Hello guys,
I installed hashcat from official repository, however I can not run it.
I am getting following error:
sudo hashcat -m 0 -a 0 -o ~/Documents/cracked.txt ~/Documents/hash_file.txt /home/tomas/Downloads/rockyou.txt 255 ✘
[sudo] password for tomas:
hashcat (v6.2.6) starting
clGetPlatformIDs(): CL_PLATFORM_NOT_FOUND_KHR
ATTENTION! No OpenCL, HIP or CUDA compatible platform found.
You are probably missing the OpenCL, CUDA or HIP runtime installation.
* AMD GPUs on Linux require this driver:
"AMDGPU" (21.50 or later) and "ROCm" (5.0 or later)
* Intel CPUs require this runtime:
"OpenCL Runtime for Intel Core and Intel Xeon Processors" (16.1.1 or later)
* NVIDIA GPUs require this runtime and/or driver (both):
"NVIDIA Driver" (440.64 or later)
"CUDA Toolkit" (9.0 or later)
Started: Mon Jul 17 11:35:50 2023
Stopped: Mon Jul 17 11:35:50 2023
sudo inxi -Fxxxmz ✔
Kernel: 5.15.120-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 dm: SDDM
Type: Laptop System: LENOVO product: 20236 v: Lenovo G500 serial: <filter>
Chassis: type: 10 v: Lenovo G500 serial: <filter>
Mobo: LENOVO model: INVALID v: 31900003WIN8 STD MLT serial: <filter>
UEFI: LENOVO v: 78CN25WW(V2.03) date: 11/19/2013
ID-1: BAT1 charge: 9.6 Wh (43.0%) condition: 22.3/40.4 Wh (55.1%)
power: 12.5 W volts: 10.6 min: 10.8 model: LENOVO PABAS0241231 type: Li-ion
serial: <filter> status: discharging
System RAM: total: 4 GiB available: 3.7 GiB used: 3.03 GiB (81.9%)
igpu: 64 MiB
Array-1: capacity: 16 GiB slots: 2 modules: 1 EC: None
max-module-size: 8 GiB
Device-1: DIMM0 info: single-bank type: DDR3 detail: synchronous
size: 4 GiB speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: SK-Hynix part-no: HMT451S6AFR8A-PB serial: <filter>
Device-2: DIMM1 type: no module installed
Info: dual core model: Intel Core i3-3110M bits: 64 type: MT MCP
smt: enabled arch: Ivy Bridge rev: 9 cache: L1: 128 KiB L2: 512 KiB
L3: 3 MiB
Speed (MHz): avg: 1236 high: 1344 min/max: 1200/2400 volts: 0.9 V
ext-clock: 100 MHz cores: 1: 1198 2: 1197 3: 1205 4: 1344 bogomips: 19167
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
v: kernel arch: Gen-7 ports: active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: AMD Mars [Radeon HD 8670A/8670M/8750M / R7 M370] vendor: Lenovo
driver: radeon v: kernel arch: GCN-1 pcie: speed: 5 GT/s lanes: 8
bus-ID: 01:00.0 chip-ID: 1002:6600 class-ID: 0380 temp: 45.0 C
Device-3: Realtek Lenovo EasyCamera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 bus-ID: 3-4:2 chip-ID: 0bda:5728 class-ID: 0e02
serial: <filter>
Display: server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting,radeon alternate: fbdev,vesa dri: crocus,radeonsi
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 model: Chi Mei Opto 0x15a7 res: 1366x768 hz: 60 dpi: 101
size: 344x193mm (13.54x7.6") diag: 398mm (15.7") modes: 1366x768
API: OpenGL v: 4.2 Mesa 23.0.4 renderer: Mesa Intel HD Graphics 4000 (IVB
GT2) direct-render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo 7
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
API: ALSA v: k5.15.120-1-MANJARO status: kernel-api with: aoss
type: oss-emulator
Server-1: sndiod v: N/A status: off
Server-2: JACK v: 1.9.22 status: off
Server-3: PipeWire v: 0.3.74 status: n/a (root, process)
with: pipewire-media-session status: active
Server-4: PulseAudio v: 16.1 status: active (root, process)
with: pulseaudio-alsa type: plugin
Device-1: Qualcomm Atheros QCA8172 Fast Ethernet vendor: Lenovo driver: alx
v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0
chip-ID: 1969:10a0 class-ID: 0200
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie:
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b1 class-ID: 0280
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 bus-ID: 1-1.3:3 chip-ID: 8087:07dc
class-ID: e001
Local Storage: total: 1.36 TiB used: 45.59 GiB (3.3%)
ID-1: /dev/sda vendor: Toshiba model: MQ02ABF050H size: 465.76 GiB
speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter> fw-rev: 1K scheme: GPT
ID-2: /dev/sdb vendor: Seagate model: ST1000LM014-1EJ164 size: 931.51 GiB
speed: 3.0 Gb/s tech: HDD rpm: 5400 serial: <filter> fw-rev: LVD1
scheme: GPT
ID-1: / size: 39.08 GiB used: 25.59 GiB (65.5%) fs: ext4 dev: /dev/sdb2
ID-2: /boot/efi size: 96 MiB used: 47.6 MiB (49.6%) fs: vfat
dev: /dev/sda2
ID-3: /home size: 58.76 GiB used: 19.93 GiB (33.9%) fs: ext4
dev: /dev/sdb3
ID-1: swap-1 type: partition size: 1024 MiB used: 28.7 MiB (2.8%)
priority: -2 dev: /dev/sdb1
System Temperatures: cpu: 51.0 C mobo: N/A gpu: radeon temp: 46.0 C
Processes: 212 Uptime: 15m wakeups: 1 Init: systemd v: 253
default: graphical Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1458
pm: pacman pkgs: 1443 pm: flatpak pkgs: 15 Shell: Sudo (sudo) v: 1.9.14p1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
Can you advise me, what and how I should install additionally, please ?
Thank you.
