Hi all, I’ve been researching all my possible issues these last few days. I’m trying to install MariaDB on my Manjaro Linux XFCE PC, and can’t seem to get anything working.
After installing MariaDB using sudo pacman -S mariadb.
I run: mariadb from the terminal and get this message:
ERROR 2002 (HY000): Can’t connect to local MySQL server through socket ‘/var/run/mysqld/mysqld.sock’ (111) which, when I check that directory I have an instance of a mysqld.sock as well as a mysqld.pid
So I try and run
systemctl start mariadb, which gives me:
Job for mariadb.service failed because the control process exited with error code.
I open up the sytemctl status mariadb.service and eventually read this:
Process: 10691 ExecStart= /usr/bin/mariadbd $MYSQLD_OPTS $WSREP_NEW_CLUSTER $WSREP_START_POSITION (code=exited, status=1/FAILURE)
I run systemctl enable mariadb, which gives me no return, which I interpret as a success but there’s no effect on those other commands and I can’t access mariadb.
I wonder if it’s because of systemd, but in my research I read that mariadb is looking for an init.d file in the usr/etc directory and I don’t seem to have one and it might be somewhere else due to running systemd.
At this point I’m lost as I’m not the most tech savvy fellow around and am just looking for some insight into how to possibly resolve my problem.
Any help would be greatly appreciated. Thanks.
