I used the FluffyChat client for matrix chat. Recently, it wouldn’t start anymore. Starting from the terminal, it reported a missing dependency which I can’t remember. I uninstalled FluffyChat and tried to reinstall it. But fluffychat cannot be found with AUR enabled, neither with pacman nor with pamac, whereas it is still available here: AUR (en) - fluffychat
What is the reason for the removal?
Will fluffychat be available again?
Searching for “fluffy” with pamac, I was unable to find fluffychat in the repositories.
However, I found many fluffychat packages in the AUR:
$ pamac search fluffy
fluffychat-web-git 0.34.0.r726.g12cdee06-1 AUR
Chat with your friends
fluffychat-web-bin 1.1.0-1 AUR
fluffychat-web 1.1.0-1 AUR
fluffychat-git v0.34.0.r124.g62a68984-3 AUR
fluffychat-bin 1.1.0-2 AUR
fluffychat 1.1.0-1 AUR
And there is a -bin version. So you should be able to install it with:
Now FluffyChat can be installed perfectly. In the meanwhile, I tried a workaround: I started a XFCE session, tried the same, FluffyChat could be installed, logged off, started a Cinnamon session again, read your answers, trried pamac: everything is OK!
I don’t know what the reason for the described behavior had been.
