Hello,
I have very less idea about display managers. I have Nvidia proprietary card. But gnome wayland doesn’t play so well with it I think. I face issues like, screen recorders like SImple Screen recorder or Kazam not working properly, Blank screen after recording. After logging using Xorg, all the issue are solved. I just wanted to know, should I continue using Gnome xorg? I just don’t any issues with my desktop. My full system details are given below:
Machine: Type: Laptop System: HP product: HP ProBook 450 G5 v: N/A serial: <superuser/root required>
Mobo: HP model: 837D v: KBC Version 02.3D.00 serial: <superuser/root required> UEFI: HP v: Q85 Ver. 01.11.01
date: 04/27/2020
Battery: ID-1: BAT0 charge: 33.1 Wh condition: 41.9/41.9 Wh (100%)
CPU: Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP L2 cache: 6144 KiB
Speed: 800 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 799 2: 802 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Graphics: Device-1: Intel UHD Graphics 620 driver: i915 v: kernel
Device-2: NVIDIA GM108M [GeForce 930MX] driver: nvidia v: 455.45.01
Device-3: Chicony HP HD Camera type: USB driver: uvcvideo
Display: x11 server: X.org 1.20.9 driver: modesetting resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.2.3
Audio: Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel
Sound Server: ALSA v: k5.4.80-2-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: enp2s0 state: down mac: 10:e7:c6:dc:e7:16
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi
IF: wlp3s0 state: up mac: 74:e5:f9:06:7a:7f
Drives: Local Storage: total: 1.02 TiB used: 9.81 GiB (0.9%)
ID-1: /dev/sda vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB
ID-2: /dev/sdb vendor: HP model: SSD S700 120GB size: 111.79 GiB
Partition: ID-1: / size: 109.24 GiB used: 9.80 GiB (9.0%) fs: ext4 dev: /dev/sdb2
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 49.0 C mobo: 0.0 C
Info: Processes: 256 Uptime: 1h 18m Memory: 15.07 GiB used: 1.98 GiB (13.2%) Shell: Zsh inxi: 3.1.08```
