oct 11 14:04:23 grommet9 systemd[1263]: Starting Virtual filesystem service - disk device monitor...
Oct 11 14:04:23 grommet9 dbus-daemon[1285]: [session uid=1001 pid=1285] Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
Oct 11 14:04:23 grommet9 systemd[1263]: Started Virtual filesystem service - disk device monitor.
Oct 11 14:04:23 grommet9 dbus-daemon[1285]: [session uid=1001 pid=1285] Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service' requested by ':1.22' (uid=1001 pid=1383 comm="/usr/lib/tumbler-1/tumblerd " label="unconfined")
Oct 11 14:04:23 grommet9 systemd[1263]: Starting Virtual filesystem service - Apple File Conduit monitor...
Oct 11 14:04:23 grommet9 dbus-daemon[1285]: [session uid=1001 pid=1285] Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
Oct 11 14:04:23 grommet9 systemd[1263]: Started Virtual filesystem service - Apple File Conduit monitor.
Oct 11 14:04:23 grommet9 dbus-daemon[1285]: [session uid=1001 pid=1285] Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service' requested by ':1.22' (uid=1001 pid=1383 comm="/usr/lib/tumbler-1/tumblerd " label="unconfined")
Oct 11 14:04:23 grommet9 systemd[1263]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
Oct 11 14:04:23 grommet9 dbus-daemon[1285]: [session uid=1001 pid=1285] Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
Oct 11 14:04:23 grommet9 systemd[1263]: Started Virtual filesystem service - Media Transfer Protocol monitor.
Oct 11 14:04:23 grommet9 dbus-daemon[1285]: [session uid=1001 pid=1285] Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service' requested by ':1.22' (uid=1001 pid=1383 comm="/usr/lib/tumbler-1/tumblerd " label="unconfined")
Oct 11 14:04:23 grommet9 systemd[1263]: Starting Virtual filesystem service - digital camera monitor...
Oct 11 14:04:23 grommet9 dbus-daemon[1285]: [session uid=1001 pid=1285] Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
Oct 11 14:04:23 grommet9 systemd[1263]: Started Virtual filesystem service - digital camera monitor.
Oct 11 14:04:23 grommet9 dbus-daemon[1285]: [session uid=1001 pid=1285] Successfully activated service 'org.freedesktop.thumbnails.Thumbnailer1'
Oct 11 14:04:23 grommet9 systemd[1263]: Started Sound Service.
Oct 11 14:04:32 grommet9 systemd[1263]: run-user-969-gvfs.mount: Succeeded.
Oct 11 14:04:32 grommet9 systemd[1263]: run-user-969.mount: Succeeded.
Oct 11 14:34:17 grommet9 dbus-daemon[1285]: [session uid=1001 pid=1285] Activating service name='ca.desrt.dconf' requested by ':1.66' (uid=1001 pid=14177 comm="mousepad " label="unconfined")
Oct 11 14:34:17 grommet9 dbus-daemon[1285]: [session uid=1001 pid=1285] Successfully activated service 'ca.desrt.dconf'
Oct 11 15:30:29 grommet9 systemd[1263]: tmp-sanity\x2dmountpoint\x2d676693948.mount: Succeeded.
It seems you need to run it as root. By the way, if you remember when this happened, then you can run journalctl and find the date and time.
It just did it while I was reading your reply, at about 15:50:
[grommet9 ~]# journalctl -b0
Oct 11 15:50:24 grommet9 systemd[1]: Starting Snap Daemon...
Oct 11 15:50:24 grommet9 snapd[45455]: AppArmor status: apparmor is enabled and all features are available
Oct 11 15:50:24 grommet9 snapd[45455]: daemon.go:343: started snapd/2.46-1 (series 16; classic) manjaro/ (amd64) linux/5.9.0-1-MANJARO.
Oct 11 15:50:24 grommet9 snapd[45455]: daemon.go:436: adjusting startup timeout by 30s (pessimistic estimate of 30s plus 5s per snap)
Oct 11 15:50:24 grommet9 systemd[1263]: tmp-sanity\x2dmountpoint\x2d214046632.mount: Succeeded.
Oct 11 15:50:24 grommet9 systemd[1]: tmp-sanity\x2dmountpoint\x2d214046632.mount: Succeeded.
Oct 11 15:50:24 grommet9 systemd[1]: Started Snap Daemon.
Oct 11 15:50:24 grommet9 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 11 15:50:24 grommet9 kernel: audit: type=1130 audit(1602445824.690:122): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 11 15:50:29 grommet9 snapd[45455]: daemon.go:542: gracefully waiting for running hooks
Oct 11 15:50:29 grommet9 snapd[45455]: daemon.go:544: done waiting for running hooks
Oct 11 15:50:29 grommet9 snapd[45455]: daemon stop requested to wait for socket activation
Oct 11 15:50:29 grommet9 systemd[1]: snapd.service: Succeeded.
Oct 11 15:50:29 grommet9 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 11 15:50:29 grommet9 kernel: audit: type=1131 audit(1602445829.690:123): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 11 15:50:59 grommet9 rtkit-daemon[1496]: Supervising 6 threads of 4 processes of 1 users.
Oct 11 15:51:01 grommet9 anacron[26078]: Job `cron.daily' started
Oct 11 15:51:01 grommet9 anacron[26078]: Job `cron.daily' terminated
Oct 11 15:51:01 grommet9 anacron[26078]: Normal exit (1 job run)
Oct 11 15:51:40 grommet9 audit[46297]: USER_AUTH pid=46297 uid=1001 auid=1001 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=grommet9 addr=? terminal=pts/0 res=success'
Oct 11 15:51:40 grommet9 kernel: audit: type=1100 audit(1602445900.667:124): pid=46297 uid=1001 auid=1001 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=grommet9 addr=? terminal=pts/0 res=success'
Oct 11 15:51:40 grommet9 kernel: audit: type=1101 audit(1602445900.667:125): pid=46297 uid=1001 auid=1001 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=grommet9 addr=? terminal=pts/0 res=success'
Oct 11 15:51:40 grommet9 kernel: audit: type=1103 audit(1602445900.667:126): pid=46297 uid=1001 auid=1001 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=grommet9 addr=? terminal=pts/0 res=success'
Oct 11 15:51:40 grommet9 kernel: audit: type=1105 audit(1602445900.667:127): pid=46297 uid=1001 auid=1001 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=grommet9 addr=? terminal=pts/0 res=success'
Oct 11 15:51:40 grommet9 audit[46297]: USER_ACCT pid=46297 uid=1001 auid=1001 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=grommet9 addr=? terminal=pts/0 res=success'
Oct 11 15:51:40 grommet9 audit[46297]: CRED_ACQ pid=46297 uid=1001 auid=1001 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=grommet9 addr=? terminal=pts/0 res=success'
Oct 11 15:51:40 grommet9 audit[46297]: USER_START pid=46297 uid=1001 auid=1001 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=grommet9 addr=? terminal=pts/0 res=success'
Oct 11 15:51:40 grommet9 su[46297]: (to root) coach on pts/0
Oct 11 15:51:40 grommet9 su[46297]: pam_unix(su-l:session): session opened for user root(uid=0) by (uid=1001)
Oct 11 15:51:40 grommet9 systemd[1]: Starting Snap Daemon...
Oct 11 15:51:40 grommet9 snapd[46357]: AppArmor status: apparmor is enabled and all features are available
Oct 11 15:51:40 grommet9 snapd[46357]: daemon.go:343: started snapd/2.46-1 (series 16; classic) manjaro/ (amd64) linux/5.9.0-1-MANJARO.
Oct 11 15:51:40 grommet9 snapd[46357]: daemon.go:436: adjusting startup timeout by 30s (pessimistic estimate of 30s plus 5s per snap)
Oct 11 15:51:40 grommet9 systemd[1]: tmp-sanity\x2dmountpoint\x2d000366510.mount: Succeeded.
Oct 11 15:51:40 grommet9 systemd[1263]: tmp-sanity\x2dmountpoint\x2d000366510.mount: Succeeded.
Oct 11 15:51:40 grommet9 systemd[1]: Started Snap Daemon.
Oct 11 15:51:40 grommet9 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 11 15:51:40 grommet9 kernel: audit: type=1130 audit(1602445900.847:128): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 11 15:51:45 grommet9 snapd[46357]: daemon.go:542: gracefully waiting for running hooks
Oct 11 15:51:45 grommet9 snapd[46357]: daemon.go:544: done waiting for running hooks
Oct 11 15:51:45 grommet9 snapd[46357]: daemon stop requested to wait for socket activation
Oct 11 15:51:45 grommet9 systemd[1]: snapd.service: Succeeded.
Oct 11 15:51:45 grommet9 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 11 15:51:45 grommet9 kernel: audit: type=1131 audit(1602445905.850:129): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Do you see anything to look into?
I just did a cold login, it blanked for a second, ran ’ journalctl -b0’ - nothing.
Not a line.
Other FYI: have run this laptop with a 1440 HDMI screen, no problems at all.
It’s just at 4K, it will blank a bit.
I cannot see anything relevant in the log regarding the first issue. Have you eliminated most hardware issues? (faulty cable, connector, etc.) Please post the output of inxi -Gazy.
# inxi -Gazy
  Device-1: Intel Iris Plus Graphics G7 vendor: Lenovo driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:8a52
  Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus ID: 3-6:5
  chip ID: 5986:2130
  Display: server: X.org 1.20.9 compositor: compiz v: 0.9.14.1 driver: intel
  unloaded: modesetting alternate: fbdev,vesa tty: 382x110
  Message: Advanced graphics data unavailable in console for root.
re: other hardware issues
This is the second monitor it’s happened on, so I doubt it’s the monitor.
I can try swapping the HDMI cable - that was a problem on another machine/setup, but it was a problem with ‘red dots’ over the picture, so the cable can be a problem.
Have you tried the modesetting Xorg driver?
I played a video for about 3 hours last night, with a higher quality HDMI cable, and I didn’t see any glitches at all.
So I think that’s a ‘solved’ - it was the HDMI cable.
Additional thoughts for anyone finding this thread:
My ‘bad’ HDMI cable was rated at 4K.
I would not have expected this kind of failure/problem, being due to a bad cable.
I would have expected:
not working at all
artifacts in the picture
but random blanking did surprise me.
So there you have it, the quality of an HDMI cable can have more effect on the picture than you think.
Thanks @pobrn for the suggestion - I did know to try changing all the parts in a system, but as I’ve said, I had not thought the cable could create this kind of problem.
‘user’ version:
$ inxi -Gazy
  chip ID: 5986:2130
  Display: x11 server: X.Org 1.20.9 compositor: compiz v: 0.9.14.1
  driver: intel unloaded: modesetting alternate: fbdev,vesa display ID: :0.0
  screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x572mm (40.0x22.5")
  s-diag: 1166mm (45.9")
  Monitor-1: HDMI1 res: 3840x2160 hz: 60 dpi: 139 size: 700x390mm (27.6x15.4")
  diag: 801mm (31.5")
  OpenGL: renderer: Mesa Intel Iris Plus Graphics (ICL GT2) v: 4.6 Mesa 20.1.8
  direct render: Yes
