Having trouble finding CPU TDP in AC powered system
I’m running Manjaro on a relatively old PC with an i5 6th gen CPU. I’ve been trying to find out any power readings I can get since I run the PC 24/7.
I have tried the methods posted in
Unix & Linux Stack Exchange and so far I could only get the energy readings through cat /sys/class/powercap/*/energy_uj. Most of the solutions on that link are focused on laptops which provide procfs or sysfs files for installed batteries, and only one answer talked about reading power from ACPI. I tried that solution and installed powerstat from AUR but found this as its output (tail):
14:27:37   0.2  99.6   0.2   0.0   0.0    5    453   1390   0.00E
14:27:47   0.2  99.5   0.3   0.0   0.0    5    473   1398   0.00E
14:27:57   0.2  99.5   0.3   0.0   0.0    5    451   1395   0.00E
 Average   0.2  99.5   0.3   0.0   0.0  5.2  469.0 1396.6  -N/A-
 GeoMean   0.2  99.5   0.3   0.0   0.0  5.2  467.6 1396.4   0.00
  StdDev   0.0   0.1   0.1   0.0   0.0  0.4   39.9   19.8  -N/A-
 Minimum   0.1  99.2   0.2   0.0   0.0  5.0  434.5 1380.8  -N/A-
 Maximum   0.4  99.6   0.6   0.0   0.0  6.0  722.0 1523.1  -N/A-
Summary:
System:   0.00 Watts on average with standard deviation 0.00
This hints that there are no power sensors available!
Any advice would be of great help!
