My computer had two disks. 1 SSD 2 HDD I installed Windows 11 on SSD. Now I want to install manjaro on same disk aa dual boot. I shrunk ssd volume to make space for Linux. But that SSD was not showing under Linux Live CD.
Windows is perfectly running on SSD.
What is wrong with this.
Have you switched off Fast startup in Windows? Otherwise the ssd remains in a hibernate mode as Windoze does not really shut down.
Iām not sure if Windoze 11 easily can be installed with Secure boot switched off, Secure boot could hinder Manjaro to boot, so you need to check first how you installed Windoze.
Still nothing happens
Did you check the bios of your computer? In some situations Fast Boot (set to ON in the bios) makes that Linux / Grub does not see the ssd / nvme drive.
Nothing happens
Not answering any question makes it impossible to help.
