Hi there. Last day, I changed my kernel, switched back to stable branch and downgraded all packages with pacman -Syyuu.
After that, I am having troubles updating AUR packages with pamac.
$ pamac update
Preparing...
Checking v4l2loopback-dc-dkms dependencies...
Checking python-bitarray dependencies...
Checking bitstower-markets dependencies...
Checking spotify-qt dependencies...
Checking typora dependencies...
Refreshing AUR...
Error: Failed to prepare transaction: target not found: droidcam
Edit build files : [e]
Apply transaction ? [e/y/N] y
Transaction cancelled.
Here’s the system info:
Kernel: 5.10.93-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=5aa960f9-3052-4c76-9257-1057f04b9522 rw quiet
resume=UUID=3af4b3a6-4df6-4288-ae08-99df3959dc81 udev.log_priority=3
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_wayland vt: 2 dm: SDDM
Type: Laptop System: Apple product: MacBookAir6,2 v: 1.0
serial: <superuser required> Chassis: type: 10 v: Mac-7DF21CB3ED6977E5
Mobo: Apple model: Mac-7DF21CB3ED6977E5 v: MacBookAir6,2
serial: <superuser required> UEFI: Apple v: 122.0.0.0.0 date: 06/10/2020
ID-1: BAT0 charge: 29.3 Wh (83.0%) condition: 35.3/54.3 Wh (64.9%)
volts: 8.2 min: 7.6 model: SMP bq20z451 type: Li-ion serial: N/A
status: Full cycles: 2672
RAM: total: 3.78 GiB used: 3.17 GiB (83.9%)
RAM Report:
Info: model: Intel Core i5-4250U bits: 64 type: MT MCP arch: Haswell
family: 6 model-id: 0x45 (69) stepping: 1 microcode: 0x26
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1103 high: 1300 min/max: 800/2600 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 966 2: 1278 3: 1300
4: 871 bogomips: 15204
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Apple driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0a26 class-ID: 0300
Display: wayland server: X.Org 1.21.1.4 compositor: kwin_wayland driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :1 screens: 1
Screen-1: 0 s-res: 1440x900 s-dpi: 96 s-size: 381x238mm (15.0x9.4")
s-diag: 449mm (17.7")
Monitor-1: XWAYLAND0 res: 1440x900 hz: 60 dpi: 126
size: 290x180mm (11.4x7.1") diag: 341mm (13.4")
Device-1: Intel Haswell-ULT HD Audio vendor: Apple driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
Device-3: Broadcom 720p FaceTime HD Camera driver: N/A bus-ID: 02:00.0
chip-ID: 14e4:1570 class-ID: 0480
Sound Server-1: ALSA v: k5.10.93-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.43 running: yes
Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter vendor: Apple
driver: wl v: kernel modules: bcma bus-ID: 03:00.0 chip-ID: 14e4:43a0
class-ID: 0280
Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb v: 0.8
bus-ID: 1-3.3:6 chip-ID: 05ac:828f class-ID: fe01
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 113 GiB used: 67.98 GiB (60.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0128F size: 113 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: EA1Q scheme: GPT
ID-1: / raw-size: 104.39 GiB size: 102.19 GiB (97.89%)
used: 66.08 GiB (64.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 5aa960f9-3052-4c76-9257-1057f04b9522
used: 150.4 MiB (50.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 9585-07E1
ID-1: swap-1 type: partition size: 8.31 GiB used: 1.76 GiB (21.2%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: 3af4b3a6-4df6-4288-ae08-99df3959dc81
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 9 rev: 2.0
Hub-2: 1-3:2
info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth) ports: 3
rev: 2.0 speed: 12 Mb/s power: 94mA chip-ID: 0a5c:4500 class-ID: 0900
Device-1: 1-3.3:6 info: Apple Bluetooth USB Host Controller
type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s
Device-2: 1-5:3 info: Apple Apple Internal Keyboard / Trackpad
type: HID,Keyboard,Mouse driver: apple,bcm5974,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 05ac:0291 class-ID: 0301
serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Device-1: 2-3:4 info: Apple Internal Memory Card Reader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 05ac:8406 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 63.0 C mobo: N/A
Processes: 255 Uptime: 1d 1h 26m wakeups: 6 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1598
pacman: 1583 lib: 384 flatpak: 15 Shell: Zsh v: 5.8 running-in: konsole
inxi: 3.3.12
