I’m trying to set Manjaro to use Mac keyboard shortcuts. For example, I’d like to be able cut/copy/paste using Command+X/C/V instead of Control.
Adding these shortcuts via the System Systems -> Shortcuts interface does nothing. It seems like it has added the shortcut, but the shortcuts still don’t actually work.
Also, I found “Import Shortcut Scheme” -> “Mac Scheme” which looked promising. I hoped that would set all of my shortcuts to their mac equivalents all at once. Unfortunately it seems to do nothing at all. I hit apply, and nothing changes with any of the shortcuts.
Thanks in advance for any help!
I’m running the current fully updated stable build: 5.9.16 x86_64 with KDE Plasma, and the default kernel.
