"Hard disk boot sector invalid" after installing manjaro x32bits
Hi folks,
I am trying to rescues my very-many-years-old Acer Aspire 2010 laptop. In order to do that I installed manjaro X32bits with xfce desktop from a DVD but whem I booted the screen shows the following message error:
I set up three partitions on MRB for /boot, /root and swap selecting the option -install bootloader in /boot partition- but it fails.
I also tried many other configurations during two days but everything fails.
I read in other threads that it is important to select flag esp for /boot partition. Is it so important and what does it means.
Do you have any idea about what it is wrong?
AS I already asked, why not install a 64bit Manjaro?
and
try installing the bootloader onto the drive and not a partition.
I also tried to select that option and I got the same message error.
I bought this laptop in 2007 therefore it is a x32 system not compatible with a OS x64 installation. Anyway I have tried before to install manjaro Kdex64 whem i discovered it is not suitable :joy:
You could try using Gparted from within your Manjaro installation media and create a new msdos partiton table (menubar > Device > Create Partition Table) and then partiton your disk again.
I do not understand how to make a MsDOS partition in order to create more partitions can restore the bootloader.
this. :point_up:
You don't need a separate /boot partition.
Even with a /boot partition, you have only 3 partitions.
You can use up to 4 partitions.
And if you need more...
this. :point_up:
but suggest you do this before installation not at installation.
A msdos disk can have 4 primary partitions or 3 primary partitions and 1 extended partition within it you can have many many logical partitions. gparted can let you do it. There is no practical limits on the number of partitions you can have.
Have you tried to read Manjaro User Guide? It is a PDF preinstalled on the Live environment or you can download it from https://manjaro.org/support/userguide/. IMO it is quite easy to precisely follow the BIOS path in it (not UEFI) and nothing wron should happen.
Yes, it is amazing but I also read the userguide trying to install again.
If you want to start with a "clean sheet" on your /dev/sda, once you are booted into your Manjaro Installation medium, open the menu and type gparted. Launch the application. When asked for password type:manjaro. When the app window opens: menu bar > Device > Create Partition Table. Choose: msdos.
Now, in gparted create the partiton(s) you want. You won't need a separate boot partition. When done start the installer and choose "manual partitoning" (or some such wording) point the installer to the partition(s) you have created. Install the grub to your drive /dev/sda and not a partition.
The User Guide also has a chapter about using GParted instead of Calamares for partitioning.
But IMO there are small details which the User Guide points you at like checking if you booted in the right mode (Legacy for MBR partition table or UEFI for GPT), whether you chose the correct device to install Grub.
@paeiro, if you want to reinstall, start the installer from the terminal to obtain a log which you can post here or at a pastebin service. Run sudo -E calamares -d
I have an old HP with the same problem. The solution was to install syslinux as the bootloader. You can do that by chrooting on the system.
I followed the instructions, given by Marte in the previous thread, in order to obtain a "clean sheet" making a new partition table in msdos. Them I create new partitions on Gparted and now I am going to install again using calamares from terminal so I obtain this log:
[manjaro@manjaro ~]$ sudo -E calamares -d
QStandardPaths: wrong ownership on runtime directory /run/user/1000, 1000 instead of 0
qt5ct: using qt5ct plugin
01:18:07 [6]: Using log file: "/home/manjaro/.cache/calamares/session.log"
01:18:07 [6]: Using Calamares QML directory "/usr/share/calamares/qml"
01:18:07 [6]: Using Calamares settings file at "/etc/calamares/settings.conf"
01:18:07 [2]: WARNING: Required settings.conf key disable-cancel is missing.
01:18:07 [6]: Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
01:18:07 [2]: WARNING: the branding component "/usr/share/calamares/branding/manjaro" does not ship translations.
01:18:07 [6]: Loaded branding component "manjaro"
01:18:07 [6]: STARTUP: initQmlPath, initSettings, initBranding done
01:18:07 [6]: STARTUP: initModuleManager: module init started
01:18:07 [6]: STARTUP: initModuleManager: all modules init done
01:18:07 [6]: STARTUP: initJobQueue done
01:18:07 [6]: Available desktop QSize(1280, 772) minimum size QSize(1024, 520)
01:18:07 [6]:   Proposed window size: 1024 520
01:18:07 [6]: STARTUP: CalamaresWindow created; loadModules started
01:18:07 [6]: Loaded module configuration "/etc/calamares/modules/welcome.conf"
01:18:07 [6]: Matching exact locale QLocale(Spanish, Latin, Spain)
01:18:07 [6]:  .. Matched locale  "es_ES"
01:18:07 [6]: Looking for translations for "es_ES"
01:18:07 [6]:  .. Calamares using locale: "es_ES"
01:18:07 [6]: Welcome string false "Manjaro Linux 18.0 \"Illyria\""
01:18:07 [6]: ViewModule "welcome@welcome" loading complete.
01:18:07 [6]: Loaded module configuration "/etc/calamares/modules/locale.conf"
01:18:07 [6]: ViewModule "locale@locale" loading complete.
01:18:07 [6]: Loaded module configuration "/usr/share/calamares/modules/keyboard.conf"
01:18:10 [6]: ViewModule "keyboard@keyboard" loading complete.
01:18:10 [6]: Loaded module configuration "/usr/share/calamares/modules/partition.conf"
01:18:10 [8]: Loaded backend plugin:  "pmlibpartedbackendplugin"
01:18:10 [2]: WARNING: Partition-module does not support *userSwapChoices* setting "file"
01:18:10 [2]: WARNING: Partition-module does not support *userSwapChoices* setting "reuse"
01:18:10 [6]: Partition-module setting *defaultFileSystemType* "ext4"
01:18:10 [6]: ViewModule "partition@partition" loading complete.
01:18:10 [6]: Loaded module configuration "/etc/calamares/modules/users.conf"
01:18:10 [0]: Could not parse stylesheet of object QLabel(0x21831c0, name = "hostname_extra_label_2")
01:18:10 [0]: Could not parse stylesheet of object QLabel(0x2185010, name = "password_extra_label_3")
01:18:10 [0]: Could not parse stylesheet of object QLabel(0x2187150, name = "labelExtraRootPassword")
01:18:10 [6]: ViewModule "users@users" loading complete.
01:18:10 [6]: ViewModule "summary@summary" loading complete.
01:18:10 [6]: Module "partition@partition" already loaded.
01:18:10 [6]: QML import paths:
     "/usr/bin"
     "qrc:/qt-project.org/imports"
     "/usr/lib/qt/qml"
01:18:10 [6]: Loaded module configuration "/usr/share/calamares/modules/mount.conf"
01:18:10 [6]: Loaded module configuration "/etc/calamares/modules/unpackfs.conf"
01:18:10 [6]: Loaded module configuration "/etc/calamares/modules/machineid.conf"
01:18:10 [6]: Loaded module configuration "/usr/share/calamares/modules/fstab.conf"
01:18:10 [6]: Module "locale@locale" already loaded.
01:18:10 [6]: Module "keyboard@keyboard" already loaded.
01:18:10 [6]: Loaded module configuration "/usr/share/calamares/modules/luksopenswaphookcfg.conf"
01:18:10 [6]: Loaded module configuration "/etc/calamares/modules/initcpio.conf"
01:18:10 [6]: Module "users@users" already loaded.
01:18:10 [6]: Loaded module configuration "/etc/calamares/modules/displaymanager.conf"
01:18:10 [6]: Loaded module configuration "/etc/calamares/modules/mhwdcfg.conf"
01:18:10 [6]: Loaded module configuration "/etc/calamares/modules/services.conf"
01:18:10 [6]: Loaded module configuration "/usr/share/calamares/modules/grubcfg.conf"
01:18:10 [6]: Loaded module configuration "/etc/calamares/modules/bootloader.conf"
01:18:10 [6]: Loaded module configuration "/etc/calamares/modules/postcfg.conf"
01:18:10 [6]: Loaded module configuration "/usr/share/calamares/modules/umount.conf"
01:18:10 [6]: Loaded module configuration "/etc/calamares/modules/finished.conf"
01:18:10 [6]: ViewModule "finished@finished" loading complete.
01:18:10 [6]: STARTUP: loadModules for all modules done
01:18:11 [6]: STARTUP: Window now visible and ProgressTreeView populated
01:18:11 [0]: Could not parse stylesheet of object QLabel(0x21831c0, name = "hostname_extra_label_2")
01:18:11 [0]: Could not parse stylesheet of object QLabel(0x2185010, name = "password_extra_label_3")
01:18:11 [0]: Could not parse stylesheet of object QLabel(0x2187150, name = "labelExtraRootPassword")
01:18:11 [6]: Need at least storage bytes: 8482560409
01:18:12 [6]: Need at least ram bytes: 1073741824
01:18:12 [6]: A battery exists, checking for mains power.
01:18:12 [6]: RequirementsChecker output:
     enoughStorage :   true
     enoughRam :   true
     hasPower :   true
     hasInternet :   true
     isRoot :   true
01:18:12 [6]: xkbmap selection changed to:  "es" - "winkeys"
01:18:17 [6]: Fetching GeoIP data from "https://get.geojs.io/v1/ip/geo.json"
01:18:17 [6]: GeoIP reporting "Europe/Madrid"
01:18:21 [6]: Got locale language "es_ES.UTF-8"
01:18:21 [6]:  .. extracted country "Spain" :: ("es", "ES")
01:18:21 [6]:    .. looking for locale part "ES"
01:18:21 [6]:    .. matched "es"
01:18:21 [6]: Next level: "es"
01:18:32 [0]: blkid: unknown file system type  ""  on  "/dev/sda2"
01:18:34 [6]: Removing unsuitable devices: 1 candidates.
01:18:35 [6]: LIST OF DETECTED DEVICES:
01:18:35 [6]: node	capacity	name	prettyName
01:18:35 [6]: "/dev/sda" 60011642880 "ATA TOSHIBA MK6021GA" "ATA TOSHIBA MK6021GA – 55,89 GiB (/dev/sda)"
01:18:35 [6]: .. 1 devices detected.
01:18:51 [6]: os-prober gave no output.
01:18:51 [0]: QString::arg: Argument missing: Este dispositivo tiene un <strong>% 1 </ strong> tabla de particiones.,  ?
01:18:51 [6]: Updating partitioning state widgets.
01:18:51 [0]: QObject::setParent: Cannot set parent, new parent is in a different thread
01:18:51 [6]: Setting up actions for "/dev/sda" with 0 entries.
01:18:51 [0]: QString::arg: Argument missing: Este dispositivo tiene un <strong>% 1 </ strong> tabla de particiones., MBR
01:18:51 [6]: Checking if "/dev/sda1" can be resized.
01:18:51 [6]: Required  storage B: 11166914969 "(10.4GB)"
01:18:51 [6]: Available storage B: 54518927360 "(50GB)" for "/dev/sda1"    length: 108820480    sectorsUsed: 2338200    fsType: "ext4"
01:18:51 [6]: Partition "/dev/sda1" authorized for resize + autopartition install.
01:18:51 [6]: .. contains resizable "/dev/sda1"
01:18:51 [6]: Required  storage B: 9019431321 "(8GB)"
01:18:51 [6]: Storage capacity  B: 55716085760 "(51GB)" for "/dev/sda1"    length: 108820480
01:18:51 [6]: Partition "/dev/sda1" authorized for replace install.
01:18:51 [6]: .. contains replacable "/dev/sda1"
01:18:51 [6]: Checking if "/dev/sda2" can be resized.
01:18:51 [6]: Available storage B: 4293918720 "(3GB)" for "/dev/sda2"    length: 8386560    sectorsUsed: 0    fsType: "ampliado"
01:18:51 [6]: Storage capacity  B: 4293918720 "(3GB)" for "/dev/sda2"    length: 8386560
01:18:51 [6]: Setting texts for 0 osprober entries
01:18:51 [6]: Updating partitioning preview widgets.
01:18:54 [6]: Updating partitioning preview widgets.
01:18:55 [6]: Choice applied:  4
01:19:14 [6]: old boundaries: 2048 108822527 108820480
01:19:14 [6]: new boundaries: 2048 108822527
01:19:14 [6]: dirty status: false
01:19:14 [8]: PartitionPage::updateBootLoaderInstallPath "/dev/sda"
01:19:14 [6]: PCM::setBootLoaderInstallPath "/dev/sda"
01:19:24 [6]: Checking MSDOS partition 2 primaries, max 4
01:19:28 [8]: PartitionPage::updateBootLoaderInstallPath "/dev/sda"
01:19:28 [6]: PCM::setBootLoaderInstallPath "/dev/sda"
01:19:59 [0]: QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
01:19:59 [0]: QObject::setParent: Cannot set parent, new parent is in a different thread
01:19:59 [6]: Gathering UUIDs for partitions that exist now.
01:19:59 [6]: .. added path= "/dev/sda1" UUID= "486b0682-a596-45d3-9a9a-5a3a24dd263f"
01:19:59 [6]: .. added path= "/dev/sda2" UUID= ""
01:19:59 [6]: .. added path= "" UUID= ""
01:19:59 [6]: Writing to GlobalStorage["partitions"]
01:19:59 [6]: .. partitions on "/dev/sda"
01:19:59 [6]:   .. mapping for "/dev/sda1" "/dev/sda1"
     mtpoint: :   "/"
     fs: :   "ext4"
     fsname :   "ext4"
     uuid :   "486b0682-a596-45d3-9a9a-5a3a24dd263f"
01:19:59 [6]:   .. mapping for "/dev/sda2" "/dev/sda2"
     mtpoint: :   ""
     fs: :   "extended"
     fsname :   "ampliado"
     uuid :   ""
01:19:59 [6]:   .. mapping for "" "Partición nueva"
     mtpoint: :   ""
     fs: :   "linuxswap"
     fsname :   "linuxswap"
     uuid :   ""
01:19:59 [8]: QVariant(QString, "486b0682-a596-45d3-9a9a-5a3a24dd263f") "/dev/sda1" "/" "ext4"
01:19:59 [8]: QVariant(QString, "") "/dev/sda2" "" "extended"
01:19:59 [8]: QVariant(QString, "") "" "" "linuxswap"
     mtpoint: :   "/"
     fs: :   "ext4"
     fsname :   "ext4"
     mtpoint: :   ""
     fs: :   "extended"
     fsname :   "ampliado"
     uuid :   ""
     mtpoint: :   ""
     fs: :   "linuxswap"
     uuid :   ""
01:20:02 [6]: Summary widget is larger than viewport, enlarge by 83 to QSize(816, 551)
01:20:15 [6]: Starting job "Limpiar todos los puntos de montaje temporales."
01:20:15 [6]: Opened mtab. Lines:
01:20:15 [6]: "proc /proc proc rw,nosuid,nodev,noexec,relatime 0 0"
01:20:15 [6]: "sys /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0"
01:20:15 [6]: "dev /dev devtmpfs rw,nosuid,relatime,size=625608k,nr_inodes=156402,mode=755 0 0"
01:20:15 [6]: "run /run tmpfs rw,nosuid,nodev,relatime,mode=755 0 0"
01:20:15 [6]: "/dev/sr0 /run/miso/bootmnt iso9660 ro,relatime,nojoliet,check=s,map=n,blocksize=2048 0 0"
01:20:15 [6]: "cowspace /run/miso/cowspace tmpfs rw,relatime,size=262144k,mode=755 0 0"
01:20:15 [6]: "overlay_root /run/miso/overlay_root tmpfs rw,relatime,size=964384k,mode=755 0 0"
01:20:15 [6]: "/dev/loop0 /run/miso/sfs/livefs squashfs ro,relatime 0 0"
01:20:15 [6]: "/dev/loop1 /run/miso/sfs/mhwdfs squashfs ro,relatime 0 0"
01:20:15 [6]: "/dev/loop2 /run/miso/sfs/desktopfs squashfs ro,relatime 0 0"
01:20:15 [6]: "/dev/loop3 /run/miso/sfs/rootfs squashfs ro,relatime 0 0"
01:20:15 [6]: "overlay / overlay rw,relatime,lowerdir=/run/miso/sfs/livefs:/run/miso/sfs/mhwdfs:/run/miso/sfs/desktopfs:/run/miso/sfs/rootfs,upperdir=/run/miso/overlay_root/upper,workdir=/run/miso/overlay_root/work,index=off 0 0"
01:20:15 [6]: "securityfs /sys/kernel/security securityfs rw,nosuid,nodev,noexec,relatime 0 0"
01:20:15 [6]: "tmpfs /dev/shm tmpfs rw,nosuid,nodev 0 0"
01:20:15 [6]: "devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0"
01:20:15 [6]: "tmpfs /sys/fs/cgroup tmpfs ro,nosuid,nodev,noexec,mode=755 0 0"
01:20:15 [6]: "cgroup2 /sys/fs/cgroup/unified cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate 0 0"
01:20:15 [6]: "cgroup /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,xattr,name=systemd 0 0"
01:20:15 [6]: "pstore /sys/fs/pstore pstore rw,nosuid,nodev,noexec,relatime 0 0"
01:20:15 [6]: "bpf /sys/fs/bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700 0 0"
01:20:15 [6]: "cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct 0 0"
01:20:15 [6]: "cgroup /sys/fs/cgroup/blkio cgroup rw,nosuid,nodev,noexec,relatime,blkio 0 0"
01:20:15 [6]: "cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0"
01:20:15 [6]: "cgroup /sys/fs/cgroup/net_cls,net_prio cgroup rw,nosuid,nodev,noexec,relatime,net_cls,net_prio 0 0"
01:20:15 [6]: "cgroup /sys/fs/cgroup/rdma cgroup rw,nosuid,nodev,noexec,relatime,rdma 0 0"
01:20:15 [6]: "cgroup /sys/fs/cgroup/perf_event cgroup rw,nosuid,nodev,noexec,relatime,perf_event 0 0"
01:20:15 [6]: "cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0"
01:20:15 [6]: "cgroup /sys/fs/cgroup/cpuset cgroup rw,nosuid,nodev,noexec,relatime,cpuset 0 0"
01:20:15 [6]: "cgroup /sys/fs/cgroup/freezer cgroup rw,nosuid,nodev,noexec,relatime,freezer 0 0"
01:20:15 [6]: "cgroup /sys/fs/cgroup/devices cgroup rw,nosuid,nodev,noexec,relatime,devices 0 0"
01:20:15 [6]: "systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=42,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=9987 0 0"
01:20:15 [6]: "tmpfs /tmp tmpfs rw,nosuid,nodev 0 0"
01:20:15 [6]: "mqueue /dev/mqueue mqueue rw,relatime 0 0"
01:20:15 [6]: "debugfs /sys/kernel/debug debugfs rw,relatime 0 0"
01:20:15 [6]: "hugetlbfs /dev/hugepages hugetlbfs rw,relatime,pagesize=4M 0 0"
01:20:15 [6]: "binfmt_misc /proc/sys/fs/binfmt_misc binfmt_misc rw,relatime 0 0"
01:20:15 [6]: "configfs /sys/kernel/config configfs rw,relatime 0 0"
01:20:15 [6]: "tmpfs /etc/pacman.d/gnupg tmpfs rw,relatime,mode=755 0 0"
01:20:15 [6]: "tmpfs /run/user/1000 tmpfs rw,nosuid,nodev,relatime,size=128584k,mode=700,uid=1000,gid=1000 0 0"
01:20:15 [6]: "gvfsd-fuse /run/user/1000/gvfs fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000 0 0"
01:20:15 [6]: ClearTempMountsJob finished. Here's what was done:
01:20:15 [6]: Starting job "Limpiar puntos de montaje para operaciones de particionamiento en /dev/sda"
01:20:17 [6]: ClearMountsJob finished. Here's what was done:
01:20:17 [6]: Starting job "Formatear la partición /dev/sda1 (sistema de archivos: ext4, tamaño: 53135 MB) en ATA TOSHIBA MK6021GA"
01:21:54 [6]: Starting job "Crear nueva 4094MB partición en  /dev/sda (ATA TOSHIBA MK6021GA) con el sistema de archivos linuxswap."
01:22:18 [6]: Starting job "Establecer la información de la partición"
01:22:18 [6]: Gathering UUIDs for partitions that exist now.
01:22:19 [6]: .. added path= "/dev/sda1" UUID= "2a0620a2-4f6a-4d5b-aab3-239dbb4ff394"
01:22:19 [6]: .. added path= "/dev/sda2" UUID= ""
01:22:20 [6]: .. added path= "/dev/sda5" UUID= "6fe759d9-31a1-44c2-a10d-6901fb3a0169"
01:22:20 [6]: Writing to GlobalStorage["partitions"]
01:22:20 [6]: .. partitions on "/dev/sda"
01:22:20 [6]:   .. mapping for "/dev/sda1" "/dev/sda1"
     mtpoint: :   "/"
     fs: :   "ext4"
     fsname :   "ext4"
     uuid :   "2a0620a2-4f6a-4d5b-aab3-239dbb4ff394"
01:22:20 [6]:   .. mapping for "/dev/sda2" "/dev/sda2"
     mtpoint: :   ""
     fs: :   "extended"
     fsname :   "ampliado"
     uuid :   ""
01:22:20 [6]:   .. mapping for "/dev/sda5" "/dev/sda5"
     mtpoint: :   ""
     fs: :   "linuxswap"
     uuid :   "6fe759d9-31a1-44c2-a10d-6901fb3a0169"
01:22:20 [6]: FillGlobalStorageJob writing bootLoader path: QVariant(QVariantMap, QMap(("installPath", QVariant(QString, "/dev/sda"))))
01:22:20 [6]: Starting job "mount"
01:22:28 [6]: Job file "/usr/lib/calamares/modules/mount/main.py"
01:22:28 [6]: Job description from __doc__ "mount" = "Define mountpoints."
01:22:29 [6]: Starting job "unpackfs"
01:22:29 [6]: Determining gettext path from ("/home/manjaro", "/usr/bin", "/usr/share/locale")
01:22:29 [6]:  .. Found "es_ES" in "/usr/share/locale/es_ES"
01:22:30 [6]: Job file "/usr/lib/calamares/modules/unpackfs/main.py"
01:22:30 [6]: Job description from pretty_name "unpackfs" = "Installing filesystems."
mount: /tmp/tmpmdwq_3ef/rootfs: ATENCIÓN: el dispositivo está protegido contra escritura; se monta como sólo lectura.
mount: /tmp/tmpmdwq_3ef/desktopfs: WARNING: device write-protected, mounted read-only.
01:11:52 [6]: Using log file: "/home/manjaro/.cache/calamares/session.log"
01:11:52 [6]: Using Calamares QML directory "/usr/share/calamares/qml"
01:11:52 [6]: Using Calamares settings file at "/etc/calamares/settings.conf"
01:11:52 [2]: WARNING: Required settings.conf key disable-cancel is missing.
01:11:52 [6]: Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
01:11:52 [2]: WARNING: the branding component "/usr/share/calamares/branding/manjaro" does not ship translations.
01:11:52 [6]: Loaded branding component "manjaro"
01:11:52 [6]: STARTUP: initQmlPath, initSettings, initBranding done
01:11:52 [6]: STARTUP: initModuleManager: module init started
01:11:52 [6]: STARTUP: initModuleManager: all modules init done
01:11:52 [6]: STARTUP: initJobQueue done
01:11:52 [6]: Available desktop QSize(1280, 772) minimum size QSize(1024, 520)
01:11:52 [6]:   Proposed window size: 1024 520
01:11:52 [6]: STARTUP: CalamaresWindow created; loadModules started
01:11:52 [6]: Loaded module configuration "/etc/calamares/modules/welcome.conf"
01:11:52 [6]: Matching exact locale QLocale(Spanish, Latin, Spain)
01:11:52 [6]:  .. Matched locale  "es_ES"
01:11:52 [6]: Looking for translations for "es_ES"
01:11:52 [6]:  .. Calamares using locale: "es_ES"
01:11:52 [6]: Welcome string false "Manjaro Linux 18.0 \"Illyria\""
01:11:52 [6]: ViewModule "welcome@welcome" loading complete.
01:11:52 [6]: Loaded module configuration "/etc/calamares/modules/locale.conf"
01:11:53 [6]: ViewModule "locale@locale" loading complete.
01:11:53 [6]: Loaded module configuration "/usr/share/calamares/modules/keyboard.conf"
01:11:55 [6]: ViewModule "keyboard@keyboard" loading complete.
01:11:55 [6]: Loaded module configuration "/usr/share/calamares/modules/partition.conf"
01:11:55 [8]: Loaded backend plugin:  "pmlibpartedbackendplugin"
01:11:55 [2]: WARNING: Partition-module does not support *userSwapChoices* setting "file"
01:11:55 [2]: WARNING: Partition-module does not support *userSwapChoices* setting "reuse"
01:11:55 [6]: Partition-module setting *defaultFileSystemType* "ext4"
01:11:55 [6]: ViewModule "partition@partition" loading complete.
01:11:55 [6]: Loaded module configuration "/etc/calamares/modules/users.conf"
01:11:55 [0]: Could not parse stylesheet of object QLabel(0x9ab450, name = "hostname_extra_label_2")
01:11:55 [0]: Could not parse stylesheet of object QLabel(0x9ad2b0, name = "password_extra_label_3")
01:11:55 [0]: Could not parse stylesheet of object QLabel(0x9af3f0, name = "labelExtraRootPassword")
01:11:55 [6]: ViewModule "users@users" loading complete.
01:11:55 [6]: ViewModule "summary@summary" loading complete.
01:11:55 [6]: Module "partition@partition" already loaded.
01:11:55 [6]: QML import paths:
     "/usr/bin"
     "/usr/lib/qt/qml"
01:11:55 [6]: Loaded module configuration "/usr/share/calamares/modules/mount.conf"
01:11:55 [6]: Loaded module configuration "/etc/calamares/modules/unpackfs.conf"
01:11:55 [6]: Loaded module configuration "/etc/calamares/modules/machineid.conf"
01:11:55 [6]: Loaded module configuration "/usr/share/calamares/modules/fstab.conf"
01:11:55 [6]: Module "locale@locale" already loaded.
01:11:55 [6]: Module "keyboard@keyboard" already loaded.
01:11:55 [6]: Loaded module configuration "/usr/share/calamares/modules/luksopenswaphookcfg.conf"
01:11:55 [6]: Loaded module configuration "/etc/calamares/modules/initcpio.conf"
01:11:55 [6]: Module "users@users" already loaded.
01:11:55 [6]: Loaded module configuration "/etc/calamares/modules/displaymanager.conf"
01:11:55 [6]: Loaded module configuration "/etc/calamares/modules/mhwdcfg.conf"
01:11:55 [6]: Loaded module configuration "/etc/calamares/modules/services.conf"
0101:50:57 [6]: Starting job "networkcfg"
01:51:03 [6]: Job file "/usr/lib/calamares/modules/networkcfg/main.py"
01:51:03 [6]: Job description from __doc__ "networkcfg" = "Setup network configuration"
01:51:03 [6]: Starting job "machineid"
01:51:03 [6]: Determining gettext path from ("/home/manjaro", "/usr/bin", "/usr/share/locale")
01:51:03 [6]:  .. Found "es_ES" in "/usr/share/locale/es_ES"
01:51:03 [6]: Job file "/usr/lib/calamares/modules/machineid/main.py"
01:51:03 [6]: Job description from pretty_name "machineid" = "Generar identificación-de-máquina."
01:51:03 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "systemd-machine-id-setup")
01:51:08 [6]: Finished. Exit code: 0
01:51:08 [6]: Target cmd: ("systemd-machine-id-setup")
01:51:08 [6]: Target output:
Initializing machine ID from random generator.
01:51:08 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "ln", "-s", "/etc/machine-id", "/var/lib/dbus/machine-id")
01:51:08 [6]: Target cmd: ("ln", "-s", "/etc/machine-id", "/var/lib/dbus/machine-id")
01:51:08 [6]: Starting job "fstab"
01:51:08 [6]: Job file "/usr/lib/calamares/modules/fstab/main.py"
01:51:08 [6]: Job description from __doc__ "fstab" = "Configures fstab."
01:51:08 [6]: Starting job "Configurar uso horario a Europe/Madrid"
01:51:09 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "rm", "-f", "/etc/localtime")
01:51:09 [6]: Finished. Exit code: 0
01:51:09 [6]: Target cmd: ("rm", "-f", "/etc/localtime")
01:51:09 [6]: Target output:
01:51:09 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "ln", "-s", "/usr/share/zoneinfo/Europe/Madrid", "/etc/localtime")
01:51:09 [6]: Target cmd: ("ln", "-s", "/usr/share/zoneinfo/Europe/Madrid", "/etc/localtime")
01:51:09 [6]: Starting job "Configurar modelo de teclado a pc105, distribución a es-winkeys"
01:51:09 [6]: Executing SetKeyboardLayoutJob
01:51:09 [6]: Looking for converted keymap in "/tmp/calamares-root-g7vjbqkh/lib/kbd/keymaps/xkb"
01:51:09 [6]: Looking for legacy keymap in QRC
01:51:11 [6]: .. Found legacy keymap "es" with score 11
01:51:11 [6]: Written KEYMAP= "es" to vconsole.conf
01:51:11 [6]: Written XkbLayout "es" ; XkbModel "pc105" ; XkbVariant "winkeys" to X.org file "/tmp/calamares-root-g7vjbqkh/etc/X11/xorg.conf.d/00-keyboard.conf"
01:51:11 [6]: Written XKBMODEL "pc105" ; XKBLAYOUT "es" ; XKBVARIANT "winkeys" to /etc/default/keyboard file "/tmp/calamares-root-g7vjbqkh/etc/default/keyboard"
01:51:11 [6]: Starting job "localecfg"
01:51:11 [6]: Job file "/usr/lib/calamares/modules/localecfg/main.py"
01:51:11 [6]: Job description from __doc__ "localecfg" = "Create locale"
01:51:11 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "locale-gen")
01:51:43 [6]: Finished. Exit code: 0
01:51:43 [6]: Target cmd: ("locale-gen")
01:51:43 [6]: Target output:
Generating locales...
  en_US.UTF-8... done
  es_ES.UTF-8... done
Generation complete.
01:51:43 [6]: [PYTHON JOB]:  "/tmp/calamares-root-g7vjbqkh/etc/locale.gen done"
01:51:43 [6]: [PYTHON JOB]:  "/tmp/calamares-root-g7vjbqkh/etc/locale.conf done"
01:51:43 [6]: [PYTHON JOB]:  "/tmp/calamares-root-g7vjbqkh/etc/default done"
01:51:43 [6]: Starting job "luksopenswaphookcfg"
01:51:43 [6]: Job file "/usr/lib/calamares/modules/luksopenswaphookcfg/main.py"
01:51:43 [6]: Job description from __doc__ "luksopenswaphookcfg" = "This module sets up the openswap hook for a resumable encrypted swap."
01:51:43 [6]: Starting job "luksbootkeyfile"
01:51:43 [6]: Job file "/usr/lib/calamares/modules/luksbootkeyfile/main.py"
01:51:43 [6]: Job description from __doc__ "luksbootkeyfile" = "This module sets up a file crypto_keyfile.bin on the rootfs, assuming the"
01:51:43 [6]: Starting job "initcpiocfg"
01:51:43 [6]: Job file "/usr/lib/calamares/modules/initcpiocfg/main.py"
01:51:43 [6]: Job description from __doc__ "initcpiocfg" = "Calls routine with given parameters to modify '/etc/mkinitcpio.conf'."
01:51:44 [6]: Starting job "initcpio"
01:51:44 [6]: Job file "/usr/lib/calamares/modules/initcpio/main.py"
01:51:44 [6]: Job description from __doc__ "initcpio" = "Calls routine to create kernel initramfs image."
01:51:44 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "mkinitcpio", "-p", "linux414")
01:53:21 [6]: Finished. Exit code: 0
01:53:21 [6]: Target cmd: ("mkinitcpio", "-p", "linux414")
01:53:21 [6]: Target output:
==> Building image from preset: /etc/mkinitcpio.d/linux414.preset: 'default'
  -> -k /boot/vmlinuz-4.14-i686 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.14-i686.img
==> Starting build: 4.14.109-1-MANJARO
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [resume]
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.14-i686.img
==> Building image from preset: /etc/mkinitcpio.d/linux414.preset: 'fallback'
  -> -k /boot/vmlinuz-4.14-i686 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.14-i686-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.14-i686-fallback.img
01:53:21 [6]: Starting job "Crear usuario noname"
01:53:21 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "groupadd", "autologin")
01:53:26 [6]: Finished. Exit code: 0
01:53:26 [6]: Target cmd: ("groupadd", "autologin")
01:53:26 [6]: Target output:
01:53:26 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "useradd", "-m", "-U", "-s", "/bin/bash", "-c", "noname", "noname")
01:53:27 [6]: Finished. Exit code: 0
01:53:27 [6]: Target cmd: ("useradd", "-m", "-U", "-s", "/bin/bash", "-c", "noname", "noname")
01:53:27 [6]: Target output:
01:53:27 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "usermod", "-aG", "lp,network,power,sys,wheel,autologin", "noname")
01:53:28 [6]: Finished. Exit code: 0
01:53:28 [6]: Target cmd: ("usermod", "-aG", "lp,network,power,sys,wheel,autologin", "noname")
01:53:28 [6]: Target output:
01:53:28 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "chown", "-R", "noname:noname", "/home/noname")
01:53:28 [6]: Target cmd: ("chown", "-R", "noname:noname", "/home/noname")
01:53:28 [6]: Starting job "Definir contraseña para el usuario noname."
01:53:28 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "usermod", "-p", "$6$TzO1dcL3H4qN8iFb$mW3bzYPMMsUefOoc1EV/4CuwZ1SzeiN6XCpRO8THhwqRv/i6twtS8qswWY.lr2MzwANiHmszAPnyn3JMMIrWu/", "noname")
01:53:29 [6]: Finished. Exit code: 0
01:53:29 [6]: Target cmd: ("usermod", "-p", "$6$TzO1dcL3H4qN8iFb$mW3bzYPMMsUefOoc1EV/4CuwZ1SzeiN6XCpRO8THhwqRv/i6twtS8qswWY.lr2MzwANiHmszAPnyn3JMMIrWu/", "noname")
01:53:29 [6]: Target output:
01:53:29 [6]: Starting job "Definir contraseña para el usuario root."
01:53:29 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "usermod", "-p", "$6$Y9Tu7jzXOjGirGau$BAzUNNzbntf1w25vS2gC/iviDDyNnztyY.7bKLsAEgJ9pU/T9JipfBWiQcAwY3k3Sd2mFHWyieXkFvjZdPOEz/", "root")
01:53:29 [6]: Target cmd: ("usermod", "-p", "$6$Y9Tu7jzXOjGirGau$BAzUNNzbntf1w25vS2gC/iviDDyNnztyY.7bKLsAEgJ9pU/T9JipfBWiQcAwY3k3Sd2mFHWyieXkFvjZdPOEz/", "root")
01:53:29 [6]: Starting job "Hostname: 2007-x32"
01:53:29 [6]: Starting job "displaymanager"
01:53:30 [6]: Determining gettext path from ("/home/manjaro", "/usr/bin", "/usr/share/locale")
01:53:30 [6]:  .. Found "es_ES" in "/usr/share/locale/es_ES"
01:53:30 [6]: Job file "/usr/lib/calamares/modules/displaymanager/main.py"
01:53:30 [6]: Job description from __doc__ "displaymanager" = "Configure display managers."
01:53:31 [6]: [PYTHON JOB]:  "gdm selected but not installed"
01:53:31 [6]: [PYTHON JOB]:  "mdm selected but not installed"
01:53:31 [6]: [PYTHON JOB]:  "sddm selected but not installed"
01:53:31 [6]: [PYTHON JOB]:  "lxdm selected but not installed"
01:53:31 [6]: [PYTHON JOB]:  "slim selected but not installed"
01:53:31 [6]: [PYTHON JOB]:  "Setting up autologin for user noname."
01:53:33 [6]: [PYTHON JOB]:  "found greeter lightdm-gtk-greeter"
01:53:35 [6]: [PYTHON JOB]:  "lightdm-gtk-greeter configured as greeter."
01:53:35 [6]: Starting job "mhwdcfg"
01:53:35 [6]: Job file "/usr/lib/calamares/modules/mhwdcfg/main.py"
01:53:35 [6]: Job description from __doc__ "mhwdcfg" = "Configure the hardware"
01:53:35 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "mhwd", "-a", "pci", "free", "0200", "--pmconfig", "/opt/pacman-mhwd.conf")
01:53:38 [6]: Finished. Exit code: 0
01:53:38 [6]: Target cmd: ("mhwd", "-a", "pci", "free", "0200", "--pmconfig", "/opt/pacman-mhwd.conf")
01:53:38 [6]: Target output:
Warning: No config found for device: 0000:02:01.0 (0200:14e4:170c) Network controller Broadcom BCM4401-B0 100Base-TX
01:53:39 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "mhwd", "-a", "pci", "free", "0280", "--pmconfig", "/opt/pacman-mhwd.conf")
01:53:41 [6]: Finished. Exit code: 0
01:53:41 [6]: Target cmd: ("mhwd", "-a", "pci", "free", "0280", "--pmconfig", "/opt/pacman-mhwd.conf")
01:53:41 [6]: Target output:
Warning: No device of class 0280 found!
01:53:41 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "mhwd", "-a", "pci", "free", "0300", "--pmconfig", "/opt/pacman-mhwd.conf")
01:55:21 [6]: Finished. Exit code: 0
01:55:21 [6]: Target cmd: ("mhwd", "-a", "pci", "free", "0300", "--pmconfig", "/opt/pacman-mhwd.conf")
01:55:21 [6]: Target output:
> Using config 'video-linux' for device: 0000:01:00.0 (0300:1002:4e50) Display controller ATI Technologies Inc RV350 NP
> Installing video-linux...
warning: database file for 'core' does not exist (use '-Sy' to download)
warning: database file for 'extra' does not exist (use '-Sy' to download)
warning: database file for 'community' does not exist (use '-Sy' to download)
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/video-linux/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0380
Processing classid: 0302
downloading mhwd.db...
resolving dependencies...
Packages (10) libxvmc-1.0.11-1.0  libva-mesa-driver-19.0.0-1.0  libva-vdpau-driver-0.7.4-4.0  mesa-vdpau-19.0.0-1.0  vulkan-intel-19.0.0-1.0  vulkan-radeon-19.0.0-1.0  xf86-video-amdgpu-18.1.0-1.0  xf86-video-ati-1:18.1.0-1.0  xf86-video-intel-1:2.99.917+859+g33ee0c3b-1.0  xf86-video-nouveau-1.0.16-1.0
Total Download Size:    7.15 MiB
Total Installed Size:  24.01 MiB
:: Retrieving packages...
downloading xf86-video-ati-1:18.1.0-1.0-i686.pkg.tar.xz...
downloading xf86-video-amdgpu-18.1.0-1.0-i686.pkg.tar.xz...
downloading libxvmc-1.0.11-1.0-i686.pkg.tar.xz...
downloading xf86-video-intel-1:2.99.917+859+g33ee0c3b-1.0-i686.pkg.tar.xz...
downloading xf86-video-nouveau-1.0.16-1.0-i686.pkg.tar.xz...
downloading vulkan-intel-19.0.0-1.0-i686.pkg.tar.xz...
downloading vulkan-radeon-19.0.0-1.0-i686.pkg.tar.xz...
downloading libva-mesa-driver-19.0.0-1.0-i686.pkg.tar.xz...
downloading libva-vdpau-driver-0.7.4-4.0-i686.pkg.tar.xz...
downloading mesa-vdpau-19.0.0-1.0-i686.pkg.tar.xz...
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
installing xf86-video-ati...
installing xf86-video-amdgpu...
installing libxvmc...
installing xf86-video-intel...
>>> This driver now uses DRI3 as the default Direct Rendering
    Infrastructure. You can try falling back to DRI2 if you run
    into trouble. To do so, save a file with the following
    content as /etc/X11/xorg.conf.d/20-intel.conf :
      Section "Device"
        Identifier  "Intel Graphics"
        Driver      "intel"
        Option      "DRI" "2"             # DRI3 is now default
        #Option      "AccelMethod"  "sna" # default
        #Option      "AccelMethod"  "uxa" # fallback
      EndSection
Optional dependencies for xf86-video-intel
    libxrandr: for intel-virtual-output [installed]
    libxinerama: for intel-virtual-output [installed]
    libxcursor: for intel-virtual-output [installed]
    libxtst: for intel-virtual-output [installed]
    libxss: for intel-virtual-output [installed]
installing xf86-video-nouveau...
installing vulkan-intel...
installing vulkan-radeon...
installing libva-mesa-driver...
installing libva-vdpau-driver...
installing mesa-vdpau...
error: command terminated by signal 7: Bus error
(1/1) Arming ConditionNeedsUpdate...
> Successfully installed video-linux
01:55:21 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "mhwd", "-a", "pci", "free", "0302", "--pmconfig", "/opt/pacman-mhwd.conf")
01:55:23 [6]: Finished. Exit code: 0
01:55:23 [6]: Target cmd: ("mhwd", "-a", "pci", "free", "0302", "--pmconfig", "/opt/pacman-mhwd.conf")
01:55:23 [6]: Target output:
Warning: No device of class 0302 found!
01:55:23 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "mhwd", "-a", "pci", "free", "0380", "--pmconfig", "/opt/pacman-mhwd.conf")
01:55:25 [6]: Finished. Exit code: 0
01:55:25 [6]: Target cmd: ("mhwd", "-a", "pci", "free", "0380", "--pmconfig", "/opt/pacman-mhwd.conf")
01:55:25 [6]: Target output:
Warning: No device of class 0380 found!
01:55:26 [6]: Starting job "hwclock"
01:55:26 [6]: Job file "/usr/lib/calamares/modules/hwclock/main.py"
01:55:26 [6]: Job description from __doc__ "hwclock" = "Set hardware clock."
01:55:26 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "hwclock", "--systohc", "--utc")
01:55:27 [6]: Finished. Exit code: 0
01:55:27 [6]: Target cmd: ("hwclock", "--systohc", "--utc")
01:55:27 [6]: Target output:
01:55:27 [6]: [PYTHON JOB]:  "Hwclock set using RTC method."
01:55:27 [6]: Starting job "services"
01:55:27 [6]: Job file "/usr/lib/calamares/modules/services/main.py"
01:55:27 [6]: Job description from __doc__ "services" = "Setup systemd services"
01:55:27 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "systemctl", "enable", "avahi-daemon.service")
01:55:29 [6]: Finished. Exit code: 0
01:55:29 [6]: Target cmd: ("systemctl", "enable", "avahi-daemon.service")
01:55:29 [6]: Target output:
Created symlink /etc/systemd/system/dbus-org.freedesktop.Avahi.service -> /usr/lib/systemd/system/avahi-daemon.service.
Created symlink /etc/systemd/system/multi-user.target.wants/avahi-daemon.service -> /usr/lib/systemd/system/avahi-daemon.service.
Created symlink /etc/systemd/system/sockets.target.wants/avahi-daemon.socket -> /usr/lib/systemd/system/avahi-daemon.socket.
01:55:29 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "systemctl", "enable", "bluetooth.service")
01:55:29 [6]: Target cmd: ("systemctl", "enable", "bluetooth.service")
Created symlink /etc/systemd/system/dbus-org.bluez.service -> /usr/lib/systemd/system/bluetooth.service.
Created symlink /etc/systemd/system/bluetooth.target.wants/bluetooth.service -> /usr/lib/systemd/system/bluetooth.service.
01:55:29 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "systemctl", "enable", "cronie.service")
01:55:29 [6]: Target cmd: ("systemctl", "enable", "cronie.service")
Created symlink /etc/systemd/system/multi-user.target.wants/cronie.service -> /usr/lib/systemd/system/cronie.service.
01:55:29 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "systemctl", "enable", "ModemManager.service")
01:55:29 [6]: Target cmd: ("systemctl", "enable", "ModemManager.service")
Created symlink /etc/systemd/system/dbus-org.freedesktop.ModemManager1.service -> /usr/lib/systemd/system/ModemManager.service.
Created symlink /etc/systemd/system/multi-user.target.wants/ModemManager.service -> /usr/lib/systemd/system/ModemManager.service.
01:55:29 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "systemctl", "enable", "NetworkManager.service")
01:55:29 [6]: Target cmd: ("systemctl", "enable", "NetworkManager.service")
Created symlink /etc/systemd/system/dbus-org.freedesktop.NetworkManager.service -> /usr/lib/systemd/system/NetworkManager.service.
Created symlink /etc/systemd/system/multi-user.target.wants/NetworkManager.service -> /usr/lib/systemd/system/NetworkManager.service.
Created symlink /etc/systemd/system/dbus-org.freedesktop.nm-dispatcher.service -> /usr/lib/systemd/system/NetworkManager-dispatcher.service.
Created symlink /etc/systemd/system/network-online.target.wants/NetworkManager-wait-online.service -> /usr/lib/systemd/system/NetworkManager-wait-online.service.
01:55:29 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "systemctl", "enable", "org.cups.cupsd.service")
01:55:29 [6]: Finished. Exit code: 1
01:55:29 [6]: Target cmd: ("systemctl", "enable", "org.cups.cupsd.service")
Failed to enable unit, unit org.cups.cupsd.service does not exist.
01:55:29 [2]: WARNING: [PYTHON JOB]:  "Cannot enable systemd .service org.cups.cupsd"
01:55:29 [2]: WARNING: [PYTHON JOB]:  "systemctl enable call in chroot returned error code 1"
01:55:29 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "systemctl", "enable", "tlp.service")
01:55:29 [6]: Target cmd: ("systemctl", "enable", "tlp.service")
Created symlink /etc/systemd/system/multi-user.target.wants/tlp.service -> /usr/lib/systemd/system/tlp.service.
01:55:29 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "systemctl", "enable", "tlp-sleep.service")
01:55:29 [6]: Target cmd: ("systemctl", "enable", "tlp-sleep.service")
Created symlink /etc/systemd/system/sleep.target.wants/tlp-sleep.service -> /usr/lib/systemd/system/tlp-sleep.service.
01:55:29 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "systemctl", "enable", "ufw.service")
01:55:29 [6]: Target cmd: ("systemctl", "enable", "ufw.service")
Created symlink /etc/systemd/system/multi-user.target.wants/ufw.service -> /usr/lib/systemd/system/ufw.service.
01:55:29 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "systemctl", "enable", "haveged.service")
01:55:29 [6]: Target cmd: ("systemctl", "enable", "haveged.service")
Created symlink /etc/systemd/system/sysinit.target.wants/haveged.service -> /usr/lib/systemd/system/haveged.service.
01:55:29 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "systemctl", "enable", "lightdm.service")
01:55:29 [6]: Target cmd: ("systemctl", "enable", "lightdm.service")
Created symlink /etc/systemd/system/display-manager.service -> /usr/lib/systemd/system/lightdm.service.
01:55:29 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "systemctl", "enable", "graphical.target")
01:55:30 [6]: Finished. Exit code: 0
01:55:30 [6]: Target cmd: ("systemctl", "enable", "graphical.target")
01:55:30 [6]: Target output:
The unit files have no installation config (WantedBy=, RequiredBy=, Also=,
Alias= settings in the [Install] section, and DefaultInstance= for template
units). This means they are not meant to be enabled using systemctl.
Possible reasons for having this kind of units are:
* A unit may be statically enabled by being symlinked from another unit's
  .wants/ or .requires/ directory.
* A unit's purpose may be to act as a helper for some other unit which has
  a requirement dependency on it.
* A unit may be started when needed via activation (socket, path, timer,
  D-Bus, udev, scripted systemctl call, ...).
* In case of template units, the unit is meant to be enabled with some
  instance name specified.
01:55:30 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "systemctl", "disable", "pacman-init.service")
01:55:30 [6]: Target cmd: ("systemctl", "disable", "pacman-init.service")
01:55:30 [6]: Starting job "grubcfg"
01:55:30 [6]: Job file "/usr/lib/calamares/modules/grubcfg/main.py"
01:55:30 [6]: Job description from __doc__ "grubcfg" = "Calls routine with given parameters to modify '/etc/default/grub'."
01:55:30 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "sh", "-c", "which dracut")
01:55:30 [6]: Finished. Exit code: 1
01:55:30 [6]: Target cmd: ("sh", "-c", "which dracut")
which: no dracut in (/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl)
01:55:30 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "sh", "-c", "which plymouth")
01:55:30 [6]: Target cmd: ("sh", "-c", "which plymouth")
which: no plymouth in (/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl)
01:55:30 [6]: Starting job "bootloader"
01:55:30 [6]: Job file "/usr/lib/calamares/modules/bootloader/main.py"
01:55:30 [6]: Job description from __doc__ "bootloader" = "Starts procedure and passes 'fw_type' to other routine."
01:55:30 [6]: [PYTHON JOB]:  "Bootloader: grub (bios)"
01:55:30 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "grub-install", "--target=i386-pc", "--recheck", "--force", "/dev/sda")
01:56:48 [6]: Finished. Exit code: 0
01:56:48 [6]: Target cmd: ("grub-install", "--target=i386-pc", "--recheck", "--force", "/dev/sda")
01:56:48 [6]: Target output:
Installing for i386-pc platform.
Installation finished. No error reported.
01:56:48 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "grub-mkconfig", "-o", "/boot/grub/grub.cfg")
01:57:58 [6]: Finished. Exit code: 0
01:57:58 [6]: Target cmd: ("grub-mkconfig", "-o", "/boot/grub/grub.cfg")
01:57:58 [6]: Target output:
Found linux image: /boot/vmlinuz-4.14-i686
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-4.14-i686.img
Found initrd fallback image: /boot/initramfs-4.14-i686-fallback.img
done
01:57:58 [6]: Starting job "postcfg"
01:57:58 [6]: Job file "/usr/lib/calamares/modules/postcfg/main.py"
01:57:58 [6]: Job description from __doc__ "postcfg" = "Misc postinstall configurations"
01:57:58 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "pacman-key", "--init")
01:58:13 [6]: Finished. Exit code: 0
01:58:13 [6]: Target cmd: ("pacman-key", "--init")
01:58:13 [6]: Target output:
gpg: checking the trustdb
gpg: marginals needed: 3  completes needed: 1  trust model: pgp
gpg: depth: 0  valid:   1  signed:  25  trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1  valid:  25  signed:  90  trust: 1-, 0q, 0n, 24m, 0f, 0u
gpg: depth: 2  valid:  84  signed:  13  trust: 84-, 0q, 0n, 0m, 0f, 0u
gpg: next trustdb check due at 2019-10-03
01:58:13 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "pacman-key", "--populate", "archlinux", "manjaro")
01:58:41 [6]: Finished. Exit code: 0
01:58:41 [6]: Target cmd: ("pacman-key", "--populate", "archlinux", "manjaro")
01:58:41 [6]: Target output:
==> Appending keys from archlinux.gpg...
==> Appending keys from manjaro.gpg...
==> Locally signing trusted keys in keyring...
  -> Locally signing key B4663188A692DB1E45A98EE95BD96CC4247B52CC...
  -> Locally signing key D8AFDDA07A5B6EDFA7D8CCDAD6D055F927843F1C...
  -> Locally signing key 76C6E477042BFE985CC220BD9C08A255442FAFF0...
  -> Locally signing key 7C89F4D439B2BFACF425107B62443D89B35859F8...
  -> Locally signing key 1E7908935AAB9A00D6B47503363DFFFD59152F77...
  -> Locally signing key 04BB537F5BC2D399BFA72F8F17C752B61B2F2E90...
  -> Locally signing key DDB867B92AA789C165EEFA799B729B06A680C281...
  -> Locally signing key 5A97ED6B72418199F0C22B23137C934B5DCB998E...
  -> Locally signing key 684148BB25B49E986A4944C55184252D824B18E8...
  -> Locally signing key 75C1B95A4D9514A57EB2DAE71817DC63CD3B5DF5...
  -> Locally signing key 39F0EC1AE50B37E5F3196F09DAD3B211663CA268...
  -> Locally signing key 2D14560CDCE6A75BB186DB758238651DDF5E0594...
  -> Locally signing key 35B4FF23EA9477582C2A0AF12B80869C5C0102A6...
  -> Locally signing key E4CDFE50A2DA85D58C8A8C70CAA6A59611C7F07E...
  -> Locally signing key 74C2F2CC05A0AB7D859839938934292D604F8BA2...
  -> Locally signing key 77DC01C9971AC3C39A0626F72C089F09AC97B894...
  -> Locally signing key 16DC688DF3EECC72323954237EC47C82A42D53A2...
  -> Locally signing key 2C688B52E3FC0144B7484BABE3B3F44AC45EE0AA...
  -> Locally signing key 91FFE0700E80619CEB73235CA88E23E377514E00...
  -> Locally signing key 22C903DE964E6FE321656E318DB9F8C18DF53602...
  -> Locally signing key 0E8B644079F599DFC1DDC3973348882F6AC6A4C2...
  -> Locally signing key AB19265E5D7D20687D303246BA1DFB64FFF979E7...
==> Importing owner trust values...
==> Disabling revoked keys in keyring...
  -> Disabling key 8F76BEEA0289F9E1D3E229C05F946DED983D4366...
  -> Disabling key 63F395DE2D6398BBE458F281F2DBB4931985A992...
  -> Disabling key 50F33E2E5B0C3D900424ABE89BDCF497A4BBCC7F...
  -> Disabling key 27FFC4769E19F096D41D9265A04F9397CDFD6BB0...
  -> Disabling key 39F880E50E49A4D11341E8F939E4F17F295AFBF4...
  -> Disabling key 8840BD07FC24CB7CE394A07CCF7037A4F27FB7DA...
  -> Disabling key 5559BC1A32B8F76B3FCCD9555FA5E5544F010D48...
  -> Disabling key 0B20CA1931F5DA3A70D0F8D2EA6836E1AB441196...
  -> Disabling key 07DFD3A0BC213FA12EDC217559B3122E2FA915EC...
  -> Disabling key 4FCF887689C41B09506BE8D5F3E1D5C5D30DB0AD...
  -> Disabling key 5A2257D19FF7E1E0E415968CE62F853100F0D0F0...
  -> Disabling key 540DE7083B89314CF70EA6F0C1B1AD0DA80EBF3E...
  -> Disabling key 7FA647CD89891DEDC060287BB9113D1ED21E1A55...
  -> Disabling key BC1FBE4D2826A0B51E47ED62E2539214C6C11350...
  -> Disabling key 4A8B17E20B88ACA61860009B5CED81B7C2E5C0D2...
  -> Disabling key 5696C003B0854206450C8E5BE613C09CB4440678...
  -> Disabling key 8CF934E339CAD8ABF342E822E711306E3C4F88BC...
  -> Disabling key F5A361A3A13554B85E57DDDAAF7EF7873CFD4BB6...
  -> Disabling key 5E7585ADFF106BFFBBA319DC654B877A0864983E...
  -> Disabling key FAA6840E8C3FC7F89BEE0DC8AC7AB10BCB6CDD17...
  -> Disabling key 65EEFE022108E2B708CBFCF7F9E712E59AF5F22A...
  -> Disabling key 40440DC037C05620984379A6761FAD69BA06C6A9...
  -> Disabling key 34C5D94FE7E7913E86DC427E7FB1A3800C84C0A5...
  -> Disabling key 81D7F8241DB38BC759C80FCE3A726C6170E80477...
  -> Disabling key E7210A59715F6940CF9A4E36A001876699AD6E84...
  -> Disabling key 5357F3B111688D88C1D88119FCF2CB179205AC90...
  -> Disabling key FB871F0131FEA4FB5A9192B4C8880A6406361833...
  -> Disabling key 66BD74A036D522F51DD70A3C7F2A16726521E06D...
  -> Disabling key B1F2C889CB2CCB2ADA36D963097D629E437520BD...
  -> Disabling key 9515D8A8EAB88E49BB65EDBCE6B456CAF15447D5...
  -> Disabling key 40776A5221EF5AD468A4906D42A1DB15EC133BAD...
  -> Disabling key D4DE5ABDE2A7287644EAC7E36D1A9E70E19DAA50...
  -> Disabling key 44D4A033AC140143927397D47EFD567D4C7EA887...
==> Updating trust database...
01:58:41 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "pacman-mirrors", "-f3")
01:59:08 [6]: Finished. Exit code: 0
01:59:08 [6]: Target cmd: ("pacman-mirrors", "-f3")
01:59:08 [6]: Target output:
::INFO Downloading mirrors from repo.manjaro.org
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
  1.218 Germany        : https://ftp.halifax.rwth-aachen.de/manjaro/
  1.836 Germany        : ftp://ftp.halifax.rwth-aachen.de/manjaro/
  1.301 Germany        : https://mirror.23media.com/manjaro/
  0.722 Germany        : http://mirror.23media.com/manjaro/
  0.863 Austria        : http://mirror.easyname.at/manjaro/
  1.717 Austria        : ftp://mirror.easyname.at/manjaro/
::INFO Writing mirror list
::Germany         : https://mirror.23media.com/manjaro/x32-stable
::Austria         : http://mirror.easyname.at/manjaro/x32-stable
::Germany         : https://ftp.halifax.rwth-aachen.de/manjaro/x32-stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
01:59:08 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "pacman", "-Syy")
01:59:17 [6]: Finished. Exit code: 0
01:59:17 [6]: Target cmd: ("pacman", "-Syy")
01:59:17 [6]: Target output:
downloading core.db...
downloading extra.db...
downloading community.db...
01:59:23 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "pacman", "-R", "--noconfirm", "amd-ucode")
01:59:54 [6]: Finished. Exit code: 0
01:59:54 [6]: Target cmd: ("pacman", "-R", "--noconfirm", "amd-ucode")
01:59:54 [6]: Target output:
checking dependencies...
Packages (1) amd-ucode-20190313.efd2c1c-1.0
Total Removed Size:  0.06 MiB
:: Do you want to remove these packages? [Y/n]
removing amd-ucode...
01:59:55 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "killall", "-9", "gpg-agent")
01:59:55 [6]: Finished. Exit code: 0
01:59:55 [6]: Target cmd: ("killall", "-9", "gpg-agent")
01:59:55 [6]: Target output:
01:59:55 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "update-grub")
02:00:50 [6]: Finished. Exit code: 0
02:00:50 [6]: Target cmd: ("update-grub")
02:00:50 [6]: Target output:
Found initrd image: /boot/intel-ucode.img /boot/initramfs-4.14-i686.img
done
02:00:50 [6]: Running "chroot" ("/tmp/calamares-root-g7vjbqkh", "grub-editenv", "-", "set", "menu_auto_hide=1", "boot_success=1")
02:00:50 [6]: Target cmd: ("grub-editenv", "-", "set", "menu_auto_hide=1", "boot_success=1")
02:00:50 [6]: Starting job "umount"
02:00:50 [6]: Determining gettext path from ("/home/manjaro", "/usr/bin", "/usr/share/locale")
02:00:50 [6]:  .. Found "es_ES" in "/usr/share/locale/es_ES"
02:00:50 [6]: Job file "/usr/lib/calamares/modules/umount/main.py"
02:00:50 [6]: Job description from pretty_name "umount" = "Desmontar sistemas de archivos."
umount: /tmp/calamares-root-g7vjbqkh/sys (sys) unmounted
umount: /tmp/calamares-root-g7vjbqkh/run/udev (run) unmounted
umount: /tmp/calamares-root-g7vjbqkh/run (tmpfs) unmounted
umount: /tmp/calamares-root-g7vjbqkh/proc (proc) unmounted
umount: /tmp/calamares-root-g7vjbqkh/dev (dev) unmounted
umount: /tmp/calamares-root-g7vjbqkh (/dev/sda1) unmounted
02:00:56 [6]: FinishedPage::setUpRestart()
Looks like the installation has succeeded. Did you restart your machine? What happened?
Bad idea to post the output here.Plesse post to a pastebin client like hastebin.com
Or at least format the pasted text as code.
Hard disk boot sector invalid!!! :sob:
but it is even worst because I decided to repeat all process again and now there is a new message
hard disk fail :dizzy_face:
and them black screen. I tried to several times to get the installation process and to format again with Gparted but program can not recognize the hard drive...
It seems the hard drive has died
https://hastebin.com/xenoyaciga.coffeescript
Today I am too tired to do anything else. This week-end i will tell you if i can solve this last issue.
Anyway, thanks all of you for your interest and help. I am learning a lot.
Calamares log seems OK. It might have been a hardware issue with the disk, indeed. Take the laptop apart and see if the disk sits fit in the SATA interface.
I am back again. The hidges of th laptop got broken but I tried again to install so here the log is: https://hastebin.com/ulizabesej.coffeescript
I have not seen the last post so I will check if the disk sits fit the SATA interface but it should notb a problem because I had installed ubuntu some years ago I did not touch it again.
I copied the old to hastebin so we can easier compare the outputs
https://hastebin.com/cakazatuli.coffeescript
What I can see from a quick search is that the new installation https://hastebin.com/ulizabesej.coffeescript only reports 2 errors, while the old https://hastebin.com/cakazatuli.coffeescript has got 6 errors.
Is the system functional now, BTW? :slight_smile:
