Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
systemd.unified_cgroup_hierarchy=true amdgpu.ppfeaturemask=0xffffffff
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
Type: Desktop Mobo: Gigabyte model: B660 DS3H DDR4 v: x.x
Megatrends LLC. v: F3 date: 01/19/2022
Info: model: 12th Gen Intel Core i5-12400 bits: 64 type: MT MCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 5
microcode: 0x37
Device-1: Advanced Micro Devices [AMD/ATI] Navi 23 [Radeon RX 6600/6600
XT/6600M] vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-2
code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3,
Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:73ff class-ID: 0300
Display: x11 server: X.Org v: 21.1.14 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: BenQ EX240 serial: <filter>
built: 2022 res: 1920x1080 dpi: 93 gamma: 1.2 size: 526x296mm (20.71x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 720x400
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (radeonsi navi23
LLVM 18.1.8 DRM 3.59 6.12.4-1-MANJARO) device-ID: 1002:73ff
memory: 7.81 GiB unified: no
API: Vulkan v: 1.4.303 layers: 8 device: 0 type: discrete-gpu name: AMD
Radeon RX 6600 (RADV NAVI23) driver: N/A device-ID: 1002:73ff
surfaces: xcb,xlib
After playing Path of exile 2 for a while Freesync seem to eventually bug out and get monitor stuck at 28 hz, changing displays hz afterwards to anything above 60 hz just keeps it stuck at 28 hz, only restarting pc /changing to another user and then changing back again resets it back to 165 hz
I tried:
- /etc/X11/xorg.conf.d/20-amdgpu.conf
Option “VariableRefresh” “false”
Does not actually work
- adding the game(Path of Exile 2) executable to /usr/share/drirc.d/00-mesa-defaults.conf with
Did manage to disable freesync once on game launch, but then i could not reproduce it
Compositor is disabled
Freesync can’t be disabled in Monitor OSD settings
