Hi How can we get Manjaro in this tablet/pc
It have a Terga 3
Hello,
Not sure you can. Something that might give you some ideas can be read here:
Open Surface RT Home - Open Surface RT
Also this might clear things up even more
Linux on Surface RT - Make the Kernel boot
Oh Thanks you
Someone recently made me aware that systems using ARM does not have a BIOS as we know from the world of personal computers - PC for short.
That someone also stated that creating a usable boot configuration requires some intimate knowledge on how the system works.
To know how the system works - it requires some with the guts, knowledge and patience - did I mention patience - so if there is no inherent - obvious answers - doing an internet search β¦
then the answer is - you donβt.
Hmm OK then thanks for the reply
