The built-in webcam does not work, it used to work. When I run cheese from the terminal it crashes the following errors:
(cheese:3845): Gtk-WARNING **: 15:44:29.332: Calling org.xfce.Session.Manager.Inhibit failed: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: Brak metody „Inhibit” (cheese:3845): cheese-WARNING **: 15:44:29.426: Nie udał się odczyt z zasobu.: …/gst-plugins-good/sys/v4l2/gstv4l2bufferpool.c(1132): gst_v4l2_buffer_pool_poll (): /GstCameraBin:camerabin/GstWrapperCameraBinSrc:camera_source/GstBin:bin35/GstV4l2Src:v4l2src1: poll error 1: Nie ma takiego urządzenia (19)
Inxi:
Device-1: Intel HD Graphics 5500 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:1616 class ID: 0300
Device-2: NVIDIA GK208BM [GeForce 920M] vendor: Dell driver: nvidia
v: 460.39 alternate: nouveau,nvidia_drm bus ID: 08:00.0 chip ID: 10de:1299
class ID: 0302
Device-3: Microdia Integrated Webcam type: USB driver: uvcvideo
bus ID: 2-5:2 chip ID: 0c45:6710 class ID: 0e02
Display: x11 server: X.Org 1.20.10 driver: loaded: modesetting,nvidia
unloaded: nouveau alternate: fbdev,intel,nv,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 112 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
QT V4L2 Test works normally. The problem is in cheese and discord
